unable to generate .execution file from .testsuite [message #71128] |
Wed, 17 May 2006 12:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: peter.boldizs.siemens.com
Greetings!
I have started working with TPTP JUnit test cases. I have written a simple
tester class and then generated a TPTP JUnit test. I have generated test
method and filled them with meaningful tests (assertEquals(...)).
I was able to run the "normal" JUnit test(Eclipse's own built-in JUnit
utility) successfully. When I tried to run the generated .testsuite file
(as TPTP "Test"), it was supposed to generate some .execution file. This
was unfortunately not successful. Two processes ("Launching" and
"Executing tests") are started but they are stuck and nothing happens.
I have found the following entry in the Eclipse workspace log:
!ENTRY org.eclipse.hyades.test.core 1 0 2006-05-17 14:46:16.24
!MESSAGE
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
!STACK 0
at
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:417)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2058)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1856)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:692)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
I would appreciate any help.
Thanks.
Peter Boldizs
Re: unable to generate .execution file from .testsuite [message #71807 is a reply to message #71348] |
Fri, 26 May 2006 09:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello!
I am using Eclipse 3.1.0 and TPTP 4.1.0.
It did not occur to me that I have to run the Agent Controller for TPTP
JUnit tests (isn't it only for profiling/logging?). The screencast I have
seen (TPTP/Documentation/TPTP 4.0.0 Introductory Screencasts/JUnit
Integration)never mentioned that the Agent Controller must be run.
Peter
FUDForum. Page generated in 0.03645 seconds
