Home » Eclipse Projects » Technology Project and PMC » Problem running my plugin
Problem running my plugin [message #74695] Tue, 17 July 2007 00:12 Go to next message
Originally posted by: chris.thomas.antimatter-studios.co.uk
I'm the sole developer of a plugin called Esftp, it's a SFTP transfer
plugin which lets you right click files in your project and upload them
to the server.
recently I was wanting to get back to the grind and do another release,
I updated to europa (v3.3) and opened the plugin code and started to try
updating some things.
without wanting to go into detail about my problems with eclipse, I
shall link to my blog where I describe one problem with files and fat32
filesystems I found under eclipse, read more here:
http://www.antimatter-studios.co.uk/sites/chris/blog/?p=43
Anyway, that problem withstanding, I have another. When I try to debug
my eclipse plugin, I setup a debug session for my plugin, I sorted out
one problem already with this in that eclipse can have a plugin
installed and then when you debug your plugin, sometimes eclipse
determines that the plugin should use the ALREADY installed version and
not the one you are debugging. So you eventually figure that out and
disable the plugin you have installed during the debug session.
What happens is that my plugin cannot activate, eclipse debugging will
run the other eclipse session, but I cannot open a property page, this
is what happens, I run eclipse debug with the -consoleLog option and
then I look at the output, at the bottom you can find all the output
from various files I have and see if you can find any problem with
anything because I am stumped and cannot find anything.
I hope someone can help with this situation.
If anyone finds this plugin useful! PLEASE HELP ME FIX THIS!
<consoleLog>
!ENTRY org.eclipse.osgi 2 0 2007-07-16 22:54:27.236
!MESSAGE The activator com.antimatter_studios.esftp.Activator for bundle
com.antimatter_studios.esftp is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
at
org.eclipse.ui.internal.dialogs.RegistryPageContributor.crea tePage(RegistryPageContributor.java:119)
at
org.eclipse.ui.internal.dialogs.PropertyPageNode.createPage( PropertyPageNode.java:56)
at
org.eclipse.jface.preference.PreferenceDialog.createPage(Pre ferenceDialog.java:1294)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.cre atePage(FilteredPreferenceDialog.java:313)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1185)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:433)
at
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:698)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:156)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 67 more
Root exception:
java.lang.ClassNotFoundException: com.antimatter_studios.esftp.Activator
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</consoleLog>
<MANIFEST.MF>
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Sftp Plug-in
Bundle-SymbolicName: com.antimatter_studios.esftp; singleton:=true
Bundle-Version: 1.1.5
Bundle-Activator: com.antimatter_studios.esftp.Activator
Bundle-Vendor: Chris Alex Thomas
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.core.resources,
org.eclipse.jface.text,
org.eclipse.ui.console
Eclipse-LazyStart: true
Export-Package: com.antimatter_studios.esftp,
com.antimatter_studios.esftp.actions,
com.antimatter_studios.esftp.directory,
com.antimatter_studios.esftp.properties,
com.antimatter_studios.esftp.ui
Bundle-ClassPath: .,
lib/commons-logging.jar,
lib/esftp-sshtools.jar
</MANIFEST.MF>
<plugin.xml>
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
adaptable="true"
id="com.antimatter_studios.esftp.Menu"
objectClass="org.eclipse.core.resources.IResource">
<menu
id="com.antimatter_studios.esftp"
label="ESftp">
<separator name="group"/>
</menu>
<action
class="com.antimatter_studios.esftp.actions.GetSelection"
definitionId="com.antimatter_studios.esftp.get"
id="com.antimatter_studios.esftp.getItem"
label="Get File From Server"
menubarPath="com.antimatter_studios.esftp/group"/>
<action
