Home » Eclipse Projects » P2 » Generating P2 Target Platform
Generating P2 Target Platform [message #778339] Thu, 12 January 2012 13:13 Go to next message
Dark Phoenix is currently offline Dark PhoenixFriend
I want to build an RCP Application with Maven and Tycho but then I should make my Target Platform wich is only a folder in the file-system to a p2 repository.
To generate the p2 I createt a new workspace, set the target platform and followed this tutorial: nirmalsasidharan .wordpress.com/2010/10/09/provisioning-your-target-platform-as-local-p2-site/
Eclipse generates me a p2 repository and all seems fine but when I want to set this generated p2 as target platform in eclipse it fails. Eclipse says that "org.eclipse.swtbot.eclipse.finder" requieres the package "javax.swing.text".
I searched a bit and found out that javax.swing.text is a part from the jdk, and some people managed it somehow to get the jdk in this p2.
Can you please help me with this issue? Can't find any information witch can help.
THX in advance
Best regards
DarkPhoenix
Re: Generating P2 Target Platform [message #779684 is a reply to message #778339] Mon, 16 January 2012 10:23 Go to previous message
Is there no one who could help me with this issue? Sad
This is essential for the build with tycho.
I know there should be a solution for this problem because on this pages they had made the JRE part of the p2:
dev.eclipse .org/mhonarc/lists/p2-dev/msg04350.html
<unit id='a.jre.javase' version='1.6.0' singleton='false'>
<provided namespace='java.package' name='javax.swing' version='0.0.0'/>
or
grepcode .com/file/repo1.maven.org/maven2/org.sonatype.tycho/tycho-osgi-components/0.11.1/p2repo/content.xml
<unit id='a.jre' version='1.6.0' singleton='false'>
Previous Topic:How to prevent uninstalling itself?
Next Topic:p2 installer
Current Time: Thu Dec 26 11:24:31 GMT 2024
Powered by FUDForum. Page generated in 0.03383 seconds
