Home » Archived » Test and Performance Tools Platform (TPTP) » Getting started with hyades...
Getting started with hyades... [message #6903] Mon, 21 February 2005 16:20 Go to next message
Originally posted by: bikehead.hotmail.com
I've downloaded hyades 3.2 and installed it over eclipse 3.1M5 on Fedora
Core 3. Eclipse works fine, and the hyades UI work, but I seem to be
have problem with the RAServer. I installed it per the instructions,
but when I start it, it seems to terminate immediately. I checked the
log file and it just has one entry for when the server starts and
another for when it terminates; no other information is given.
The instructions seems to imply that once I start the RAServer it
supposed to stay up until I give it a kill signal right? Any
suggestions on why it may be terminating?
Whenever I try and profile the example instructions in the hyades
tutorial I always get a "unable to communciate with agent" message,
which I'm assuming is a result of the RAServer not running.
Brian
Re: Getting started with hyades... [message #6957 is a reply to message #6903] Tue, 22 February 2005 14:43 Go to previous messageGo to next message
Samson Wai is currently offline Samson WaiFriend
Member
Hi Brian,
Have you run the "SetConfig.sh" script under the "bin" directory to generate
the config files? The RAServer will terminate if it cannot find the config
files.
Do you have the "compat-libstdc++" RPM package installed? The RAServer is
compiled using the C++ library "libstdc++-libc6.2-2.so.3" which is available
on older Linux kernels (it is built on Red Hat Linux 7.2).
Is port 10002 available? RAServer uses that port for incomming connection
requests. You can check if port 10002 is available by looking at the output
of "netstat -a".
Samson
"Brian Anderson" <bikehead@hotmail.com> wrote in message
news:cvd1p4$e6m$1@www.eclipse.org...
> Brian
Re: Getting started with hyades... [message #6991 is a reply to message #6957] Tue, 22 February 2005 17:41 Go to previous messageGo to next message
--------------060701020600040301020602
Thank you for replying with some suggestions. See my responses below
Samson Wai wrote:
> Hi Brian,
> files.
Yes I did do this and I checked the resulting config file it generated
and it looked good.
Yup, have this also.
> of "netstat -a".
The port is available.
> Samson
I've attached the log file in case it helps a more knowledgable person.
I also run RAServer under strace and I've attached the last portion of
it (the whole thing is about 128K). I notice the process gets a SEGV
near the end, but its unclear if this is the cause of the problem.
Again, thanks for any help provided. I'd love to try hyades on our product.
-Brian
>>Thanks,
>>Brian
Content-Type: text/x-log;
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001A50631B2CF702FD26528" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15944" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B2003A616A00720887FB" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B37161FF74ED50C241B9" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B602262ACD6857A6813C" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B7561506924B555C3AEE" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B9DA63EAFE3966E7466E" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BA1D3D685E8E5BED8896" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BB484C1998042EC75F96" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BB7D1A1115D83D32F672" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001E3330D3457D522129762" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15944" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:50.000000Z" globalInstanceId="k21B6BD2000C63362E60BE3B0E095251" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15975" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005C9E03DC3A7477AF44F62" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005D70615A56F7853370D5F" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005E3911D84485E577F4BD6" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005E8DF7B7A226C1B974D2C" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005F7303EA17C65693D9B9C" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD300060214450F45693FAC59C5" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000604350D72AC321B04C4BA" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000605EB4EB7EC7B46B24743" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000EF05D6802496B2CF3C082" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15975" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB000896C367FB83560BB2FCCE" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15984" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008B6836583A43F557615AE" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008BA6E0D2C4A1127957596" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008BF6F69C6EA8B73A5F0C7" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C3412CDED9F7085BF160" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C86F5E3EF6E22E08E05A" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C9CC2D4C171921B1FE89" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008CBC12B63D2270E4768DE" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008CCD6231C426214ED5F1C" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0009123E2D5AF461100B5954" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15984" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
