Home » Eclipse Projects » GEF » How to provide visual feedback in a policy?
How to provide visual feedback in a policy? [message #67352] |
Fri, 28 February 2003 14:06 |
Originally posted by: Raymond_Tsui.ca.ibm.co
I am a relatively new GEF user and I am trying to write some code to provide
visual feedback on the screen as the mouse passes over objects.
What I woud like to do is draw a plus sign as the mouse passes in between
IFigures. I want to understand how to temporarily draw a arbitrary shape.
What is the correct method for accessing the screen?
At the ShowTargetFeedback method in the editpolicy, I don't see any way to
paint onto the screen.
Ray
Re: How to provide visual feedback in a policy? [message #67408 is a reply to message #67352] |
Fri, 28 February 2003 15:35 |
"Ray Tsui" <Raymond_Tsui@ca.ibm.co> wrote in message
news:b3nok7$cal$1@rogue.oti.com...
provide
If you are between two figures, then you are over the diagram, or "contents"
EditPart. The SelectionTool will target whatever EditPart is underneath the
mouse. You could add an EditPolicy to the diagram EditPart that responds to
showFeedback(Request), where request.equals(RequestContsants.REQ_SELECTION),
and in that method you can create another figures and do an
addFeedback(plusFigure).
> Ray
Re: How to provide visual feedback in a policy? [message #67428 is a reply to message #67408] |
Fri, 28 February 2003 16:01 |
Hi again
Would this also apply if I am in the move/create/add state? I want to show
the feedback in the middle of that request.
What is the addFeedback you are referring to? So if I understand you
correctly, the only way to show any sort of feedback is to add a figure to
the enclosing edit part? There is no way to draw to the screen other than
using Figures?
One other question, how do I redirect the targetted Editpart?
You said that the tool will choose whichever editpart it is over. Where I
can override this behavior? For example, if my mouse is on child A of parent
B, when I call getHost, it returns A, but the mouse so close to the edge of
A that I want the host to be B. Can I redirect the host in one of my
editpolicies?
Ray
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b3ntr7$h1q$1@rogue.oti.com...
> provide
"contents"
the
to
between
shape.
to
> > Ray
Re: How to provide visual feedback in a policy? [message #67448 is a reply to message #67428] |
Fri, 28 February 2003 16:26 |
news:b3nvbf$i9u$1@rogue.oti.com...
> Hi again
Sorry, if you are in the middle of move/create/add, this is much more
common. Please try running the logic example and creating a FlowContainer.
Then, add multiple children to this container. You will see the insertion
emphasis which is probably what you are trying to do. This is handled
already by FlowLayoutEditPolicy.
Nope, the feedback is added to the feedback layer, and can paint anywhere,
but yes it is a figure. It is not clipped by the enclosing editpart.
parent
of
> editpolicies?
Once again, look at the logic example. If A is not capable of receiving
children (for example, and LED in the LogicEditor), then it does not return
getHost(). In fact, tt should not have a layout editpolicy, so it will
return NULL sa the target. In this scenario, the targeting tool keeps
drilling down until if finds B, which says that it is the target of
ADD/MOVE/CREATE.
If A and B are potential containers, then you do have to be a little more
creative. What you would want then is the type of targeting that is done in
Windows File Explorer.
Re: How to provide visual feedback in a policy? [message #67490 is a reply to message #67448] |
Fri, 28 February 2003 18:44 |
The funny thing is: I ran the logic designer example and I don't get any
insertion feedback at all, would there be something I need to turn on to see
the insertion line?
news:b3o0qk$jjt$1@rogue.oti.com...
> > Hi again
show
FlowContainer.
to
I
> parent
> of
> > editpolicies?
return
> ADD/MOVE/CREATE.
in
Re: How to provide visual feedback in a policy? [message #67550 is a reply to message #67490] |
Fri, 28 February 2003 19:00 |
Are you using the latest code from Eclipse.org?
There was a bug in Pointlist that caused the insertion line to not appear.
I just fixed it before lunch.
news:b3ob0f$q7q$1@rogue.oti.com...
see
> the insertion line?
> > > Hi again
> show
> FlowContainer.
insertion
figure
> to
anywhere,
Where
> I
> > parent
edge
> > of
> > > editpolicies?
> return
> > ADD/MOVE/CREATE.
more
done
> in
Re: How to provide visual feedback in a policy? [message #67670 is a reply to message #67550] |
Fri, 28 February 2003 22:03 |
thanks, I guess I will have to wait until Monday to get that update.
Ray
news:b3obvo$r8t$1@rogue.oti.com...
> see
> > the insertion line?
> > > > Hi again
to
> > show
> > FlowContainer.
> insertion
> figure
> > to
> anywhere,
> Where
> > I
of
> > > parent
> edge
> > > of
> > > > editpolicies?
receiving
> > return
will
> > > ADD/MOVE/CREATE.
> more
> done
> > in
Re: How to provide visual feedback in a policy? [message #68017 is a reply to message #67550] |
Mon, 03 March 2003 16:41 |
Which build would I pick up to get this fix?
Ray
> see
> > the insertion line?
Current Time: Fri Jul 05 19:36:35 GMT 2024
Powered by FUDForum. Page generated in 0.04356 seconds
