Home » Eclipse Projects » JFace » Databinding with Enum + Combo
Databinding with Enum + Combo [message #5376] Fri, 15 May 2009 02:30 Go to next message
Charlie Kelly is currently offline Charlie KellyFriend
Are there any examples/snippets available for databinding with a enum
and a Combo?
Charlie
Re: Databinding with Enum + Combo [message #6152 is a reply to message #5376] Fri, 15 May 2009 17:51 Go to previous messageGo to next message
Boris Bokowski is currently offline Boris BokowskiFriend
Hi Charlie,
Not that I am aware of, but if you could contribute one that would be great.
Currently, the snippets/examples plug-in does not use Java 1.5 features but
we would change that as soon as we add snippets dealing with enums,
generics, etc.
http://wiki.eclipse.org/JFace_Data_Binding/How_to_Contribute
Boris
"Charlie Kelly" <Eclipse@CharlieKelly.com> wrote in message
news:guik5e$c2n$1@build.eclipse.org...
> Are there any examples/snippets available for databinding with a enum and
> a Combo?
> Thanks
> Charlie
Re: Databinding with Enum + Combo [message #6195 is a reply to message #6152] Fri, 15 May 2009 19:42 Go to previous messageGo to next message
Originally posted by: fakemail.xyz.de
--------------050409030108030606030603
Boris Bokowski schrieb:
> Hi Charlie,
> generics, etc.
> Boris
>> a Combo?
>> Thanks
>> Charlie
I once implemented a Simple one .. may be its enough for you..
Content-Type: text/java;
name="ComboBoxViewer.java"
Content-Disposition: inline;
filename="ComboBoxViewer.java"
package uihelpers;
import helpers.GH;
import java.util.ArrayList;
import java.util.Arrays;
import java.util.List;
import org.eclipse.swt.widgets.Combo;
public class ComboBoxViewer<T> {
private final List<T> items;
private final Combo combo;
public ComboBoxViewer(Combo combo,T[] items) {
this(combo,Arrays.asList(items));
public ComboBoxViewer(Combo combo, List<T> items) {
this(combo,items, false);
* @param combo - the combo for which this viewer is
* @param items - the items that can be choosen
* @param addEmptyItem - if an additional empty item should be added "no item selected"
public ComboBoxViewer(Combo combo, List<T> items,boolean addEmptyItem) {
this.combo = combo;
this.items = new ArrayList<T>(items);
if (addEmptyItem) {
this.items.add(0, null);
for (T t: this.items) {
combo.add(get(t));
* selects the given item in the ComboBox
* @param t - one item that is presenting the list
* throws IllegalArgumentException if not in the list.
public void select(T t) {
int i = items.indexOf(t);
if (i == -1) {
throw new IllegalArgumentException();
} else {
combo.select(i);
* selects the first item that will return the same string
* @param s
public void selectByString(String s) {
for (T t : items) {
if ( GH.isNullOrEmpty(s) ? GH.isNullOrEmpty(get(t)) : s.equals(get(t))) {
select(t);
private String get(T t) {
if (t == null) {
return "";
}else {
return getShown(t);
* @param t - an item that should be presented
* implementing classes should override this method..
* @return bhy default toString() is returned
protected String getShown(T t) {
return t.toString();
* @return the currently selected item
public T getSelected() {
int i = combo.getSelectionIndex();
if (i != -1) {
return items.get(i);
return null;
public String getSelectedString() {
return get(getSelected());
name="GH.java"
filename="GH.java"
package helpers;
import java.io.Closeable;
import java.io.File;
import java.io.IOException;
import java.net.InetAddress;
import java.util.Collection;
import java.util.Random;
import javax.swing.filechooser.FileSystemView;
* Global Helpers that are useful for everyone..
* @author Quicksilver
public final class GH {
private static final Random rand = new Random();
private static final FileSystemView chooser = FileSystemView.getFileSystemView();
* @see java.util.Random#nextInt(int)
public static int nextInt(int n) {
synchronized(rand) {
return rand.nextInt(n);
public static int nextInt() {
return rand.nextInt();
private GH() {}
* provided for all the might use it..
* as creating costs memory that is never recovered..
* @return a FileSytemView instance..
public static FileSystemView getFileSystemView() {
return chooser;
* emulates behaviour of FileSystemView as good as possible...
* though its not the same..
