Home » Language IDEs » Java Development Tools (JDT) » Getting Line number and offset from a IProblemLocation
icon5.gif  Getting Line number and offset from a IProblemLocation [message #724317] Mon, 12 September 2011 00:46 Go to next message
Hi all,
I am aware that there is getOffset() method for IProblemLocation class. Is there a way to easily transfer this to line number (in the file) and offset on that line?
For example:
location.getOffset() returns 77
I want to get the following:
location.getLineNumber() (this does not exist) = 5
location.getLineOffset() (this also does not exist) = 15
Also, is there a way to retrieve the related file name (i.e., something.java) using IProblemLocation?
Thanks, best regards,
Re: Getting Line number and offset from a IProblemLocation [message #724958 is a reply to message #724317] Tue, 13 September 2011 10:58 Go to previous message
On 12.09.2011 06:46, Kivanc Muslu wrote:
> Hi all,
If you have the file or document, then you can use the
org.eclipse.jface.text.IDocument API.
> For example:
No.
Dani
Previous Topic:increment version number on file/save
Next Topic:auto build does not copy resource files to output folder after save
Current Time: Thu Mar 13 13:57:26 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
