Re: question on howto change the row background based on table data [message #76624 is a reply to message #76560] |
Thu, 22 September 2005 16:31 |
Jim,
Can you post your report design or build the same type of report using the
built in classic model source and reproduce the problem?
Jason Weathersby
BIRT PMC
"jnorris" <james.norris@pb.com> wrote in message
news:dguk47$f92$1@news.eclipse.org...
> Actually this doesn't work correctly after all. I have two conditions set
> to highlight the first column in the report based on comparing values of
> two columns from the dataset. In the designer preview it works as
> expected. However, when I run the application using the same dataset I am
> getting two rows in the report table for each row in the dataset with the
> second row being highlighted when it shouldn't be.
> Any ideas?
> Jim
> news:dguitu$dls$1@news.eclipse.org...
>> Found this answer in a previous post from Jason Weathersby and it works
>> for me:
>> Select the fields in the row and choose the highlights tab under the
>> Property
>> Editor. Add a condition for the highlight and set the background color.
>> -Jim
>> news:dgugk5$a75$1@news.eclipse.org...
>>>I would like to be able to change the background color for a row in a
>>>table based on the value of some of the items in the row. If someone
>>>could tell me if this is possible and how to accomplish it I'd appreciate
>>>it.
>>> Thanks,
>>> Jim
FUDForum. Page generated in 0.04047 seconds
