Home » Eclipse Projects » Remote Application Platform (RAP) » RAP deployment on Weblogic fails
RAP deployment on Weblogic fails [message #657554] |
Thu, 03 March 2011 09:31 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Florent Metral![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=fmetral%40sopragroup.com) Messages: 10 Registered: January 2010 |
Hi all,
Since two days, we are facing issue to deploy a RAP application on Weblogic 10.3. Our EAR is weel deployed on JBoss and WAS 6.1 and 7.
But when we tray to deploy on Weblogic, we get issue ProxyServlet: /eDD_War/rap and we then get a 404 errro.
It seems that the rap servlet is not mapped.
After debugging in RAP framework initialization, here is what we found :
Look at the HttpServiceTracker class (exists twice, once in the equinox and once in the workbench.rap plugin)
In Jboss, both classes are used, in Werblogic, only one in used... why ?
Here is our launch.ini file:
# Eclipse Runtime Configuration Overrides
# These properties are loaded prior to starting the framework and can also be used to override System Properties
# @null is a special value used to override and clear the framework's copy of a System Property prior to starting the framework
# "*" can be used together with @null to clear System Properties that match a prefix name.
osgi.*=@null
org.osgi.*=@null
eclipse.*=@null
The web.xml:
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.2//EN" "http://java.sun.com/j2ee/dtds/web-app_2_2.dtd">
<web-app id="WebApp">
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet </servlet-class>
<!-- the OSGi console is useful for trouble shooting but will fill up your
appserver log quickly, so deactivate on production use -->
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
<!-- Framework Controls could be useful for testing purpose, but
we disable it per default -->
<init-param>
<param-name>enableFrameworkControls</param-name>
<param-value>false</param-value>
</init-param>
<!-- Enable multi-language support for the extension registry -->
<init-param>
<param-value>-registryMultiLanguage</param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
<!-- Security -->
<security-constraint>
<web-resource-collection>
<web-resource-name>EDD access</web-resource-name>
</web-resource-collection>
<auth-constraint>
<role-name>EDDACCESS</role-name>
</auth-constraint>
</security-constraint>
<login-config>
<auth-method>BASIC</auth-method>
<realm-name>eDDRealm</realm-name>
</login-config>
<security-role>
</security-role>
</web-app>
And the config.ini:
#Product Runtime Configuration File
osgi.bundles.defaultStartLevel=4
osgi.bundles=com.ibm.icu.base@start,com.sopra.datadictionary.ui.rcp.application@start,com.sopra.datadictionary.ui.rcp.classeditor@start,com.sopra.datadictionary.ui.rcp.core@start,com.sopra.datadictionary.ui.rcp.dataheadingeditor@start, com.sopra.datadictionary.ui.rcp.dataheadingrepresentationedi tor @start,com.sopra.datadictionary.ui.rcp.dataheadingtypeeditor@start,com.sopra.datadictionary.ui.rcp.dhtreeview@start,com.sopra.datadictionary.ui.rcp.domaineditor@start,com.sopra.datadictionary.ui.rcp.dstreeview@start,com.sopra.datadictionary.ui.rcp.product@start,com.sopra.datadictionary.ui.rcp.viewlogeditor@start,com.sopra.framework.ui.rap@start,org.eclipse.core.commands@start,org.eclipse.core.contenttype@start,org.eclipse.core.databinding@start,org.eclipse.core.databinding.beans@start,org.eclipse.core.databinding.observable@start,org.eclipse.core.databinding.property@start,org.eclipse.core.expressions@start,org.eclipse.core.jobs@start,org.eclipse.core.runtime@start,org.eclipse.equinox.app@start,org.eclipse.equinox.common@start,org.eclipse.equinox.http.registry@start,org.eclipse.equinox.http.servlet@start,org.eclipse.equinox.http.servletbridge@start,org.eclipse.equinox.preferences@start,org.eclipse.equinox.registry@start,org.eclipse.equinox.servletbridge@start,org.eclipse.equinox.servletbridge.extensionbundle,org.eclipse.help@start,org.eclipse.osgi.services@start,org.eclipse.rap.jface@start,org.eclipse.rap.rwt@start,org.eclipse.rap.rwt.q07,org.eclipse.rap.ui@start,org.eclipse.rap.ui.forms@start,org.eclipse.rap.ui.views@start,org.eclipse.rap.ui.workbench@start
This would be very nice for us if some of you had an idea about this.
Thanks in advance
Re: RAP deployment on Weblogic fails [message #657561 is a reply to message #657554] |
Thu, 03 March 2011 09:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Here is the exception stacktrace we get in RAP log file:
!ENTRY org.eclipse.osgi 4 0 2011-03-03 10:47:04.990
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
at org.eclipse.rap.ui.internal.application.ApplicationRegistry. getApplicationExtensions(ApplicationRegistry.java:102)
at org.eclipse.rap.ui.internal.application.ApplicationRegistry. registerApplicationEntryPoints(ApplicationRegistry.java:91)
at org.eclipse.ui.internal.WorkbenchPlugin$3.addingService(Work benchPlugin.java:1109)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAddin g(ServiceTracker.java:979)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAddin g(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTr acked.java:262)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked. java:234)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:940)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceLis tener.serviceChanged(FilteredServiceListener.java:104)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.pu blishServiceEventPrivileged(ServiceRegistry.java:815)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.pu blishServiceEvent(ServiceRegistry.java:772)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistratio nImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.re gisterService(ServiceRegistry.java:215)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:433)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:451)
at org.eclipse.equinox.http.registry.internal.HttpServiceTracke r.open(HttpServiceTracker.java:43)
at org.eclipse.equinox.http.registry.internal.Activator.addingS ervice(Activator.java:59)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractT racked.java:185)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:348)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:283)
at org.eclipse.equinox.http.registry.internal.Activator.start(A ctivator.java:37)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(AccessController .java:251)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:378)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:377)
[Updated on: Thu, 03 March 2011 09:55] Report message to a moderator
Re: RAP deployment on Weblogic fails [message #658196 is a reply to message #657561] |
Mon, 07 March 2011 11:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> The excet error in RAP log files is:
> !ENTRY org.eclipse.osgi 4 0 2011-03-03 10:47:04.990 !MESSAGE An
> unexpected runtime error has occurred. !STACK 0
> getApplicationExtensions(ApplicationRegistry.java:102) at
this error suggests that the "application" entrypoint is not found.
Probably the org.eclipse.core.runtime bundle is not installed. The
exception in your previous post could explain this. At any rate, you
should get access to the OSGi console and print your bundle status using
the "ss" command. Post the output here if you need more help.
Best regards, Ralf
Ralf Sternberg
Twitter: @ralfstx
Current Time: Fri Jul 19 08:12:03 GMT 2024
Powered by FUDForum. Page generated in 0.05185 seconds
