Birt 3.7 Maven repository [message #755795] |
Wed, 09 November 2011 15:42 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Fabio Da Soghe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=f.dasoghe%40midhgard.it) Messages: 1 Registered: November 2011 |
Hello everybody.
I need to use BIRT Report Engine 3.7 in a web app, built with Gradle.
Gradle uses Maven repository to fetch dependencies, so I need to find all the jars/poms required in the Maven repo. I added the dependency, poms/jars were downloaded, then I got this runtime error:
org.eclipse.birt.report.engine.api.UnsupportedFormatException: The output format pdf is not supported.
at org.eclipse.birt.report.engine.api.impl.EngineTask.setupRenderOption(EngineTask.java:1938)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:96)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
As I'm new to BIRT, I had to do some investigation. It appears to me that the PDF emitter (which I need) isn't present in the Maven central repo, only the HTML one.
Is this correct or am I missing something? If that is the case, how can I do to get things working? Maybe upload all the required jars (maybe from BIRT Report Engine package) to a local Maven repo, then using it to fetch my BIRT-related project dependencies?
Thanks in advance for any hints.
Fabio
Re: Birt 3.7 Maven repository [message #755867 is a reply to message #755795] |
Wed, 09 November 2011 21:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
We are currently working on getting the BIRT libs in an official Maven
Repo, but currently your best approach is to just use a local repo.
Jason
On 11/9/2011 10:42 AM, Fabio Da Soghe wrote:
> Hello everybody.
> at
> at
> at
> Regards,
> Fabio
Re: Birt 3.7 Maven repository [message #757839 is a reply to message #757516] |
Fri, 18 November 2011 22:20 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Stephan,
We will definately look in to this. BIRT 3.7 is part of the Eclipse
indigo release train. I wonder when 2.6.2 was uploaded?
Jason
On 11/18/2011 12:54 PM, koelle wrote:
> Hi all,
> what about:
> h-ttp://wiki.eclipse.org/Maven_Tools_4_Eclipse
> They are building maven.eclipse.com with that tool, there is even a Birt
> 2.6.2 in there. But since Birt 3.7 seams not to be part of Eclipse 3.7
> it's not automatically there.
> They even have a mode where maven central dependencies are used.
> It might be easier to contact them and ask if they can push Birt 3.7
> with that tool into maven.eclipse.org.
> Best wishes
> stephan
FUDForum. Page generated in 0.04894 seconds
