Home » Language IDEs » AspectJ » the shadow for this join point is not exposed in the structure model?!?
the shadow for this join point is not exposed in the structure model?!? [message #67056] Tue, 26 September 2006 11:47 Go to next message
I am getting tons of yellow warnings in the problem view all reading:
Severity and Description Path Resource Location Creation Time Id
the shadow for this join point is not exposed in the structure model:
method-call(void myPackage.MyClass.someMethod())
[Xlint:shadowNotInStructure] myProcject line 78 1159285096719 9128305
What is AJDT trying to tell me here? Is this an error or a problem?
Should I be concerned? Could some kind soul elaborate a bit what this
message is supposed to mean, please?
Michael
PS.: This is on Eclipse 3.3M2 (20060914) with AJDT 1.5.0 (20060920) - as
usual on the bleeding edge... :-)
Re: the shadow for this join point is not exposed in the structure model?!? [message #67150 is a reply to message #67056] Fri, 06 October 2006 08:50 Go to previous messageGo to next message
Any wisdom on this one - nobody?
Michael
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:efbi21$dgi$1@utils.eclipse.org...
> Michael
> as usual on the bleeding edge... :-)
Re: the shadow for this join point is not exposed in the structure model?!? [message #67187 is a reply to message #67056] Fri, 06 October 2006 12:44 Go to previous messageGo to next message
It suggests it couldn't find the shadow for the method call to
someMethod() when trying to build an advice relationship - so this is
likely to cause a missing icon in the gutter and a missing entry in the
cross references view. But if you run your testcases and your
application works ... don't worry too much about it - however, if you
have the time to create a testcase for us, we will investigate.
Andy.
> Michael
Re: the shadow for this join point is not exposed in the structure model?!? [message #67269 is a reply to message #67187] Tue, 10 October 2006 07:41 Go to previous message
The point of my question was more: what precisely *is* this "shadow for
a method call"? Is that something an aspect writer has to know about or
should be aware of? Does this influence whether a pointcut can be
identified or not (i.e. if the aspect will be applied and woven in or
not)?
I simply don't understand the warning message, i.e. what a "shadow" is
(in this context).
Michael
"Andy Clement" <andrew.clement@gmail.com> wrote in message
news:eg614p$ds9$1@utils.eclipse.org...
> the cross references view. But if you run your testcases and your
> Andy.
>> 9128305
>> Michael
Re: the shadow for this join point is not exposed in the structure model?!? [message #594925 is a reply to message #67056] Fri, 06 October 2006 08:50 Go to previous message
Michael
> Michael
Re: the shadow for this join point is not exposed in the structure model?!? [message #594962 is a reply to message #67056] Fri, 06 October 2006 12:44 Go to previous message
Andy.
> Michael
Re: the shadow for this join point is not exposed in the structure model?!? [message #595040 is a reply to message #67187] Tue, 10 October 2006 07:41 Go to previous message
not)?
(in this context).
Michael
> Andy.
>> 9128305
>> Michael
Previous Topic:advices from aspectPath jars aren't shown in Cross References view
Next Topic:Aspects that affect all or large number of classes
Current Time: Thu Oct 16 07:47:06 EDT 2025
Powered by FUDForum. Page generated in 0.04650 seconds
