Home » Archived » XML Schema Definition (XSD) » How to access the ID of a XSDComponent
How to access the ID of a XSDComponent [message #77530] Thu, 02 April 2009 16:04 Go to next message
Joachim is currently offline JoachimFriend
The specification http://www.w3.org/TR/xmlschema-1/ describes a field
'id' at nearly each XSD Element, e.g. "xsd:attribute".
I don't find this field in the ECORE model xsd.ecore.
My problem is that I want to read and write this field.
I have this XSD excerpt:
<xsd:attribute name="B" id="r19">
<xsd:simpleType>
<xsd:restriction base="xsd:string">
<xsd:minLength value="0" />
<xsd:maxLength value="10" />
</xsd:restriction>
</xsd:simpleType>
</xsd:attribute>
I don't know how to read the value of the 'id' through the
XSDAttributeDeclaration but succeed via the field 'element:DOMElement'.
I don't know how to set the value of 'id'. I tried with filling the
XSDResourceImpl:setIntrinsicIDToEObjectMap(), but this has no effect for
XSDResourceImpl:save().
This map is also not filled at load time.
Is this a bug or is there another proposed way to read and write 'id'?
Joachim
Re: How to access the ID of a XSDComponent [message #77546 is a reply to message #77530] Thu, 02 April 2009 17:50 Go to previous messageGo to next message
--------------090907000805030103020609
Joachim,
It's not part of the component model. You can only get *and *set it
through the DOM.
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> for XSDResourceImpl:save().
> Joachim
<html>
<head>
http-equiv="Content-Type">
</head>
Joachim,<br>
<br>
Ed Merks
Re: How to access the ID of a XSDComponent [message #78052 is a reply to message #77546] Wed, 22 July 2009 11:56 Go to previous message
Hi Ed,
thanks, this worked fine.
Joachim
Ed Merks schrieb:
> Joachim,
> through the DOM.
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:attribute>
>> Thanks,
>> Joachim
Re: How to access the ID of a XSDComponent [message #604145 is a reply to message #77530] Thu, 02 April 2009 17:50 Go to previous message
Joachim,
through the DOM.
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> Joachim
<html>
<head>
</head>
Joachim,<br>
<br>
Ed Merks
Re: How to access the ID of a XSDComponent [message #604274 is a reply to message #77546] Wed, 22 July 2009 11:56 Go to previous message
Hi Ed,
Joachim
Ed Merks schrieb:
> Joachim,
> through the DOM.
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:attribute>
>> Thanks,
>> Joachim
Previous Topic:XSDSimpleTypeDefinition::facetContents not sortable?
Next Topic:XSDSimpleTypeDefinition::facetContents not sortable?
Current Time: Wed Feb 05 17:52:58 GMT 2025
Powered by FUDForum. Page generated in 0.02909 seconds
