Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #735976 is a reply to message #725253] |
Thu, 13 October 2011 09:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andreas Schilling![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=andreas_schilling%40gmx.net) Messages: 25 Registered: April 2010 |
I'm also having probably the same problem.
On our Buildserver (Jenkins) everything is fine, however if I want to do a local build from Eclipse (run the respective action that is defined in the CSPEX and that is also used on the buildserver) I get this error for at least one bundle (actually only one error is logged but when using more fine grained logging I see it on several bundles happen).
having a look at the dependency graph shows, that it seems like all *.source bundles of third party libraries are missing, e.g. com.springsource.javax.validation.source
the message then is
No component named com.springsource.javax.validation.source:osgi.bundle$0.0.0#Raw Omni Version is known to Buckminster
I don't really understand why that happens. first I thought that buckminster somehow does not use our target platform (which contains the bundle) when doing the local build but then again it should show ALL bundles to be unresolved and not only the source bundles (or shouldn't it?).
Btw, the manifest of that specific bundle seems to be not 100% correct to me, however for other bundles that also can't be resolved I can see problems on the first glance, so it might have something to do with it or not...
while in theory everything is fine as long as the Jenkins build does not fail I still would like to be able to work with buckminster on my development machine as well ![Razz](images/smiley_icons/icon_razz.gif)
also, I can't tell you why and when things stopped working locally, because some 1 1/2 years ago when we were setting up the buckminster process everything worked from Eclipse as well.
regards,
Andreas
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #735987 is a reply to message #735976] |
Thu, 13 October 2011 09:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
What version of Buckminster are you running? There's been a recent fix for missing source bundles.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=357060
- thomas
> the message then is
> buckminster on my development machine as well :p
> regards,
> Andreas
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #1551499 is a reply to message #701753] |
Wed, 07 January 2015 17:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am gettng this weird error and not able to see why this org.eclipse.emf.ecoretools.design:eclipse.feature is not getting resolved when i have this in my rmap {http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary}
Buildfile: /home/chakraborty/workspace/temp/maps.releng/build.ant
[delete] Deleting: /home/chakraborty/workspace/temp/maps.releng/some.tmp.file
common.cleanup:
install.buckminster.headless:
install.buckminster.headless.internal:
buckminster:
[echo] IMPORTANT: Populating an empty target platform may took over 10 minutes.
[echo] build.properties: /home/chakraborty/workspace/temp/maps.releng/build.properties
[java] INFO: setpref 'targetPlatformPath=/home/chakraborty/workspace/temp/buildroot/target.platform'
[java] INFO: resolve '/home/chakraborty/workspace/temp/maps.releng/build.cquery'
[java] ERROR [0002] : No suitable provider for component org.eclipse.emf.ecoretools.design:eclipse.feature was found in resourceMap file:/home/chakraborty/workspace/temp/maps.releng/build.rmap
[java] ERROR [0002] : No suitable provider for component org.eclipse.emf.ecoretools.design:eclipse.feature was found in searchPath eclipse
[java] ERROR [0002] : Rejecting provider p2({0}[http://download.eclipse.org/releases/juno]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary[http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/mdt/ocl/updates/releases/?importType=binary[http://download.eclipse.org/modeling/mdt/ocl/updates/releases/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://update.toem.de/?importType=binary[http://update.toem.de/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/birt/update-site/4.3/?importType=binary[http://download.eclipse.org/birt/update-site/4.3/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2({0}[http://download.eclipse.org/tools/cdt/releases/8.5]): No component match was found
[java] WARNING [0018] : Component request org.apache.commons.codec:osgi.bundle/[1.3.0.v201101211617,1.3.0.v201101211617] is in conflict with request org.apache.commons.codec:osgi.bundle/[1.4.0.v201209201156,1.4.0.v201209201156]
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
[java] WARNING [0040] : Component request org.apache.commons.logging:osgi.bundle/[1.1.1.v201101211721,1.1.1.v201101211721] is in conflict with request org.apache.commons.logging:osgi.bundle/[1.0.4.v201101211617,1.0.4.v201101211617]
[java] WARNING [0085] : Component request org.junit.source:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit.source:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.8.1
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.7.0
[java] WARNING [0014] : Component request org.w3c.dom.smil:osgi.bundle/[1.0.0.v200806040011,1.0.0.v200806040011] is in conflict with request org.w3c.dom.smil:osgi.bundle/[1.0.1.v200903091627,1.0.1.v200903091627]
[java] INFO: TAG-ID 0002 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0
[java] TAG-ID 0014 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.e4.rcp:eclipse.feature$1.1.2.v20130130-191718-91FUvGP7GIX2Kgz-z-gvjMvXV1NS
[java] TAG-ID 0018 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.net4j:eclipse.feature$4.1.2.v20121028-0914
[java] TAG-ID 0036 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.jdt:eclipse.feature$3.8.2.v20130116-090414-8-8nFu3FNOfwKLRuqgXKIy9z0I83
[java] TAG-ID 0040 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.net4j.util:eclipse.feature$4.1.2.v20121028-0914
[java] TAG-ID 0085 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.sdk:eclipse.feature$4.2.2.v20130116-114742-7T7oDVDQ23Iosz-vkFwNncmx7z-9Rts4b0m1FotkYacO5 -> org.eclipse.jdt.source:eclipse.feature$3.8.2.v20130116-090414-8-8nFu3FNOfwKLRuqgXKIy9z0I83
Abhishek Chakraborty
FUDForum. Page generated in 0.06483 seconds
