annotations of schema returning null [message #70928] |
Wed, 13 December 2006 08:02  |
Originally posted by: mgonzalez.ibit.org
I have a valid Schema and the following code:
List anotacions = xsdSchema.getAnnotations();
log.info("anotacions" + anotacions.size());
for(Iterator iter= anotacions.iterator() ; iter.hasNext();){
XSDAnnotation anotacio = (XSDAnnotation)iter.next();
log.info("Info aplicació " + anotacio);
I have 2 annotations and the "anotacions" + anotacions.size()); prints me
the number 2. Till here
But this log.info("Info aplicació " + anotacio); prints me
(element: [xs:annotation: null]) (applicationInformation: [[xs:appinfo:
null], [xs:appinfo: null]],
userInformation: [[xs:documentation: null] ...)
Why prints me null when the annotation is like this
<xs:annotation>
<xs:appinfo>Instancia</xs:appinfo>
<xs:appinfo>Instancia 2 </xs:appinfo>
<xs:documentation xml:lang="ca">Esquema de la
Instancia</xs:documentation>
</xs:annotation>
thanks a lot.
Re: annotations of schema returning null [message #71308 is a reply to message #71066] |
Mon, 15 January 2007 13:32  |
--------------070302030406030509040906
Marilen,
You must use standard DOM APIs to access the children of the appinfo DOM
Element. This code from the XSDEcoreBuilder might help get you started
because it does something similar:
protected void setAnnotations(EModelElement eModelElement,
XSDConcreteComponent xsdComponent)
List<XSDAnnotation> xsdAnnotations = new ArrayList<XSDAnnotation>();
List<Element> elements = new ArrayList<Element>();
boolean append = true;
if (xsdComponent instanceof XSDParticle)
xsdComponent = ((XSDParticle)xsdComponent).getContent();
if (xsdComponent != null)
elements.add(xsdComponent.getElement());
if (xsdComponent instanceof XSDAttributeDeclaration)
xsdAnnotations.add(((XSDAttributeDeclaration)xsdComponent).g etAnnotation());
else if (xsdComponent instanceof XSDAttributeUse)
XSDAttributeUse xsdAttributeUse = (XSDAttributeUse)xsdComponent;
xsdAnnotations.add(xsdAttributeUse.getContent().getAnnotatio n());
XSDAttributeDeclaration xsdAttributeDeclaration =
xsdAttributeUse.getAttributeDeclaration();
xsdAnnotations.add(xsdAttributeDeclaration.getAnnotation());
elements.add(xsdAttributeDeclaration.getElement());
append = false;
else if (xsdComponent instanceof XSDElementDeclaration)
XSDElementDeclaration xsdElementDeclaration =
(XSDElementDeclaration)xsdComponent;
xsdAnnotations.add(xsdElementDeclaration.getAnnotation());
if (xsdElementDeclaration.isElementDeclarationReference())
XSDElementDeclaration resolvedElementDeclaration =
xsdElementDeclaration.getResolvedElementDeclaration();
xsdAnnotations.add(resolvedElementDeclaration.getAnnotation( ));
elements.add(resolvedElementDeclaration.getElement());
append = false;
else if (xsdComponent instanceof XSDAttributeGroupDefinition)
xsdAnnotations.add(((XSDAttributeGroupDefinition)xsdComponen t).getAnnotation());
else if (xsdComponent instanceof XSDFacet)
xsdAnnotations.add(((XSDFacet)xsdComponent).getAnnotation()) ;
else if (xsdComponent instanceof XSDIdentityConstraintDefinition)
xsdAnnotations.add(((XSDIdentityConstraintDefinition)xsdComp onent).getAnnotation());
else if (xsdComponent instanceof XSDModelGroup)
xsdAnnotations.add(((XSDModelGroup)xsdComponent).getAnnotati on());
else if (xsdComponent instanceof XSDModelGroupDefinition)
xsdAnnotations.add(((XSDModelGroupDefinition)xsdComponent).g etAnnotation());
else if (xsdComponent instanceof XSDSchema)
xsdAnnotations.addAll(((XSDSchema)xsdComponent).getAnnotatio ns());
else if (xsdComponent instanceof XSDTypeDefinition)
xsdAnnotations.addAll(((XSDTypeDefinition)xsdComponent).getA nnotations());
else if (xsdComponent instanceof XSDWildcard)
xsdAnnotations.add(((XSDWildcard)xsdComponent).getAnnotation ());
boolean first = true;
for (XSDAnnotation xsdAnnotation : xsdAnnotations)
if (xsdAnnotation != null &&
!"true".equals(getEcoreAttribute(xsdAnnotation, "ignore")))
for (Element element : xsdAnnotation.getUserInformation())
if (!"true".equals(getEcoreAttribute(element, "ignore"))
&& !ignore(element))
ByteArrayOutputStream byteArrayOutputStream = new
ByteArrayOutputStream();
XSDResourceImpl.serialize(byteArrayOutputStream,
element, "UTF-8");
try