name="hyades.trace"
filename="hyades.trace"
lstat64("org.eclipse.hyades.test", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open(" /home/development/rac/plugins/org.eclipse.hyades.test/config /pluginconfig.xml ", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0755, st_size=1944, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x605000
read(5, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1944
read(5, "", 45056) = 0
read(5, "", 49152) = 0
close(5) = 0
munmap(0x605000, 4096) = 0
gettimeofday({1109093371, 575599}, {480, 0}) = 0
time(NULL) = 1109093371
stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=1017, ...}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 667) = 667
getdents64(4, /* 0 entries */, 4096) = 0
close(4) = 0
gettimeofday({1109093371, 575948}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 652) = 652
gettimeofday({1109093371, 576449}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 645) = 645
gettimeofday({1109093371, 576726}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 644) = 644
mmap2(NULL, 10489856, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xff1000
mprotect(0xff1000, 4096, PROT_NONE) = 0
clone(Process 15985 attached
child_stack=0x19f14c8, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THRE AD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHIL D_CLEARTID|CLONE_DETACHED, parent_tidptr=0x19f1bf8, {entry_number:6, base_addr:0x19f1bb0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0x19f1bf8) = 15985
[pid 15984] futex(0x6ec060, FUTEX_WAKE, 2147483647) = 0
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so ", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@\257\25"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=7693006, ...}) = 0
[pid 15984] old_mmap(NULL, 6424548, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x3d55000
[pid 15984] old_mmap(0x4309000, 368640, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x5b3000) = 0x4309000
[pid 15984] old_mmap(0x4363000, 75748, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4363000
[pid 15984] close(4) = 0
[pid 15984] open("/home/development/rac/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/client/libnsl.so.1 ", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/server/libnsl.so.1 ", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/i686/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/i686/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("i686/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("i686/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/etc/ld.so.cache", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=77720, ...}) = 0
[pid 15984] old_mmap(NULL, 77720, PROT_READ, MAP_PRIVATE, 4, 0) = 0xa09000
[pid 15984] open("/lib/libnsl.so.1", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\264"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=97736, ...}) = 0
[pid 15984] old_mmap(0x7e78000, 88064, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x7e78000
[pid 15984] old_mmap(0x7e8a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x11000) = 0x7e8a000
[pid 15984] old_mmap(0x7e8c000, 6144, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7e8c000
[pid 15984] mprotect(0x7e8a000, 4096, PROT_READ) = 0
[pid 15984] munmap(0xa09000, 77720) = 0
[pid 15984] open("/etc/mtab", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=558, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xcf6000
[pid 15984] read(4, "/dev/mapper/VolGroup00-LogVol00 "..., 4096) = 558
[pid 15984] munmap(0xcf6000, 4096) = 0
[pid 15984] open("/proc/stat", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x605000
[pid 15984] read(4, "cpu 804919 70648 186442 5205624"..., 1024) = 264
[pid 15984] read(4, "", 1024) = 0
[pid 15984] munmap(0x605000, 4096) = 0
[pid 15984] open("/proc/meminfo", O_RDONLY) = 4
[pid 15984] read(4, "MemTotal: 1555320 kB\nMemFre"..., 1024) = 670
[pid 15984] gettimeofday({1109093371, 583613}, NULL) = 0
[pid 15984] lstat64("/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so ", {st_mode=S_IFREG|0755, st_size=7693006, ...}) = 0
