Home » Eclipse Projects » Eclipse Platform » How to programatically select an Item in a TreeViewer
How to programatically select an Item in a TreeViewer [message #69215] |
Tue, 10 June 2003 13:34 |
Originally posted by: bodo.t.genion.de
if i have a element Object which corresponds to an TreeViewers TreeItem.
How do I set selection on the Tree of the TreeViewer ?
The 2nd step i have already made: getTree() from the treeviewer and call
setSelection() on it. that was the easy part.
but the problem is, how to find the TreeItem i want to be selected if i
just have the element Object (from my Model ) ?
I tried with findItem(Object element) of the TreeViewer but 1st this
is a protected method , so i have to subclass TreeViewer and 2nd this
method simply does not work, because TreeViewer seems not to use its
internal elementMap.
so do i need to write my own version of findItem() in a subclassed
TreeViewer or did i overlooked something, which would be more easy to do?
Bodo
Re: How to programatically select an Item in a TreeViewer [message #69439 is a reply to message #69215] |
Tue, 10 June 2003 14:23 |
found a partial solution, see below , but now i have the next problem:
if i call
treeviewer.getTree().setSelection(tis);
on a TreeViewer neither the previous registered
selectionChanedListerner of TreeViewer nor the previous
registered selctionListerner of the Tree is called.
i this a Bug or a Feature and how can i force to call the listeners ?
bodo
i found, that i need to call setUseHashlookup(true) on the TreeViewer
first.
> Bodo
Re: How to programatically select an Item in a TreeViewer [message #69541 is a reply to message #69215] |
Tue, 10 June 2003 15:48 |
Originally posted by: lynne_kues.oti.com
You should use the setSelection API defined for the viewer. This will fire
the selection changed event. See:
StructuredViewer>>public void setSelection(ISelection selection, boolean
reveal)
"bodo" <bodo.t@genion.de> wrote in message
news:3EE5DE57.2060303@genion.de...
> Bodo
Re: How to programatically select an Item in a TreeViewer [message #70484 is a reply to message #69541] |
Wed, 11 June 2003 07:01 |
yes , this also was my first thought , but then i did not understand
what the Interface "ISelection" is good for and how to use it. do my
tree-model elements need to implement this?
the point is that my model is a jdom tree, the jdom.Elemenst correspond
to the TreeItems, so if i want a certain jdom-Element to be selcted i
obviousely can not call setSelection(jdom.Element_obj, boolean reveal)
since my the jdom.Elements do not implement ISelection.
hm , i'm confused....
bodo
> reveal)
>>Bodo
Re: How to programatically select an Item in a TreeViewer [message #70502 is a reply to message #70484] |
Wed, 11 June 2003 07:02 |
Most JFace viewers (including TreeViewer) use IStructuredSelection,
and there is StructuredSelection, which implements this interface.
SY, Konstantin.
Re: How to programatically select an Item in a TreeViewer [message #70580 is a reply to message #70502] |
Wed, 11 June 2003 08:34 |
Originally posted by: lauri.pesonen.iki.fi
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> writes:
And in Bodo's case the code snippet would be:
IStructuredSelection sel = new StructuredSelection(jdom.Element_obj);
tree.setSelection(sel, true);
The important part is that the object given to StructuredSelection must be
equal() to one of the items of the tree for a selection to be shown in the
tree. I.e. either you must use the same objects to create the
StructuredSelection that are in the tree (selectedObj == treeItem) or the
item must implement equals (selectedObj.equals(treeItem)).
> SY, Konstantin.
Lauri
Re: How to programatically select an Item in a TreeViewer [message #70664 is a reply to message #70580] |
Wed, 11 June 2003 11:59 |
it works! thank you Lauri!
the doc is not very exhausive in this regard, nor are the examples, are
they ? and diggin in the eclipse source is somehow painfull.
bodo
>>SY, Konstantin.
Current Time: Sun Oct 06 14:33:12 GMT 2024
Powered by FUDForum. Page generated in 0.04522 seconds
