Re: any update to installation bug [message #65013 is a reply to message #64817] |
Mon, 24 March 2003 03:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ben Plantinga![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=abvanplant%40yahoo.com) Messages: 1 Registered: July 2009 |
I too have been hoping for an update on the installation bug. I have also
tried all the work arounds and posted solutions from several different
posts in this forum. None of them have worked successfully for me. I am
running Windows XP and using Eclipse 2.1 (various versions) for Java
devlopment, but tried the latest CDT plugin on Eclipse 2.02 without
success. I love using Eclipse for my fully time Java development
environment, but haven't done any serious C++ development as of yet.
I appreciate all the work you guys have been doing on the CDT plugin, just
wondering (like Josh) if any progress has been made with these
installation problems.
As a side note, is there a rough timeline for a CDT plugin that
(officially) works with Eclipse 2.1? I've been using the 1.0 CDT build
with Eclipse 2.1 without any major problems, but I know it's not the
official version that it's supposed to be used with. I realize that this
won't be for a while (Eclipse 2.1 isn't even finalized yet), just
wondering if there is some idea of when this will happen.
Ben Plantinga
Josh Steele wrote:
> Judy had posted a workaround for some installation problems, but I (and
> several others) keep getting the following problem (quoting from my
> previous post):
> ---Start quote
> I've tried this and it still doesn't work - but I did find a possible
> cause. This is the error I get after pressing "Enable" in the
> Install/Update Manager:
> Error creating feature "file:/C:/Program Files/eclipse/eclipse
> 2.0.2/features/org.eclipse.cdt_1.0.1.jar/".[java.io.FileNotFoundException:
> C:\Program Files\eclipse\eclipse
> 2.0.2\features\org.eclipse.cdt_1.0.1.jar\feature.xml
> The problem seems to be that it's looking for
> "features/org.eclipse.cdt_1.0.1.jar", when the zip expansion actually
> creates "features/org.eclipse.cdt_1.0.1" (no ".jar").
> ---End quote
> I am running Windows 2000, using Eclipse 2.0.2, trying to install 1.0.1
> GA. Has there been any fix to this? I'd really like to try out this plug
> in for my C/C++ programming.
> Josh
Re: any update to installation bug [message #65527 is a reply to message #64817] |
Tue, 01 April 2003 17:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: user.domain.invalid
I'm trying to install cdt with eclipse 2.1 on Linux (I know, I know, its
not supposed to work)
and I'm getting the same error message when trying to activate the cdt.
- After doing the show disabled->activate (described in some posts
earlier), I tried jarring up /features/org.eclipse.cdt_1.0.1, creating a
symbolic link with the .jar extension pointing to the
org.eclipse.cdt_1.0.1 directory and creating a copy of the
org.eclipse.cdt_1.0.1 directory , naming it org.eclipse.cdt_1.0.1.jar -
with no success.
I'm going to wait awhile to see if anyone else gets it to work or until
its officially supported - whatever comes first.
If anyone has managed to get around this - I would really appreciate
some advice (I haven't been able to find a
workaround that works in this newsgroup yet).
/m
> previous post):
> ---Start quote
> ---End quote
> Josh
Re: any update to installation bug [message #65548 is a reply to message #65527] |
Tue, 01 April 2003 18:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marcus Berglund![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=marcus.berglund%40exensus.com) Messages: 2 Registered: July 2009 |
Ok - I just tried the nightly build
(org.eclipse.cdt-200303270414-linux-gtk_1.0.1.bin.dist.zip) instead of the
one below. It worked (without any tricky workarounds) like a charm.
This is soooo nice. Thanx for the great work!!
/m
> with no success.
> Cheers,
> /m
>> previous post):
>> ---Start quote
>> ---End quote
>> Thanks,
>> Josh
Re: any update to installation bug [message #65569 is a reply to message #65548] |
Wed, 02 April 2003 07:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> the one below. It worked (without any tricky workarounds) like a
> charm. This is soooo nice. Thanx for the great work!!
> /m
I tried that too today on a Linux machine with Eclipse 2.1 installed. It
didn't work. The same configuration error with the Finish button
disabled :-(
Stelian Iancu
Linux registered user 287835
Re: any update to installation bug [message #66246 is a reply to message #65548] |
Tue, 08 April 2003 17:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dwhitema.us.ibm.com
"Marcus Berglund" <marcus.berglund@exensus.com> wrote in message
news:b6cmal$4hk$1@rogue.oti.com...
> /m
When I unzip that into my eclipse 2.1 install on linux-gtk, I can apparently
use the C++ editors, but the feature has a red X next to it under Install
Configurations -> Eclipse Platform. Whenever I try to install another
(unrelated) feature, it won't let me do so because it says that "Eclipse
C/C++ Development Tools (Linux GTK 1.0.1): Feature requires plug-in
"org.eclipse.cdt (1.0.1)", or compatible". Of course that plugin exists
after the unzip. Will someone please look into this? Should I open a
Bugzilla bug report against CDT?
David
FUDForum. Page generated in 0.04035 seconds
