Home » Archived » Buckminster » Doing a jdk5 build with jdk6, best practises?
Doing a jdk5 build with jdk6, best practises? [message #667219] Wed, 27 April 2011 13:58 Go to next message
Thomas Kratz is currently offline Thomas KratzFriend
Hi I'm just getting my head into building with buckminster. I need to build jdk5 compliant (old Mac users...) but due to a strange bug with jdk5 (I could google someone having the same one) buckminster fails to resolve a local resource with jdk5. so I switched buckminster to run on jdk6 and everything builds fine now. But I didn't find any hints on how to make the jdk6 buckminster do a jdk5 compliant build. Can someone give me pointers what would be the best way to do that ? I think I need to perform an install of the jre, but how do I set the compiler options ?
Any help will be appreciated, as always Smile
Regards Thomas
Re: Doing a jdk5 build with jdk6, best practises? [message #667283 is a reply to message #667219] Wed, 27 April 2011 20:58 Go to previous message
Matthias Kappeller is currently offline Matthias KappellerFriend
Member
> Any help will be appreciated, as always :)
> Regards Thomas
Hi Thomas,
you can enable the project specific compiler settings for this project
and set the 'Compiler compliance level' to 1.5 (open Context Menu of
the Project -> Properties -> Java Compiler). Buckminster will then use
these settings as well.
-Matthias
Previous Topic:Possible to generate a maven repository using Buckminster?
Next Topic:Dynamic branchToTag in cquery
Current Time: Wed Feb 05 09:48:53 GMT 2025
Powered by FUDForum. Page generated in 0.02620 seconds
