Several questions from a novice. [message #674759] |
Sat, 28 May 2011 10:04 |
I am trying to develop an Eclipse-based editor for a 2d game engine(www.ksatechnologyhq.com:1357). This includes a text editor for its scripting language. I want to be able to index the script files to search through them and display functions from other files. Also, I want someone to join me in making the editor.
[Updated on: Thu, 02 June 2011 06:09] Report message to a moderator
Re: Several questions from a novice. [message #675241 is a reply to message #674759] |
Mon, 30 May 2011 21:32 |
I wouldn't recommend it if you are trying to make an editor that is not for XML files. Instead, create a plugin with no template, open plugin.xml, and on the Extensions tab, click Add..., find the org.eclipse.ui.editors extension point and click Finish. Next, fill out the form that appears to the right, like this.
Check out the examples and Platform Plug-in Developer Guide to see how features are implemented. But seriously, I want some help over here!
[Updated on: Mon, 30 May 2011 21:35] Report message to a moderator
FUDForum. Page generated in 0.03241 seconds
