Tree control over IPad [message #657775] |
Fri, 04 March 2011 00:47 |
I'm testing an application over the IPad and I found some issues with the tree control, it implements a selection service similar to the one that is in the rms demo http://rap.eclipsesource.com/rapdemo/rms.
The problem is that it is difficult to select a last level node (node without children), it takes several "touch" to select the node, sometimes a touch behaves like a mouse over event and other times like a mouse down.
If the node is from other level I mean if it has children it expands and collapses fine.
Is this a bug? or will it be improved in future versions?
Re: Tree control over IPad [message #657940 is a reply to message #657841] |
Fri, 04 March 2011 17:00 |
Thanks Tim,
Meanwhile it is fixed I did a work around for this, it is not the best solution but it works for my purposes.
I changed the mouse down event for a mouse over in the JS of the tree control:
this.addEventListener( "mouseover", this._onMouseDown, this );
[Updated on: Fri, 04 March 2011 17:02] Report message to a moderator
FUDForum. Page generated in 0.02838 seconds
