Home » Language IDEs » Java Development Tools (JDT) » Eclipse will not start in Windows 7 64-bit
Eclipse will not start in Windows 7 64-bit [message #670565] |
Sun, 15 May 2011 01:24 |
Missing name Mising name Messages: 7 Registered: April 2011 Location: USA |
I recently installed 64-bit Java and now Eclipse will not start up even though I am using the 64-bit Helios package. Does that mean I need to go back to the 32-bit package?
I get this error dialog as below:
Eclipse
Java was started but returned exit code=1
C:\Windows\system32\javaw.exe
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
-XX:MaxPermSize=256m
-jar Z:\Windows Files\Development\eclipse downloads\eclipse-java-helios-win32-x86_64\eclipse\plugins/o rg.eclipse.equinox.launcher_1.1.0.v20100507.jar
-os win32
-ws win32
-arch x86_64
-showsplash
-launcher Z:\Windows Files\Development\eclipse downloads\eclipse-java-helios-win32-x86_64\eclipse\eclipse.e xe
-name Eclipse
--launcher.library Z:\Windows Files\Development\eclipse downloads\eclipse-java-helios-win32-x86_64\eclipse\plugins/o rg.eclipse.equinox.launcher.win32.win32.x86_64_1.1.0.v201005 03\eclipse_1307.dll
-startup Z:\Windows Files\Development\eclipse downloads\eclipse-java-helios-win32-x86_64\eclipse\plugins/o rg.eclipse.equinox.launcher_1.1.0.v20100507.jar
-exitdata a24_6dc
-product org.eclipse.epp.package.java.product
-vm C:\Windows\system32\javaw.exe
-vmargs
-Xms40m
-Xmx384m
OK
[Updated on: Sun, 15 May 2011 01:26] Report message to a moderator
Re: Eclipse will not start in Windows 7 64-bit [message #670615 is a reply to message #670565] |
Sun, 15 May 2011 08:14 |
Sat, 14 May 2011 18:24:36 -0700, /forums-noreply@eclipse.org/:
What do you get running:
java -version
on the command line? On Windows with the 32-bit Java I get:
java version "1.6.0_25"
Java(TM) SE Runtime Environment (build 1.6.0_25-b06)
Java HotSpot(TM) Client VM (build 20.0-b11, mixed mode, sharing)
With the 64-bit Java I get:
Java HotSpot(TM) 64-Bit Server VM (build 20.0-b11, mixed mode)
If you have both the 32-bit and 64-bit JREs installed you may need
to specify the correct one to the Eclipse launcher, e.g.:
eclipse -vm <JAVA_HOME>\bin\javaw.exe
You may also configure that in the corresponding "eclipse.ini" file.
See "Running Eclipse", also:
http://help.eclipse.org/helios/topic/org.eclipse.platform.do c.user/tasks/running_eclipse.htm
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670616 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670617 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670619 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670620 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670621 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670628 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670630 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670633 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670643 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670646 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670648 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670650 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670661 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670685 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670693 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670695 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670701 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670703 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670711 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670717 is a reply to message #670565] |
java -version
Stanimir
Re: Eclipse will not start in Windows 7 64-bit [message #670741 is a reply to message #670565] |
java -version
Stanimir
Current Time: Sat Oct 19 17:20:16 GMT 2024
Powered by FUDForum. Page generated in 0.05082 seconds