class="com.antimatter_studios.esftp.actions.PutSelection"
definitionId="com.antimatter_studios.esftp.put"
id="com.antimatter_studios.esftp.putItem"
label="Put File to Server"
<action
class="com.antimatter_studios.esftp.actions.PutSaveSelection "
definitionId="com.antimatter_studios.esftp.putSave"
id="com.antimatter_studios.esftp.putSaveItem"
label="Put File to Server and Save"
</objectContribution>
</extension>
<extension
point="org.eclipse.ui.preferencePages">
<page
class="com.antimatter_studios.esftp.ui.Workbench"
id="com.antimatter_studios.esftp.properties.Workbench"
name="ESftp"/>
</extension>
<extension
point="org.eclipse.ui.propertyPages">
<page
class="com.antimatter_studios.esftp.ui.Project"
id="com.antimatter_studios.esftp.properties.Project"
name="ESftp"
objectClass="org.eclipse.core.resources.IProject"/>
</extension>
<extension point="org.eclipse.ui.actionSets">
<actionSet label="ESftp" visible="true"
id="com.antimatter_studios.esftp.actionSet">
<menu label="ESf&amp;tp"
id="com.antimatter_studios.esftp.esftpmenu"
path="window">
<separator name="ESftpGroupMenu"></separator>
</menu>
<action
icon="icons/put.gif"
id="com.antimatter_studios.esftp.putActionSet"
label="&amp;Put File"
menubarPath="com.antimatter_studios.esftp.esftpmenu/ESftpGroupMenu "
toolbarPath="ESftpGroupMenu"
tooltip="Put File to Server">
</action>
<action
id="com.antimatter_studios.esftp.putSaveActionSet"
label="&amp;Put+Save File"
tooltip="Put File to Server and Save">
</action>
<action
icon="icons/get.gif"
id="com.antimatter_studios.esftp.getActionSet"
label="&amp;Get File"
tooltip="Get file from remote">
</action>
</actionSet>
</extension>
<extension point="org.eclipse.ui.commands">
<category name="EsftpCategory"
description="ESftp Commands"
id="com.antimatter_studios.esftp.commandCategory">
</category>
<command
categoryId="com.antimatter_studios.esftp.commandCategory"
name="Put File to Server"
id="com.antimatter_studios.esftp.put" />
<command
id="com.antimatter_studios.esftp.putSave"
name="Put File to Server and Save"/>
<command
name="Get File from Server"
id="com.antimatter_studios.esftp.get" />
</extension>
<extension point="org.eclipse.ui.bindings">
<key sequence="Ctrl+Alt+P"
commandId="com.antimatter_studios.esftp.put"
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration" />
<key sequence="Ctrl+Alt+S"
commandId="com.antimatter_studios.esftp.putSave"
<key sequence="Ctrl+Alt+G"
commandId="com.antimatter_studios.esftp.get"
</extension>
</plugin>
</plugin.xml>
<build.properties>
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
META-INF/,\
lib/
</build.properties>
Re: Problem running my plugin [message #74772 is a reply to message #74695] Tue, 17 July 2007 10:50 Go to previous messageGo to next message
Chris Thomas wrote:
> to the server.
> <consoleLog>
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> </consoleLog>
> <MANIFEST.MF>
> </MANIFEST.MF>
> <plugin.xml>
> <plugin>
> <extension
> <objectContribution
> adaptable="true"
> <menu
> label="ESftp">
> </menu>
> <action
> <action
> <action
> </extension>
> <extension
> <page
> name="ESftp"/>
> </extension>
> <extension
> <page
> name="ESftp"
> </extension>
> path="window">
> </menu>
> <action
> </action>
> <action
> </action>
> <action
> </action>
> </actionSet>
> </extension>
> </category>
> <command
> <command
> <command
> </extension>
> </extension>
> </plugin>
> </plugin.xml>
> <build.properties>
> source.. = src/
> output.. = bin/
> META-INF/,\
> lib/
> </build.properties>
ok, after talking to paul webster on IRC, I found the solution, which
was that on the build tab, at the top, you have two sections under
"runtime configuration", on the left, you have add library, it usually
contains "." as the only item, or more, but "." is usually there. On
the other side, you have add Folder, there was the problem, it was
empty, upon adding "src", which is the folder containing the plugin
source code, I was able to finally get the plugin to work.
so I hope that helps some people and saves them from the problem I had.
