Re: Using DS in RCP [message #723253 is a reply to message #699498] |
Thu, 08 September 2011 07:14 |
Originally posted by:
On 2011-07-21 18:37, Timothy Vogel wrote:
> Thanks for your reply!
> org.eclipse.equinox.ds and org.eclipse.equinox.util are in both plug-in
> projects, the one with just the simple calc service and the one that is
> a RCP workbench project.
> I'm not sure how to start the org.eclipse.equinox.ds in the RCP project.
If you have a product build, you can do that as follows: Open the
Eclipse product editor, go to tab "configuration", add a new entry to
the upper list for the bundle org.eclipse.equinox.ds and set Auto-Start
flag to true. This may not be sufficient for your Eclipse launching
configuration (depending on how you configured it). Therefore, if you
test your application within Eclipse, you need to open the Eclipse
launcher configuration (Run>Run Configurations...), go to tab Plug-ins,
search for the org.eclipse.equinox.ds bundle (which must be selected
there), and also need to set auto-start to true.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.03589 seconds