* -> done as normal FileSystemView has a memory leak on that method..
public static File[] getFiles(File parent,boolean useHidden) {
File[] files = parent.listFiles();
if (files == null) return new File[0];
if (useHidden) {
// int length = files.length;
int k = 0;
for (int i = 0; i+k < files.length; i++) {
while (i+k < files.length && files[i+k].isHidden()) {
k++;
if (i+k < files.length) {
files[i] = files[i+k];
if (k != 0) {
File[] onlyVisible = new File[files.length - k];
System.arraycopy(files, 0, onlyVisible, 0, onlyVisible.length );
return onlyVisible;
return files;
* closes all provided streams ignoring exceptions
* @param closeable
public static void close(Closeable... closeable) {
for (Closeable c: closeable) {
try {
if (c != null) {
c.close();
} catch (IOException e) {
} catch (RuntimeException e) {
e.printStackTrace();
* sleeps ignoring interruption handling..
* @param millis - how long to sleep
public static void sleep(long millis) {
try {
Thread.sleep(millis);
} catch(InterruptedException ie) {}
* replaces invalid characters in Filenames
public static String replaceInvalidFilename(String filename) {
filename = filename.replace("\\", ".");
filename = filename.replace("/", ".");
filename = filename.replace("*", ".");
filename = filename.replace("?", ".");
filename = filename.replace("\"", "\'");
filename = filename.replace("<", ".");
filename = filename.replace(">", ".");
filename = filename.replace("|", ".");
filename = filename.replace(":", "-");
return filename;
* replaces invalid filepath
public static String replaceInvalidFilpath(String filename) {
filename = filename.replace(File.separator.equals("\\")?"/": "\\", ".");
return filename;
* replaces newline characters with \n
* and \ with \\
* so it does basic escaping
* @param s
* @return
public static String replaces(String s) {
s = s.replace("\\", "\\\\");
s = s.replace("\n", "\\n");
return s;
* reverses replacements of replace function
public static String revReplace(String s) {
int i = 0;
while ((i = s.indexOf('\\',i)) != -1) {
if (s.length() > i+1) {
char c = s.charAt(i+1);
if (c == '\\') {
s = s.substring(0, i)+"\\"+s.substring(i+2) ;
} else if (c == 'n') {
s = s.substring(0, i)+"\n"+s.substring(i+2);
i++;
return s;
public static boolean isLocaladdress(InetAddress ia) {
return ia.isLoopbackAddress()|| ia.isSiteLocalAddress();
public static String getStacktrace(Thread t) {
String s = t.getName();
for (StackTraceElement ste:t.getStackTrace()) {
s += "\n"+ste.getFileName()+" Line:"+ste.getLineNumber()+" "+ste.getMethodName();
return s;
public static boolean isEmpty(String s) {
return s.length() == 0;
public static boolean isNullOrEmpty(String s) {
return s == null || s.length() == 0;
public static String toString(Object[] arr) {
if (arr == null) {
return "null";
if (arr.length == 0) {
return "{empty}";
String s = "";
for (Object o:arr) {
s+=","+o.toString();
return "{"+s.substring(1)+"}";
public static byte[] concatenate(byte[]... arrays) {
int totalsize= 0;
for (byte[] array: arrays) {
totalsize += array.length;
byte[] all = new byte[totalsize];
int currentpos = 0;
System.arraycopy(array, 0, all, currentpos, array.length);
currentpos += array.length;
return all;
public static int compareTo(int a , int b) {
return (a < b ? -1 : (a==b ? 0 : 1));
public static int compareTo(byte a , byte b) {
public static int unsingedCompareTo(byte a,byte b) {
return compareTo(a & 0xff , b & 0xff);
* concatenates each term in collection using .toString()
* and puts between each string "between"
* if the map is empty it will return the empty map string instead...
* prefix and postfix are applied around everything..
public static String concat(Collection<?> terms,String between,String emptyMap) {
String ret = null;
for (Object o: terms) {
if (ret != null) {
ret += between+o.toString();
} else {
ret = o.toString();
if (ret == null) {
return emptyMap;
} else {
return ret;
--------------050409030108030606030603--
Re: Databinding with Enum + Combo [message #6209 is a reply to message #6195] Fri, 15 May 2009 19:44 Go to previous messageGo to next message
>> Hi Charlie,
>> great. Currently, the snippets/examples plug-in does not use Java 1.5
>> features but we would change that as soon as we add snippets dealing
>> with enums, generics, etc.
>> Boris
>>> and a Combo?
>>> Thanks
>>> Charlie
Ah I think I misread you .. though you were looking for some kind of
viewer...
sry..
Re: Databinding with Enum + Combo [message #6224 is a reply to message #6152] Fri, 15 May 2009 20:58 Go to previous messageGo to next message
--------------010704090406010009050409
Attached is a snippet that demonstrates binding an enum to a
ComboViewer. It's pretty simple once you see the keys.