[pid 15984] open(".hotspotrc", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/endorsed", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = -1 ENOENT (No such file or directory)
[pid 15984] rt_sigaction(SIGSEGV, NULL, {0x804d0f0, [SEGV], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGSEGV, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_STACK|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {0x804d0f0, [SEGV], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGPIPE, NULL, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGPIPE, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGCHLD, NULL, {0x804d134, [], SA_RESTORER, 0x7e58d8}, 8) = 0
[pid 15984] rt_sigaction(SIGCHLD, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO|SA_NOCLDSTOP, 0x7e58d0}, {0x804d134, [], SA_RESTORER, 0x7e58d8}, 8) = 0
[pid 15984] rt_sigaction(SIGBUS, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGBUS, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGILL, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGILL, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGFPE, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGFPE, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] old_getrlimit(RLIMIT_STACK, {rlim_cur=10240*1024, rlim_max=2147483647}) = 0
[pid 15984] open("/proc/self/stat", O_RDONLY) = 4
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x9c7000
[pid 15984] read(4, "15984 (RAServer) R 1 15983 15983"..., 1024) = 188
[pid 15984] munmap(0x9c7000, 4096) = 0
[pid 15984] open("/proc/sys/vm/heap-stack-gap", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] rt_sigprocmask(SIG_BLOCK, NULL, [], 8) = 0
[pid 15984] rt_sigaction(SIGUSR2, {0x41091ec, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, NULL, 8) = 0
[pid 15984] old_getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
[pid 15984] setrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
[pid 15984] open(" /usr/java/j2sdk1.4.2_07/jre/lib/i386/native_threads/libhpi.s o ", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220+\0"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=33188, ...}) = 0
[pid 15984] old_mmap(NULL, 35584, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x769000
[pid 15984] old_mmap(0x771000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x7000) = 0x771000
[pid 15984] geteuid32() = 500
[pid 15984] socket(PF_FILE, SOCK_STREAM, 0) = 4
[pid 15984] fcntl64(4, F_GETFL) = 0x2 (flags O_RDWR)
[pid 15984] fcntl64(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
[pid 15984] connect(4, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
[pid 15984] open("/etc/passwd", O_RDONLY) = 4
[pid 15984] fcntl64(4, F_GETFD) = 0
[pid 15984] fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=1750, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xe71000
[pid 15984] read(4, "root:x:0:0:root:/root:/bin/bash\n"..., 4096) = 1750
[pid 15984] munmap(0xe71000, 4096) = 0
[pid 15984] open("/tmp/hsperfdata_bikehead", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/tmp/hsperfdata_bikehead", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] getdents64(4, /* 3 entries */, 4096) = 80
[pid 15984] kill(15975, SIG_0) = -1 ESRCH (No such process)
[pid 15984] unlink("/tmp/hsperfdata_bikehead/15975") = 0
[pid 15984] getdents64(4, /* 0 entries */, 4096) = 0
[pid 15984] mkdir("/tmp/hsperfdata_bikehead", 0755) = -1 EEXIST (File exists)
[pid 15984] open("/tmp/hsperfdata_bikehead/15984", O_RDWR|O_CREAT|O_TRUNC, 0600) = 4
[pid 15984] ftruncate(4, 16384) = 0
[pid 15984] mmap2(NULL, 16384, PROT_READ|PROT_WRITE, MAP_SHARED, 4, 0) = 0x605000
[pid 15984] mmap2(0xbfe0e000, 12288, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xbfe0e000
[pid 15984] mprotect(0xbfe0e000, 12288, PROT_NONE) = 0
[pid 15984] mmap2(0xbfe04000, 40960, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xbfe04000
[pid 15984] sigaltstack({ss_sp=0xbfe04000, ss_flags=0, ss_size=40960}, NULL) = 0
[pid 15984] rt_sigaction(SIGHUP, NULL, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGINT, NULL, {0x804d0f0, [INT], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGTERM, NULL, {0x804d0f0, [TERM], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigprocmask(SIG_UNBLOCK, [INT QUIT USR2 TERM CHLD], NULL, 8) = 0
[pid 15984] gettimeofday({1109093371, 588826}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588869}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588904}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588940}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588975}, NULL) = 0
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libverify.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\37"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=70980, ...}) = 0