String documentation =
byteArrayOutputStream.toString("UTF8");
int start = documentation.indexOf("?>");
start = documentation.indexOf(">", start + 2);
int end = documentation.lastIndexOf("</");
String documentationBody = end == -1 ? null :
documentation.substring(start + 1, end);
String existingDocumentation =
EcoreUtil.getDocumentation(eModelElement);
if (existingDocumentation != null)
if (!first && !append)
continue;
documentationBody = existingDocumentation +
System.getProperty("line.separator") + documentationBody;
EcoreUtil.setDocumentation(eModelElement,
documentationBody);
catch (UnsupportedEncodingException exception)
throw new WrappedException(exception);
xsdAnnotation.getApplicationInformation())
String sourceURI = element.hasAttributeNS(null,
"source") ? element.getAttributeNS(null, "source") : null;
element, "UTF-8");
try
String applicationInformation =
int start = applicationInformation.indexOf("?>");
start = applicationInformation.indexOf(">", start + 2);
int end = applicationInformation.lastIndexOf("</");
String applicationInformationBody = end == -1 ? null :
applicationInformation.substring(start + 1, end);
String key = getEcoreAttribute(element, "key");
if (key == null)
key = "appinfo";
EAnnotation eAnnotation =
eModelElement.getEAnnotation(sourceURI);
String existingApplicationInformation =
eAnnotation == null ?
null :
(String)eAnnotation.getDetails().get(key);
if (existingApplicationInformation != null)
continue;
existingApplicationInformation +
System.getProperty("line.separator") + applicationInformationBody;
if (eAnnotation == null)
eAnnotation =
EcoreFactory.eINSTANCE.createEAnnotation();
eAnnotation.setSource(sourceURI);
eModelElement.getEAnnotations().add(eAnnotation);
eAnnotation.getDetails().put(key,
applicationInformationBody);
first = false;
first = true;
for (Element element : elements)
if (element != null)
NamedNodeMap attributes = element.getAttributes();
for (int j = 0, length = attributes.getLength(); j < length;
++j)
Attr attribute = (Attr)attributes.item(j);
if (!ignore(attribute))
String sourceURI = attribute.getNamespaceURI();
eAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
if (first || append ||
eAnnotation.getDetails().get(attribute.getLocalName()) == null)
eAnnotation.getDetails().put(attribute.getLocalName(),
attribute.getValue());
first = false;
Marilen wrote:
> Hello Ed, my idea is to get the text inside the annotation
> Example, if I have this annotation
> <xs:annotation>
> </xs:annotation>
> How can I get the text "Instancia" and "Instancia 2"?
> I have tried with
> List appInfo = anotacio.getApplicationInformation();
> log.info(" appInfo" + appInfo.get(0));
> and I get this print:
> appInfo[xs:appinfo: null]
> It is possible to get the text inside <xs:appinfo>??
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Marilen,<br>
<br>
DOM Element.
Re: annotations of schema returning null [message #599258 is a reply to message #70928] |
Wed, 13 December 2006 08:13  |
Marilen,
I'm not sure what you are expecting from the toString representation of
an XSDAnnotation but it's simply showing the toString presentation of
the DOM element. Use the XSDAnnotation's APIs to access the data and
I'm sure you'll find everything you need is there.
> me the number 2. Till here
> [[xs:appinfo: null], [xs:appinfo: null]],
> <xs:annotation>
> </xs:annotation>
> thanks a lot.
Re: annotations of schema returning null [message #599314 is a reply to message #70947] |
Wed, 03 January 2007 07:08  |
<xs:annotation>
</xs:annotation>
I have tried with
Thank you.
Re: annotations of schema returning null [message #599326 is a reply to message #70947] |
Wed, 03 January 2007 07:12  |
<xs:annotation>
</xs:annotation>
I have tried with
Re: annotations of schema returning null [message #599448 is a reply to message #71066] |
Marilen,
append = false;
append = false;
element, "UTF-8");
try
continue;
documentationBody);
element, "UTF-8");
try
if (key == null)
key = "appinfo";
null :
continue;
eAnnotation =
first = false;
first = true;
++j)
first = false;
> <xs:annotation>
> </xs:annotation>
> I have tried with
<html>
<head>
<title></title>
</head>
Marilen,<br>
<br>
DOM Element.
FUDForum. Page generated in 0.04263 seconds
