Home » Eclipse Projects » Mylyn » When does the auto-sync run
When does the auto-sync run [message #69818] Fri, 26 June 2009 15:10 Go to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
When does the auto-sync run? Is it at a specific time?
Re: When does the auto-sync run [message #69838 is a reply to message #69818] Fri, 26 June 2009 18:40 Go to previous messageGo to next message
It runs every 20 minutes by default.
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: When does the auto-sync run [message #69857 is a reply to message #69838] Sat, 27 June 2009 20:33 Go to previous messageGo to next message
On 2009-06-26 18:40:59 -0400, Steffen Pingel <steffen.pingel@tasktop.com> said:
A co-worker expressed concern about a corporate setting where a lot of
developers might all start Eclipse and nail the server at the same
time. I know it synchs on startup, does it start the "20 minutes" at
the point that the first one stops? That would at least build a little
variation into everyone's clocks so that every 20 minutes the server
does not get nailed again. Likewise, have you considered adding a
small amount of fudge to the interval? Like some smallish random
interval added to the 20 minutes.
Finally, can a repository provider specify a minimum interval? So that
someone cannot specify something like 1 minute as their interval?
Mark
Re: When does the auto-sync run [message #69916 is a reply to message #69857] Mon, 29 June 2009 13:40 Go to previous messageGo to next message
Those are good points Mark. Can you file a bug so we can track that and
discuss optimizing the current strategy?
Steffen
Steffen Pingel
Re: When does the auto-sync run [message #69937 is a reply to message #69916] Mon, 29 June 2009 13:49 Go to previous messageGo to next message
Cool -- please post the bug number here :) I see a noticeable surge at
10:30ET and 2:30ET where many search queries run for minutes on end.
Most days they all get killed for taking too long, yet no one seems to
complain.. so I can't help but feel the compute power is simply going to
waste.
Re: When does the auto-sync run [message #69956 is a reply to message #69937] Mon, 29 June 2009 15:25 Go to previous message
On 2009-06-29 13:49:55 -0400, "Eclipse Webmaster (Denis Roy)"
> to waste.
I filed bug 281894
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281894
Mark
Re: When does the auto-sync run [message #597919 is a reply to message #69818] Fri, 26 June 2009 18:40 Go to previous message
Steffen
Steffen Pingel
Re: When does the auto-sync run [message #597923 is a reply to message #69838] Sat, 27 June 2009 20:33 Go to previous message
Mark
Re: When does the auto-sync run [message #597937 is a reply to message #69857] Mon, 29 June 2009 13:40 Go to previous message
Steffen
Steffen Pingel
Re: When does the auto-sync run [message #597940 is a reply to message #69916] Mon, 29 June 2009 13:49 Go to previous message
waste.
Re: When does the auto-sync run [message #597946 is a reply to message #69937] Mon, 29 June 2009 15:25 Go to previous message
> to waste.
I filed bug 281894
Mark
Previous Topic:Mylyn 3.2 is now available
Next Topic:Hotmail IMAP Connector
Current Time: Sun Apr 27 11:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.03506 seconds
