Home » Modeling » GMF (Graphical Modeling Framework) » Customize GMF editors(Scope of xpt templates for generating GMF editors and alternative GMF transformation chains)
Customize GMF editors [message #662808] Fri, 01 April 2011 03:29 Go to next message
LD  is currently offline LD Friend
I am new with GMF templates. I would like help on:
- Do xpt templates for GMF modify generated models (gmfmap, gmftool,gmfgen, gmfgraph) as they customize the generated editor code?
- Is there any reverse transformation chain or generators:
e.g. ATL Flow Generators
e.g. IAML GMF Tools
i.e. .Reverse transformation: gmfgen --> .gmfmap --> ( .gmfgraph + .gmftool + .ecore ) ?
- Is posible to synchronize .gmfgen and .gmfmap with modified source code?
Thanks in advance.
Re: Customize GMF editors [message #662860 is a reply to message #662808] Fri, 01 April 2011 09:28 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael IstriaFriend
> - Do xpt templates for GMF modify generated models (gmfmap, gmftool,gmfgen, gmfgraph) as they http://www.bonitasoft.org/blog/eclipse/customize-your-gmf-ed itor-by-customizing-templates/code?
These templates read your gnfgen files and generate code from there. There are also templates which generates the gmfgen from the 3 other files.
> e.g. http://opensource.urszeidler.de/ATLflow/index.html e.g. http://code.google.com/p/iaml/wiki/GmfTools
AFAIK, this does not exist.
AFAIK, such a feature does not exist, but it would be very powerful!
There are some easier ways to customize GMF using GMF runtime extension points (provider). It is far easier to use than templates, and it is a better design.
HTH
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Eclipse Community Award 2011: Best Modeling Tool
Re: Customize GMF editors [message #662868 is a reply to message #662860] Fri, 01 April 2011 10:04 Go to previous messageGo to next message
Hi Mickael, thank you.
Can you please give more information (e.g. where to find examples and/or documentation or papers) about:
  • The "templates which generates the gmfgen from the 3 other files." ( .gmfmap, gmfgraph, .gmftool )?
  • The GMF customization alternative "using GMF runtime extension points (provider)"?
By the chance the examples are inside Bonita-Studio, can you indicate me in what part concretely if you don´t mind Wink.
Regards.
Re: Customize GMF editors [message #662904 is a reply to message #662868] Fri, 01 April 2011 12:41 Go to previous messageGo to next message
I've never customized such templates. Then I cannot really help you on such topics. I think it would require you to tweak the GmfGen generator, which is some internal GMF Tooling code. Then that's not recommended.
Sure:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. gmf.doc/reference/extension-points/index.html
http://www2.imm.dtu.dk/courses/02162/e08/PDF/seminar-papers/ GMF2P1.pdf
These extension point allow you to override most of GMF runtime "providers" (~= factories). Then you can easily add or remove edit policies, use customized edit parts and so on.
> By the chance the examples are inside Bonita-Studio, can you indicate me in what part concretely if you don´t mind ;).
Here it is:
http://www.bonitasoft.org/websvn/listing.php?repname=Bonita+ Open+Solution&path=%2Fbonita-studio%2Fbranches%2Fbonita- studio-5.4.1%2Fplugins%2Forg.bonitasoft.studio.diagram.custo m%2F#path_bonita-studio_branches_bonita-studio-5.4.1_plugins _org.bonitasoft.studio.diagram.custom_
http://www.bonitasoft.org/websvn/filedetails.php?repname=Bon ita+Open+Solution&path=%2Fbonita-studio%2Fbranches%2Fbon ita-studio-5.4.1%2Fplugins%2Forg.bonitasoft.studio.diagram.c ustom%2Fplugin.xml
HTH
Re: Customize GMF editors [message #662917 is a reply to message #662904] Fri, 01 April 2011 13:29 Go to previous messageGo to next message
Thank you. HTH2
Bonita-studio-5.4.1 y the latest stable version? I saw 5.4.2 in the Web SVN.
Are the providers and the whole project of org.bonitasoft.studio.diagram.custom deloped without code generation mediation?