[pid 15984] old_mmap(NULL, 73396, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xd26000
[pid 15984] old_mmap(0xd36000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0xf000) = 0xd36000
[pid 15984] open("/home/development/rac/lib/libjvm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libjvm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/client/libjvm.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\332\t"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=5192831, ...}) = 0
[pid 15984] old_mmap(NULL, 4371592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x355d000
[pid 15984] old_mmap(0x395b000, 114688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x3fd000) = 0x395b000
[pid 15984] old_mmap(0x3977000, 70792, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x3977000
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libjava.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\200"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=142076, ...}) = 0
[pid 15984] old_mmap(NULL, 137668, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x623000
[pid 15984] old_mmap(0x643000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x1f000) = 0x643000
[pid 15984] open("/home/development/rac/lib/libverify.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libverify.so", O_RDONLY) = 4
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libzip.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\35"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=90008, ...}) = 0
[pid 15984] old_mmap(NULL, 91488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xe45000
[pid 15984] old_mmap(0xe59000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x13000) = 0xe59000
[pid 15984] open("/home/development/rac/lib/libjava.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libjava.so", O_RDONLY) = 4
[pid 15984] stat64("/usr/java/j2sdk1.4.2_07/jre/lib/rt.jar", {st_mode=S_IFREG|0644, st_size=26905782, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/rt.jar", {st_mode=S_IFREG|0644, st_size=26905782, ...}) = 0
[pid 15984] --- SIGSEGV (Segmentation fault) @ 0 (0) ---
[pid 15984] rt_sigprocmask(SIG_SETMASK, [SEGV], ~[KILL STOP RTMIN RT_1], 8) = 0
[pid 15984] gettimeofday({1109093371, 594494}, {480, 0}) = 0
[pid 15984] time(NULL) = 1109093371
[pid 15984] stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=1017, ...}) = 0
[pid 15984] write(3, "<CommonBaseEvent creationTime=\"2"..., 608) = 608
Process 15984 detached
[pid 15985] +++ killed by SIGSEGV +++
PANIC: handle_group_exit: 15985 leader 15984
--------------060701020600040301020602--
Re: Getting started with hyades... [message #7122 is a reply to message #6991] Wed, 23 February 2005 15:21 Go to previous messageGo to next message
Member
Can you crank up the logging level for the log? You can do this by modifying
the "config/serviceconfig.xml" file. Look for the line:
<AgentControllerConfiguration activeConfiguration="default" filePort="10005"
jvm="D:\jdk1.4.1\jre\bin\classic\jvm.dll" loggingDetail="LOW"
loggingLevel="DEBUG" port="10002" processPolling="true" securedPort="10003"
version="3.2.0">
and change the value of the "loggingLevel" attribute to "DEBUG". Remove the
old log and restart RAServer to generate a detailed log. Please post the log
here. Thanks.
BTW, what is the value of the attribute "jvm" in your config file?
Samson
news:cvfqsa$653$1@www.eclipse.org...
> Samson Wai wrote:
> > Hi Brian,
generate
config
> > files.
> and it looked good.
is
available
connection
output
> > of "netstat -a".
> > Samson
product.
> -Brian
> >>Thanks,
> >>Brian
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
....}) = 0
fig.xml", O_RDONLY) = 5
= 0x605000
> close(5) = 0
> close(4) = 0
|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID|CLONE _DETACHED,
O_RDONLY) = 4
> [pid 15984] read(4,
file or directory)
file or directory)
directory)
file or directory)
or directory)
or directory)
directory)
> [pid 15984] read(4,
....}) = 0
> [pid 15984]
directory)
directory)
0x7e58d8}, 8) = 0
0
> [pid 15984]
O_RDONLY) = 4
> [pid 15984] read(4,
exists)
0600) = 4
0x605000
NULL) = 0
8) = 0
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
....}) = 0
8) = 0
....}) = 0
Re: Getting started with hyades... [message #7149 is a reply to message #7122] Wed, 23 February 2005 16:35 Go to previous messageGo to next message
--------------090404070505010406090404
Ok,
the jvm entry in that element is
jvm=/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so. I assume
that the setup script set this since I didn't.
I changed the log level and reran RAServer. The resulting log is
attached. Seems to be having problems just after loading libjvm.so and
resolving JNI_CreateJavaVM.
I'm using Sun's most recent 1.4.2_7 rpm from their web site.
Samson Wai wrote:
> version="3.2.0">
> here. Thanks.
