Home » Archived » XML Schema Definition (XSD) » XSDWildcard distingishing between an actual xs:any and an implied any
Re: XSDWildcard distingishing between an actual xs:any and an implied any [message #65608 is a reply to message #65587] |
Thu, 29 December 2005 11:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Francis,
No this doesn't seem right. I think there is confusion here between
elements of type anyType, i..e., <xsd:element name="x"
type=xsd:anyType"/> verses element wildcards <xsd:any>. When matching
element content using the DFA returned by XSDParticle, each element will
match either an element declaration or a wildcard, which you can tell
apart easily by whether you've matched an XSDElementDeclaration or an
XSDWildcard. In the first case, you can look at the type definition of
the element declaration and determine if it is the anyType using
XSDConstants.isURType. In the second case, depending on the processing
kind of the wildcard, it will either require a strict match to some
global element declaration, or in lax or skip mode, it will treat the
element as implicitly being of type anyType. Looking directly at the
particle or the particle's parent will not provide any useful
information in this regard since a model group can contain many wildcards.
Francis Upton wrote:
> The XSDWildcard seems to be emitted in the case where an element has
> no type information; and it is also emitted in response to an actual
> xs:any element appearing in the schema.
> In both cases, the XSDWildcard appears the same (surprisingly it
> refers to a DOM element from Xerces of xs:any).
> I'm doing an implementation where I create a tree of elements, and I
> need to distinguish these two cases. In the case of an explicit
> xs:any element appearing in a schema, I need to take a different
> action from the case where an element is simply untyped.
> Right now, I determine the difference by seeing if the parent of the
> enclosing particle is an XSDModelGroup which has more than one child.
> In this case, I assume I'm working with an explicit xs:any.
> Does this seem right? Is there a better way to go?
> Francis
Re: XSDWildcard distingishing between an actual xs:any and an implied any [message #65629 is a reply to message #65608] |
Thu, 29 December 2005 21:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Francis Upton IV![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=francisu%40ieee.org) Messages: 472 Registered: July 2009 Location: Oakland, CA |
Thanks Ed, what you describe is exactly how I thought it should work. I
found the problem, I took a left turn in my code which did not allow
me to see what was really going on.
Happy new year to you!
Francis
Ed Merks wrote:
> Francis,
>> Thanks,
>> Francis
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
Re: XSDWildcard distingishing between an actual xs:any and an implied any [message #597412 is a reply to message #65587] |
Thu, 29 December 2005 11:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33201 Registered: July 2009 |
Francis,
> Francis
Ed Merks
Re: XSDWildcard distingishing between an actual xs:any and an implied any [message #597419 is a reply to message #65608] |
Francis
Ed Merks wrote:
> Francis,
>> Thanks,
>> Francis
Current Time: Sat Aug 24 12:52:05 GMT 2024
Powered by FUDForum. Page generated in 0.03314 seconds
