Home » Eclipse Projects » P2 » Possible to download files other than jars through update site?
Possible to download files other than jars through update site? [message #766459] Thu, 15 December 2011 20:39 Go to next message
Roshan S. is currently offline Roshan S.Friend
I have an update site running with my features and plugins. What I wanted to know, is it possible to download a file, such as a batch file, when the user updates the plugins?
Re: Possible to download files other than jars through update site? [message #766515 is a reply to message #766459] Thu, 15 December 2011 23:07 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
An IU can have one artifact, which typically is a jar or zip file, but
it can really be any file. You can write touchpoint instructions that
operate on the artifact when installing and uninstalling (some already
exists e.g. unzipping, cleaning up an unzip, copy, remove).
The artifact resides in an artifact repository, and it in turn point to
the actual artifact (an URL to download).
You can naturally also package your file inside the jar (or some other
jar, like a plugin that only contains resources like this...).
It all depends on what you trying to achieve.
So - Answer is 'yes'.
Hope that helps.
- henrik
On 2011-15-12 21:39, Roshan S. wrote:
Re: Possible to download files other than jars through update site? [message #768785 is a reply to message #766515] Tue, 20 December 2011 19:46 Go to previous messageGo to next message
Thanks for the reply Henrik,
I would like to put my file on our server so: http://www.mycompany.com/eclipsec.exe but unfortunately, I don't think the copy action point will support a URL. I used:
instructions.install=org.eclipse.equinox.p2.touchpoint.natives.copy(source:http${#58}//www.mycompany.com/updatesite/eclipsec.exe,target:${installFolder}/eclipsec.exe,overwrite:true);
Am I using the touchpoint incorrectly or would it be better to package the eclipsec.exe in a jar have that installed as part of the update and then unzip it using the unzip action?
Roshan
Re: Possible to download files other than jars through update site? [message #768823 is a reply to message #768785] Tue, 20 December 2011 21:55 Go to previous message
You should view the exe as an artefact and have an IU that describes it.
Other IUs should depend on it.
The instructions to install it will be given the reference to the
artifact - it is in some variable (but I don't remember the name).
- henrik
> Roshan
Previous Topic:Uninstalling feature using p2 director after feature had been updated via update site
Next Topic:P2 documentation?
Current Time: Thu Dec 26 13:39:38 GMT 2024
Powered by FUDForum. Page generated in 0.04326 seconds