> Samson
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400066968630CFF3F623C4D1A" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="4000" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400067E341702E2666C529410" msg="Parsing plugin file: /home/development/rac/plugins/org.eclipse.hyades.logging.par sers/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400067EFE54AEDFAD649424CD" msg="Started processing Configuration /home/development/rac/plugins/org.eclipse.hyades.logging.par sers/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000683543EED0B65732A4E40" msg="Completed processing Configuration /home/development/rac/plugins/org.eclipse.hyades.logging.par sers/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000683D63011D52E491613A2" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006841921EF77EF25C3FC60" msg="Parsing plugin file: /home/development/rac/plugins/org.eclipse.hyades.perfmon.lin ux/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068498034818030EADC8F5" msg="Started processing Configuration /home/development/rac/plugins/org.eclipse.hyades.perfmon.lin ux/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000685846607E8EF6533C20F" msg="Completed processing Configuration /home/development/rac/plugins/org.eclipse.hyades.perfmon.lin ux/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000685F73505BF18513BDFDC" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006863448CDC8FE28D7C6D2" msg="Parsing plugin file: /home/development/rac/plugins/org.eclipse.hyades.perfmon.jmx agent/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006868D4D5227CB36FF7006" msg="Started processing Configuration /home/development/rac/plugins/org.eclipse.hyades.perfmon.jmx agent/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000688DD344CC7EE34E96CA8" msg="Completed processing Configuration /home/development/rac/plugins/org.eclipse.hyades.perfmon.jmx agent/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000689650C0578CB400776EC" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000689A55C5C5D8315DD164B" msg="Parsing plugin file: /home/development/rac/plugins/org.eclipse.hyades.datacollect ion/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000689FD0788311B3BF96996" msg="Started processing Configuration /home/development/rac/plugins/org.eclipse.hyades.datacollect ion/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068B045F8785426445D706" msg="Completed processing Configuration /home/development/rac/plugins/org.eclipse.hyades.datacollect ion/config/pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068B7D4FF565364112D907" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068BBA5B3B256154AE062D" msg="Parsing plugin file: /home/development/rac/plugins/org.eclipse.hyades.test/config /pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068C2B48E86C4D3780B347" msg="Started processing Configuration /home/development/rac/plugins/org.eclipse.hyades.test/config /pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068E5E2AA6B2DD32AB503E" msg="Completed processing Configuration /home/development/rac/plugins/org.eclipse.hyades.test/config /pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068ED668C8DFAC4F054B0B" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068F1C01A1C4AB06047F93" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400068FAE1373EE3A430EF002" msg="Successfully set LD_LIBRARY_PATH = /home/development/rac/lib:/home/development/rac/lib:/home/de velopment/java/jre/lib/i386:/home/development/java/jre/lib/i 386/client:/home/development/java/jre/lib/i386/server: " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000690287222680605A8D6C0" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000690713DD0261F557381BE" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000690BC4E7B27E7621C768F" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006910D1848F68016A2073D" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006916379D4D9932D7AE995" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000691BD31814B6549E1F514" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000692347A47604E49E88F70" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006929C64E0C5BC1DC86C37" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006930C3DB5BA2D39DD41A0" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB01400069384281531771F065B67" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar:/home/developmen t/rac/lib/hlcbe101.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006941D2744C80953BE2C00" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar:/home/developmen t/rac/lib/hlcbe101.jar:/home/development/rac/lib/ecore.