Do you have public diagrams of plugin dependencies related to the editor and of the editor architecture?
Regards.
Re: Customize GMF editors [message #663196 is a reply to message #662917] Mon, 04 April 2011 09:46 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
do I understand right that you want to modify the genmodel via a transformation? Take a look at this gmf plugin: http://code.google.com/p/gmftools/ . I use a post reconcile qvto transformation to do this. You can choose the transformation to execute on the last page of the genmodel creation wizzard. A post reconcile transformation would look like this:
modeltype GMFGEN uses gmfgen('http://www.eclipse.org/gmf/2009/GenModel');
transformation postRec(inout gmfgenModel : GMFGEN);
property genNavigator : GenNavigator = null;
property genStandardPrefencePage : GenStandardPreferencePage = null;
property genPlugIn : GenPlugin = null;
property genEditorGenerator : GenEditorGenerator = null;
property genDiagram: GenDiagram = null;
main() {
  this.genEditorGenerator := gmfgenModel.objectsOfType(GenEditorGenerator)->asOrderedSet()->first();
  genDiagram := gmfgenModel.objectsOfType(GenDiagram)->asOrderedSet()->first();
  this.genPlugIn := gmfgenModel.objectsOfType(GenPlugin)->asOrderedSet()->first();
  this.genStandardPrefencePage := gmfgenModel.objectsOfType(GenStandardPreferencePage)->asOrderedSet()->first();
  this.genNavigator := gmfgenModel.objectsOfType(GenNavigator)->asOrderedSet()->first();
  --fix BUG 331875
  gmfgenModel.objectsOfType(ExpressionLabelParser)->forEach(parser)
    parser.className := parser.className.concat(parser._uses->first().container().oclAsType(GenNodeLabel).visualID.toString());
This book can be helpful too.
I use custom expand templates to add custom code to the code generation. Here you can find the by gmf used templates org.eclipse.gmf.codegen. Just define a AROUND block for the definitions you want to override. Sometimes it is usefull to override only for some genmodel elements this can be done by using an if statement at the begining in you around block and write in it's else statemen <<targetDef.proceed()>>. So you get only your custom code executed for the elements you want.
Hope this helps you!
Ralph
[Updated on: Mon, 04 April 2011 09:57]
Report message to a moderator
Re: Customize GMF editors [message #663375 is a reply to message #662917] Mon, 04 April 2011 19:47 Go to previous messageGo to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
LD wrote on Fri, 01 April 2011 15:29
5.4.1 is the latest stable release but 5.4.2 will be soon release.
No, we are efffectively using also custom templates. you can find them here:http://www.bonitasoft.org/websvn/listing.php?repname=Bo nita+Open+Solution&path=%2Fbonita-studio%2Fbranches%2Fbo nita-studio-5.4.1%2Fplugins%2Forg.bonitasoft.studio-models%2 F#path_bonita-studio_branches_bonita-studio-5.4.1_plugins_or g.bonitasoft.studio-models_
We are using them when there are no extension points available or if we want to customize a part of code that is generated for a lot of elements.
sorry no. But you can use this http://www.eclipse.org/pde/incubator/dependency-visualizatio n/index.php to hae a quick overview.
Ralph
Are you able to generate the code with this transformation in a headless build?
Why do you choose to use a post-reconcile approcach and don't customize code generation at the generation? Some precise use cases? Easier code to read?
Ralph
yes this is a good starting point for EMF and GMF.
Ralph
effectively using aspect templates is better. You can take a look to this blogpost: http://www.bonitasoft.org/blog/eclipse/customize-your-gmf-ed itor-by-customizing-templates/
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Customize GMF editors [message #663993 is a reply to message #663375] Thu, 07 April 2011 06:35 Go to previous messageGo to next message
Hi. Thank you Mickael, Ralph and Aurelien.
Sure Bonita Studio team is effective, the Award and the quality of the product talk really positive.
Looking to the reference of the templates of bonita studio, I have some questions.
[Templates and Extensions ~Related Q.]
