Home » Language IDEs » C / C++ IDE (CDT) » How to add existing Visual C++ 6.0 to CDT?
How to add existing Visual C++ 6.0 to CDT? [message #69164] Thu, 08 May 2003 04:55 Go to next message
Originally posted by: markus.rakowski.nospam-gmx.net
Hi, I installed Eclipse 2.1 and the CDT. However, CDT does not recognize
an existing installation of Visual C++ 6.0.
How to add an existing Visual C++ 6.0 installation to CDT in order to be
able to compile/debug/run?
Thanking you
Markus
Re: How to add existing Visual C++ 6.0 to CDT? [message #69186 is a reply to message #69164] Thu, 08 May 2003 06:15 Go to previous messageGo to next message
Originally posted by: dkel.unknown.com
First you need to ensure that VC++ is in your path when you start eclipse.
vcvars32.bat contains
the relevant information if you don't have it already on your path.
You also need to have a make program. I didn't use microsofts nmake program,
I used a unix make
equivalent, and put it on my path, making it easier to use the default make
system of CDT, plus I
am developing cross platform applications, I believe mingw provides a make
program, you could also
search the web or sourceforge. You can extract the make file from VC++
projects, but they may only work with nmake.
To debug, I register msdev.exe as an external tool, once my executable is
built it appears in the project tree
I highlight it and use the external tool to launch msdev with that
executable, I can then debug it.
It isn't as integrated as gcc and gdb, but as I have to use MS compilers on
windows, this still works very
well for me, it's just you have to leave the IDE to debug. I haven't tried
gdb to see if it can debug microsoft compiled code.
Dave
"Markus Rakowski" <markus.rakowski@nospam-gmx.net> wrote in message
news:b9d626$gpn$3@rogue.oti.com...
> Thanking you
> Markus
Can I use MFC in CDT? [message #69441 is a reply to message #69186] Fri, 09 May 2003 05:10 Go to previous messageGo to next message
Originally posted by: billhao.hotmail.com
Re: How to add existing Visual C++ 6.0 to CDT? [message #69645 is a reply to message #69164] Fri, 09 May 2003 13:08 Go to previous messageGo to next message
Just tried Microsoft NMAKE on my make file and it works ok, so I didn't need
another make file utility
I just replaced the default build command with NMAKE and that was all that
was needed.
Now you should be able to extract make files from the VC++ IDE, or write
your own.
Dave
> Thanking you
> Markus
Re: Can I use MFC in CDT? [message #69665 is a reply to message #69441] Fri, 09 May 2003 13:10 Go to previous message
If you hand craft the MFC object use and MFC macro calls, then you can use
MFC in eclipse. It may be quite hard to do without the VC++ wizards to start
you off or the GUI layout tool, unless you build the App
first in VC++ then complete it in CDT.
Dave
"bill" <billhao@hotmail.com> wrote in message
news:b9frai$bkj$1@rogue.oti.com...
Previous Topic:executing binaries under Linux
Next Topic:Building a C++ project
Current Time: Fri Oct 17 15:51:49 EDT 2025
Powered by FUDForum. Page generated in 0.05087 seconds