Boris, I've got a patch for the snippets project with this. What
specifics (Project, Component, subject prefix, etc) should I use to
enter the Bugzilla?
Eric
Boris Bokowski wrote:
> Hi Charlie,
> generics, etc.
> Boris
>> a Combo?
>> Thanks
>> Charlie
name="Snippet034ComboViewerAndEnum.java"
filename="Snippet034ComboViewerAndEnum.java"
* Copyright (c) 2009 Eric Rizzo and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Eric Rizzo - initial API and implementation
package org.eclipse.jface.examples.databinding.snippets;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.beans.PojoObservables;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.value.IObservableVal ue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.databinding.viewers.ViewersObservables;
import org.eclipse.jface.viewers.ArrayContentProvider;
import org.eclipse.jface.viewers.ComboViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class Snippet034ComboViewerAndEnum {
Display display = new Display();
final Person model = new Person("Pat", Gender.Unknown);
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
final Shell shell = new View(model).createShell();
// The SWT event loop
Display display = Display.getCurrent();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
// Print the results
System.out.println("person.getName() = " + model.getName());
System.out.println("person.getGender() = " + model.getGender());
static enum Gender {
Male, Female, Unknown;
// The data model class. This is normally a persistent class of some sort.
// In this example, we only push changes from the GUI to the model, so we
// don't worry about implementing JavaBeans bound properties. If we need
// our GUI to automatically reflect changes in the Person object, the
// Person object would need to implement the JavaBeans property change
// listener methods.
static class Person {
// A property...
String name;
Gender gender;
public Person(String name, Gender gender) {
this.name = name;
this.gender = gender;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public Gender getGender() {
return gender;
public void setGender(Gender newGender) {
this.gender = newGender;
// The GUI view
static class View {
private Person viewModel;
private Text name;
private ComboViewer gender;
public View(Person viewModel) {
this.viewModel = viewModel;
public Shell createShell() {
// Build a UI
Display display = Display.getDefault();
Shell shell = new Shell(display);
RowLayout layout = new RowLayout(SWT.VERTICAL);
layout.fill = true;
layout.marginWidth = layout.marginHeight = 5;
shell.setLayout(layout);
name = new Text(shell, SWT.BORDER);
gender = new ComboViewer(shell, SWT.READ_ONLY);
// Here's the first key to binding a combo to an Enum:
// First give it an ArrayContentProvider,
// then set the input to the list of values from the Enum.
gender.setContentProvider(ArrayContentProvider.getInstance() );
gender.setInput(Gender.values());
// Bind the fields
DataBindingContext bindingContext = new DataBindingContext();
IObservableValue widgetObservable = SWTObservables.observeText(
name, SWT.Modify);
bindingContext.bindValue(widgetObservable, PojoObservables
.observeValue(viewModel, "name"));
// The second key to binding a combo to an Enum is to use a
// selection observable from the ComboViewer:
widgetObservable = ViewersObservables
.observeSingleSelection(gender);
.observeValue(viewModel, "gender"));
// Open and return the Shell
shell.pack();
shell.open();
return shell;
--------------010704090406010009050409--
Re: Databinding with Enum + Combo [message #6254 is a reply to message #6224] Sat, 16 May 2009 18:26 Go to previous messageGo to next message
> enter the Bugzilla?
> Eric
Hi Eric,
Thanks for the snippet. The "keys" are particularly helpful.
Boris, given that this snippet is available, would you like me to create
an additional snippet?
Charlie
>> Hi Charlie,
>> Boris
>>> and a Combo?
>>> Thanks
>>> Charlie
Re: Databinding with Enum + Combo [message #7568 is a reply to message #6224] Mon, 18 May 2009 02:37 Go to previous messageGo to next message
Hi Eric,
> enter the Bugzilla?
Eclipse > Platform > UI, you can use a prefix [DataBinding] in the
description.
Thanks!
Boris
Re: Databinding with Enum + Combo [message #7587 is a reply to message #6254] Mon, 18 May 2009 02:39 Go to previous messageGo to next message
Hi Charlie,
You could comment on the bugzilla Eric is going to enter (hoping that he
posts the bug id here), or improve on his snippet if you think it can be
improved.
Thanks!
Boris
Re: Databinding with Enum + Combo [message #7688 is a reply to message #7568] Mon, 18 May 2009 17:27 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=276755
> Hi Eric,
>> enter the Bugzilla?
> description.
> Thanks!
> Boris
Previous Topic:Image control in TreeViewer
Next Topic:Implementing Auto complete
Current Time: Fri Nov 08 23:41:30 GMT 2024
Powered by FUDForum. Page generated in 0.03766 seconds