1. Templates in org.bonitasoft.studio-models/GMFTemplates/ are used for customizing this projects:
- (proj1) org.bonitasoft.studio.diagram/ (100% generated)
- org.bonitasoft.studio.diagram.custom/ (100% generated) Are the extensions generated too?
- org.bonitasoft.studio.common.diagram/ (100% generated)
2. Templates in org.bonitasoft.studio-models/form/GMFTemplates/
- (proj2) org.bonitasoft.studio.diagram.form/ (100% generated)
- org.bonitasoft.studio.diagram.form.custom/ (x% generated)
3. Templates are not involved with generating:
- org.bonitasoft.studio.diagram.form.properties/
[Execution of Templates ~Related Q.]
4. I see some of the projects (i.e. proj1, proj2) are automatically generated by means of GMF Diagram Code Generation functionality. And similar with the EMF templates. But do you use any other mechanism to automate the generation such as an ANT script, MWE, particular eclipse LUNCH configurations or something else?
[GMF models manipulation by transformation ~Related Q.]
5. I saw specific customizations of the .gmfgraph, .gmfmap such the required for having intemediate bpmn events in the border of an activity in bonita studio models project. Are this customizations done by hand, or do have scripts to manipulate those models such as the language EOL from Epsilon or the QVTO mentioned by Ralph?
Best Regards.
Re: Customize GMF editors [message #664006 is a reply to message #663993] Thu, 07 April 2011 07:56 Go to previous messageGo to next message
LD wrote on Thu, 07 April 2011 08:35
Thank you Smile
org.bonitasoft.studio.diagram/ is generated
org.bonitasoft.studio.diagram.custom/ nothing is not generated, there are most of the subclass and providers that extends the generated code
g.bonitasoft.studio.common.diagram/ is not generated. We are using some classes in the generated code and also for the other diagram.
- org.bonitasoft.studio.diagram.form.custom/ (0% generated)
no
In development mode, we are using the classic right-click generate code on the model files.
For build process, we are using ant tasks to generate EMF and GMF code. It avoids to have desynchronisation between svn code and generated code.
For border items, I invite you to take a look to this blogpost: http://www.bonitasoft.org/blog/tutorial/how-to-create-and-cu stomize-boundary-items-in-eclipse-gmf/
Re: Customize GMF editors [message #664143 is a reply to message #664006] Thu, 07 April 2011 15:47 Go to previous messageGo to next message
Hi.
See comments belows.
Yes I saw it and it works perfectly, and the correspondance in the SVN. That is why I ask (Q5) if the .gmfgraph and .gmfmap are modified by hand or not.
Regards.
Re: Customize GMF editors [message #664146 is a reply to message #664143] Thu, 07 April 2011 15:54 Go to previous messageGo to next message
LD wrote on Thu, 07 April 2011 17:47
gmfgraph and gmfmap are modified using the graphical interface.
This is part of the graphical model, this is the main way to modelize/customize your GMF diagram.
Re: Customize GMF editors [message #664157 is a reply to message #664146] Thu, 07 April 2011 16:27 Go to previous messageGo to next message
Hi.
Thank you. I actually modify these models with EOL scripts and generate the editors with Eugenia.
I suppose you mean the GMF editor provided for each model. But some times it is ticky so I thougth you could be using a custom approach.
Best Regards.
Re: Customize GMF editors [message #664170 is a reply to message #663375] Thu, 07 April 2011 17:22 Go to previous message
I use this for all changes to the generator model that are done by hand. My usecases are filling in the paths for aspect templates, building up the gen navigator, fixing a bug with expression labels etc. The transformation enables me to delete and generate the generator model without the need to set it up by hand after is was deleted and new created.
Actually I use this. The blog post is very helpful for beginners.
Why do you override addFixedChild and not addBorderItem?
Ralph
[Updated on: Thu, 07 April 2011 17:34]
Previous Topic:NsLock issue
Next Topic:How to customize GMF editors with nodes to have particular behavior
Current Time: Thu Jan 02 19:50:08 GMT 2025
Powered by FUDForum. Page generated in 0.05914 seconds
