Home » Language IDEs » C / C++ IDE (CDT) » gdb can't read execution path on Windows
gdb can't read execution path on Windows [message #71606] Tue, 27 May 2003 16:27 Go to next message
Originally posted by: david.pickens.arc.com
Forgive me if this problem has been addressed elsewhere, but I've spent
considerable time searching the news group and bugzilla and found nothing.
I installed the latest CDT under Eclipse 2.1 on Windows XP Professional,
with MinGW and gdb 5.2.1. I can build the "Hello, World" program okay, but
when I attempt to run the debugger, it immediately aborts with the pop up
dialog:
The execution of program is suspended because of error.
Error creating process C:Documents and SettingsdavidpMy
DocumentsworkspaceHelloWorldhello.exe, (error 193)
As you can see, backslashes are not getting escaped properly. Is there a
preference, or something, that needs to be set somewhere?
-- David
Re: gdb can't read execution path on Windows [message #71662 is a reply to message #71606] Tue, 27 May 2003 16:36 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Check if the "Debugger" option on the "Debugger" propety page of launch
configuration is set to "Cygwin GDB Debugger".
"David Pickens" <david.pickens@arc.com> wrote in message
news:bb03lj$8cc$1@rogue.oti.com...
> dialog:
> Thanks
> -- David
Re: gdb can't read execution path on Windows [message #71699 is a reply to message #71662] Tue, 27 May 2003 17:02 Go to previous messageGo to next message
Mikhail,
Yes, the Debugger is set to "Cygwin GDB Debugger". The gdb path
is "C:\MinGW\bin\gdb.exe".
--David
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:bb049a$8r8$1@rogue.oti.com...
nothing.
but
up
> > dialog:
> > Thanks
> > -- David
Re: gdb can't read execution path on Windows [message #71737 is a reply to message #71699] Tue, 27 May 2003 18:11 Go to previous messageGo to next message
I don't think that this happens because of backslashes. This message is
returned by gdb. Try to debug it from command line.
news:bb05rp$a9m$1@rogue.oti.com...
> Mikhail,
> --David
spent
> nothing.
Professional,
> but
> up
> > > dialog:
a
> > > Thanks
> > > -- David
Re: gdb can't read execution path on Windows [message #71775 is a reply to message #71737] Wed, 28 May 2003 00:41 Go to previous messageGo to next message
I invoked gdb from the command line on my executable, and it
issues the error 193 and then immediately hangs.
So, the problem is indeed gdb related.
Do you happen to know what causes error 193? Is it something to
do with an unrecognized executable format, or something like that?
The executable that I am debugging is simply the "hello,world" example
from the tutorial. It was compiled and
linked with "g++" version 3.2.3, which comes with MinGW. It runs
okay by itself, so, it should be quite acceptable to gdb.
--David
news:bb09s2$dl1$1@rogue.oti.com...
> > Mikhail,
> > --David
launch
> spent
> > nothing.
> Professional,
okay,
> > but
pop
> > up
> > > > dialog:
there
> a
> > > > Thanks
> > > > -- David
Re: gdb can't read execution path on Windows [message #72001 is a reply to message #71775] Wed, 28 May 2003 18:03 Go to previous messageGo to next message
I discovered that the problem only occurs if the executable is within the
"C:\documents and settings" folder, or sub-folder there of. gdb works fine
if the target executable is moved elsewhere.
I found in the gdb source where this error is emitted. It is the error code
from calling the Windows "CreateProcess" API function. gdb first transforms
the path by calling "cygwin_conv_to_win32_path". Evidently, the
path is somehow corrupted. The error message prints out the path prior
to being transformed. I don't have any means to debug gdb itself, so
I am not able see what exactly is being passed to CreateProcess to
cause this error.
-David
news:bb10k5$ts4$1@rogue.oti.com...
> --David
> > > Mikhail,
> > > --David
> launch
> > spent
> > > nothing.
> > Professional,
> okay,
> > > but
> pop
> > > up
> > > > > dialog:
> there
> > a
> > > > > Thanks
> > > > > -- David
Re: gdb can't read execution path on Windows [message #72020 is a reply to message #72001] Wed, 28 May 2003 18:06 Go to previous messageGo to next message
Originally posted by: jvaldez.mail.com
Most like the problem is due to the spaces in the path name.
> cause this error.
> -David
>>--David
>>>>Mikhail,
>>>>--David
>>launch
>>>spent
>>>>nothing.
>>>Professional,
>>okay,
>>>>but
>>pop
>>>>up
>>>>>>dialog:
>>there
>>>a
>>>>>>Thanks
>>>>>> -- David
Re: gdb can't read execution path on Windows [message #72059 is a reply to message #72020] Wed, 28 May 2003 18:17 Go to previous message
No, I checked that already. Spaces don't seem to be a problem if the
target executable is in another directory.
-David
"exquisitus" <jvaldez@mail.com> wrote in message
news:3ED4FA8F.2070203@mail.com...
the
fine
code
transforms
> > cause this error.
> > -David
> >>--David
> >>>>Mikhail,
> >>>>--David
> >>launch
> >>>spent
> >>>>nothing.
> >>>Professional,
> >>okay,
> >>>>but
> >>pop
> >>>>up
> >>>>>>dialog:
> >>there
> >>>a
> >>>>>>Thanks
> >>>>>> -- David
Previous Topic:Problems with C-Editor?!
Next Topic:Error : Stack is not available
Current Time: Tue Nov 12 19:54:49 GMT 2024
Powered by FUDForum. Page generated in 0.03854 seconds