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000694A75759FBD05AB70D38" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar:/home/developmen t/rac/lib/hlcbe101.jar:/home/development/rac/lib/ecore.jar:/ home/development/rac/lib/common.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000695396409628F316272E0" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar:/home/developmen t/rac/lib/hlcbe101.jar:/home/development/rac/lib/ecore.jar:/ home/development/rac/lib/common.jar:/home/development/rac/pl ugins/org.eclipse.hyades.perfmon.jmxagent/lib/jmxagent.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000695E84C718BAC5C054CBE" msg="Successfully set CLASSPATH = :/home/development/rac/lib/commons-logging.jar:/home/develop ment/rac/lib/hcframe.jar:/home/development/rac/lib/hexcore.j ar:/home/development/rac/lib/hexl.jar:/home/development/rac/ lib/hexr.jar:/home/development/rac/lib/hl14.jar:/home/develo pment/rac/lib/hlcommons.jar:/home/development/rac/lib/hlcore .jar:/home/development/rac/lib/hlevents.jar:/home/developmen t/rac/lib/hlcbe101.jar:/home/development/rac/lib/ecore.jar:/ home/development/rac/lib/common.jar:/home/development/rac/pl ugins/org.eclipse.hyades.perfmon.jmxagent/lib/jmxagent.jar:/ home/development/rac/plugins/org.eclipse.hyades.test/lib/jun it.jar " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000696A921816E7573FDE0BF" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB014000696DC2BD87E1D1FF5EAD4" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006A5D750B4C1C72F2675AA" msg="Loaded JVM library /usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so" severity="5" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="4000" subComponent="framework/RAServer/java.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006A68C5CF8E9023C090E08" msg="Resolved entrypoint for JNI_CreateJavaVM" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006C17A5895CC5F0DDD522B" msg="Recieving signal 11" severity="5" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="4000" subComponent="framework/RAServer/RAServer.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-23T16:32:20.000000Z" globalInstanceId="k21CB0140006C1FA4D23E5C94DD05726" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="4000" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
--------------090404070505010406090404--
Re: Getting started with hyades... [message #7221 is a reply to message #7149] Thu, 24 February 2005 19:13 Go to previous messageGo to next message
Well, I noticed that there are two versions of libjvm.so in 1.4.2_07. I
changed the jvm entry to
'/usr/java/j2sdk1.4.2_07/jre/lib/i386/client/libjvm.so' and it started
working! I'm unclear as to the difference between the client and server
java versions.
Brian Anderson wrote:
> Ok,
> Samson Wai wrote:
>> Hi,
>> modifying
>> filePort="10005"
>> securedPort="10003"
>> version="3.2.0">
>> Remove the
>> the log
>> here. Thanks.
>> Samson
Re: Getting started with hyades... [message #8194 is a reply to message #7221] Thu, 03 March 2005 20:48 Go to previous messageGo to next message
Member
There is no requirement on which libjvm.so (client or server) to use. But
the important point is that whatever is specified in the serviceconfig.xml
should match the environment variable LD_LIBRARY_PATH. For example, if the
config file is pointing to the "client" libjvm.so, then the LD_LIBRARY_PATH
env should point to the "/usr/java/j2sdk1.4.2_07/jre/lib/i386/client" path.
This is because RAServer will try to do a dlopen() on the libjvm.so
specified in the config file using the FQ path name. If the LD_LIBRARY_PATH
is pointing to another libjvm.so, we will get a dlsym() error when trying to
resolve symbols in the library and crash.
Samson
news:cvl91k$45q$1@www.eclipse.org...
> java versions.
> > Ok,
> > Samson Wai wrote:
> >> Hi,
> >> modifying
> >> filePort="10005"
> >> securedPort="10003"
> >> version="3.2.0">
> >> Remove the
> >> the log
> >> here. Thanks.
> >> Samson
Re: Getting started with hyades... [message #8225 is a reply to message #8194] Thu, 03 March 2005 23:59 Go to previous message
Originally posted by: bike_head.hotmail.com
Hmm, I see. My mistake was that I noticed two libjvm.so in the java SDK
from sun, so I put both on the path. The client variant is the first on
the LD_LIBRARY_PATH so it gets picked up first. I should change the
LD_LIBRARY_PATH to only have one of them and the config entry should match.
> Samson
>>java versions.
>>>Ok,
>>>Samson Wai wrote:
>>>>Hi,
>>>>modifying
>>>>filePort="10005"
>>>>securedPort="10003"
>>>>version="3.2.0">
>>>>Remove the
>>>>the log
>>>>here. Thanks.
>>>>Samson
Previous Topic:GLA RT
Next Topic:New, improved TPTP website
Current Time: Thu Jan 02 13:44:30 GMT 2025
Powered by FUDForum. Page generated in 0.08579 seconds