Re: Problem running my plugin [message #74855 is a reply to message #74772] Tue, 31 July 2007 03:04 Go to previous message
Originally posted by: atoulme.intalio.com
Hi Chris,
this looks like something that you should report to the Equinox
newsgroup. I experienced the same problems and ended up deleting my
plugin.properties file. That did it.
Please report on the equinox newsgroup and/or open a bug.
Antoine
Chris Thomas wrote:
> Chris Thomas wrote:
>> Hi,
>> to the server.
>> <consoleLog>
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 67 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> </consoleLog>
>> <MANIFEST.MF>
>> </MANIFEST.MF>
>> <plugin.xml>
>> <?xml version="1.0" encoding="UTF-8"?>
>> <plugin>
>> <extension
>> <objectContribution
>> adaptable="true"
>> <menu
>> label="ESftp">
>> </menu>
>> <action
>> <action
>> <action
>> </extension>
>> <extension
>> <page
>> name="ESftp"/>
>> </extension>
>> <extension
>> <page
>> name="ESftp"
>> </extension>
>> path="window">
>> </menu>
>> <action
>> </action>
>> <action
>> </action>
>> <action
>> </action>
>> </actionSet>
>> </extension>
>> </category>
>> <command
>> <command
>> <command
>> </extension>
>> </extension>
>> </plugin>
>> </plugin.xml>
>> <build.properties>
>> source.. = src/
>> output.. = bin/
>> META-INF/,\
>> lib/
>> </build.properties>
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: Problem running my plugin [message #601491 is a reply to message #74695] Tue, 17 July 2007 10:50 Go to previous message
Chris Thomas wrote:
> to the server.
> <consoleLog>
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> </consoleLog>
> <MANIFEST.MF>
> </MANIFEST.MF>
> <plugin.xml>
> <plugin>
> <extension
> <objectContribution
> adaptable="true"
> <menu
> label="ESftp">
> </menu>
> <action
> <action
> <action
> </extension>
> <extension
> <page
> name="ESftp"/>
> </extension>
> <extension
> <page
> name="ESftp"
> </extension>
> path="window">
> </menu>
> <action
> </action>
> <action
> </action>
> <action
> </action>
> </actionSet>
> </extension>
> </category>
> <command
> <command
> <command
> </extension>
> </extension>
> </plugin>
> </plugin.xml>
> <build.properties>
> source.. = src/
> output.. = bin/
> META-INF/,\
> lib/
> </build.properties>
Re: Problem running my plugin [message #601526 is a reply to message #74772] Tue, 31 July 2007 03:04 Go to previous message
Hi Chris,
Antoine
Chris Thomas wrote:
> Chris Thomas wrote:
>> Hi,
>> to the server.
>> <consoleLog>
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 67 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> </consoleLog>
>> <MANIFEST.MF>
>> </MANIFEST.MF>
>> <plugin.xml>
>> <plugin>
>> <extension
>> <objectContribution
>> adaptable="true"
>> <menu
>> label="ESftp">
>> </menu>
>> <action
>> <action
>> <action
>> </extension>
>> <extension
>> <page
>> name="ESftp"/>
>> </extension>
>> <extension
>> <page
>> name="ESftp"
>> </extension>
>> path="window">
>> </menu>
>> <action
>> </action>
>> <action
>> </action>
>> <action
>> </action>
>> </actionSet>
>> </extension>
>> </category>
>> <command
>> <command
>> <command
>> </extension>
>> </extension>
>> </plugin>
>> </plugin.xml>
>> <build.properties>
>> source.. = src/
>> output.. = bin/
>> META-INF/,\
>> lib/
>> </build.properties>
Previous Topic:contexts
Next Topic:Web development with Server Side Eclipse
Current Time: Tue Apr 29 03:39:49 EDT 2025
Powered by FUDForum. Page generated in 0.33894 seconds
