Home » Eclipse Projects » Eclipse Platform » Ant build problem
Ant build problem [message #73137] Fri, 13 June 2003 03:46 Go to next message
I have a strange problem when using ant in combine with Eclipse. It seems
that eclipse dont change the time the file was changed (or something like
that). Anyway, when I edit a java file and then want to do a build, I run my
ant task. the problem is that it doesnt compile any files if there is an old
class file in the output directory. I know the build.xml works for "manual"
builds as I tested running it from a dos-promt and edit the java file in
another editor. I dont want to fix this through a "clean" task in the
build.xml so that is not an option. I guess there is something small I have
missed somewhere.
<target name="init">
<tstamp/>
</target
<target name="compile" depends="init">
<javac classpath = "${classpath}"
srcdir = "${src}"
destdir = "${build}"
deprecation = "on"
debug= "on"
<include name="**/*.java"/>
</javac>
</target>
Thanks in advance!
Re: Ant build problem [message #73156 is a reply to message #73137] Fri, 13 June 2003 04:06 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
I think this is because you have Eclipse's auto compile on save option set.
In this case ant won't compile any source because the class files are always
up-to-date with the source.
To manage auto compile, see Window-->Preferences-->Workbench-->Perform build
automatically on resource modification.
HTH,
Csaba
"Mathias" <mathias.ohlsson@enovation.se> wrote in message
news:bcbvfu$l5m$1@rogue.oti.com...
my
old
"manual"
have
> missed somewhere.
> <tstamp/>
> </target
> srcdir = "${src}"
> deprecation = "on"
> debug= "on"
> </javac>
> </target>
> Thanks in advance!
Re: Ant build problem [message #73188 is a reply to message #73156] Fri, 13 June 2003 04:16 Go to previous messageGo to next message
Thanks for the help. That solved my issue with the compiling. I just have a
follow-up question on this..:)
When I compile i only get this in the Console:
Buildfile: D:\Project\myproject\build.xml
init:
compile:
BUILD SUCCESSFUL
Total time: 411 milliseconds
Even though it really compiles some files. Im looking for the setting to set
so I see something like this:
compile:
[javac] Compiling 1 source file to D:\Project\myproject\lib
As one do in the dos-prompt.
Thanks again!
/Mathias Ohlsson
"Horv
Re: Ant build problem [message #73346 is a reply to message #73188] Fri, 13 June 2003 08:38 Go to previous message
Originally posted by: darin_swanson.oti.com
Discussed in the eclipse.tools.jdt newsgroup where you cross-posted...please
don't do that.
Darins
"Mathias Ohlsson" <mathias.ohlsson@enovation.se> wrote in message
news:bcc18p$nco$1@rogue.oti.com...
a
> init:
> compile:
> BUILD SUCCESSFUL
set
> compile:
> Thanks again!
> /Mathias Ohlsson
> "Horv
Previous Topic:Showing matching brace that is offscreen
Next Topic:proxy for update also for CVS?
Current Time: Tue Oct 28 23:02:57 EDT 2025
Powered by FUDForum. Page generated in 0.04313 seconds
