Home » Eclipse Projects » Virgo » Problems using Virgo Test Framework
Problems using Virgo Test Framework [message #651546] |
Mon, 31 January 2011 15:45 |
Dmitry Messages: 4 Registered: January 2011 |
I am trying to use Virgo Test Framework to run tests with Maven and did the following steps:
1) Create unit test class:
package com.tcds.test;
import org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner;
import org.junit.Assert;
import org.junit.Test;
import org.junit.runner.RunWith;
@RunWith(DmKernelTestRunner.class)
public class DemoIntegrationTest {
@Test
public void testOne() {
Assert.assertTrue("Test failed!", false);
2) Create test.config.properties at 'src/test/resources/META-INF/test.config.properties' with the following content:
launcher.bundles =\
file:${virgo.kernel.libraries}/com.springsource.slf4j.api-1.6.1.jar@start,\
file:${virgo.kernel.libraries}/com.springsource.slf4j.org.apache.commons.logging-1.6.1.jar@start,\
file:${virgo.kernel.libraries}/com.springsource.org.aspectj.weaver-1.6.6.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.medic-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.apache.felix.configadmin-1.2.4.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.medic.core-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.osgi-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.apache.felix.eventadmin-1.0.0.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.common-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.io-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.jmx-2.1.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.math-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.util.parser.manifest-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/com.springsource.org.apache.commons.codec-1.3.0.jar@start,\
file:${virgo.kernel.libraries}/com.springsource.org.apache.commons.httpclient-3.1.0.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.repository-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.springframework.aop-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.springframework.asm-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.springframework.expression-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.springframework.beans-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.springframework.core-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.springframework.context-3.0.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.core-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.agent.dm-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.springframework.osgi.core-1.2.1.jar,\
file:${virgo.kernel.libraries}/org.springframework.osgi.extender-1.2.1.jar@start,\
file:${virgo.kernel.libraries}/org.springframework.osgi.io-1.2.1.jar,\
file:${virgo.kernel.libraries}/com.springsource.org.aopalliance-1.0.0.jar,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.artifact-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.services-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.osgi-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.deployer-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.model-2.1.0.RELEASE.jar@start,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.kerneldmfragment-2.1.0.RELEASE.jar,\
file:${virgo.kernel.libraries}/org.eclipse.virgo.kernel.shell-2.1.0.RELEASE.jar@start
deployer.timeout=300
#org.eclipse.virgo.test.properties.include=file:META-INF/virgo-test.properties
virgo.home=D:/virgo-web-server-2.1.0.RELEASE
virgo.kernel.libraries=D:/virgo-web-server-2.1.0.RELEASE/lib/kernel
virgo.ext.libraries=D:/virgo-web-server-2.1.0.RELEASE/repository/ext
virgo.osgi.java.profile=D:/virgo-web-server-2.1.0.RELEASE/lib/java6-server.profile
#Equinox Configuration
osgi.parentClassloader=fwk
osgi.context.bootdelegation=false
osgi.compatibility.bootdelegation=false
osgi.clean=true
osgi.configuration.area=target
osgi.java.profile=file:${virgo.osgi.java.profile}
osgi.java.profile.bootdelegation=override
osgi.hook.configurators.include=org.eclipse.virgo.osgi.extensions.equinox.hooks.ExtensionsHookConfigurator
org.eclipse.virgo.kernel.home=target
org.eclipse.virgo.kernel.domain=org.eclipse.virgo.kernel
# Paths are relative to the current working directory
org.eclipse.virgo.kernel.config=src/test/resources/config
org.eclipse.virgo.medic.log.config.path=src/test/resources/config/serviceability.xml
org.eclipse.gemini.web.tomcat.config.path=src/test/resources/config/tomcat-server.xml
org.eclipse.virgo.kernel.deployer.disableRecovery=true
3) Place 'config' directory from Ecipse Virgo distribution to 'src/test/resources/config'.
All relative paths at this configuration files were changed to absolute paths pointing to 'D:/virgo-web-server-2.1.0.RELEASE\' where Virgo was unpacked. Zip with this configuration files attached to this post.
While running test I have the following output:
[2011-01-31 21:26:26.328] Thread-18 < public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.328] Thread-18 Before filtering: 0
[2011-01-31 21:26:26.328] Thread-18 After filtering: 0
[2011-01-31 21:26:26.328] Thread-18 > public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.312] System Bundle Shutdown > public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.328] System Bundle Shutdown < public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.328] startup-tracker < public boolean org.eclipse.virgo.kernel.core.BlockingSignal.awaitCompletion(long, java.util.concurrent.TimeUnit) org.eclipse.virgo.kernel.core.FailureSignalledException: java.lang.RuntimeException: bundle stopped
at org.eclipse.virgo.kernel.core.BlockingSignal.awaitCompletion(BlockingSignal.java:56)
at org.eclipse.virgo.kernel.core.internal.StartupTracker$StartupTrackingRunnable.run(StartupTracker.java:161)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.RuntimeException: bundle stopped
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$StartupTrackerBundleListener.bundleChanged(BundleStartTracker.java:246)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:919)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:149)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1349)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1300)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:517)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:550)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1097)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.suspendAllBundles(StartLevelManager.java:617)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:261)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:690)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:588)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle$1.run(InternalSystemBundle.java:243)
... 1 common frames omitted
[2011-01-31 21:26:26.328] Thread-18 > public java.lang.String org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.toString()
[2011-01-31 21:26:26.328] Thread-18 < public java.lang.String org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.toString()
[2011-01-31 21:26:26.328] Thread-18 global > org.eclipse.virgo.kernel.shell.CommandExecutor [null] (org.eclipse.virgo.kernel.osgicommand_2.1.0.RELEASE [3])
[2011-01-31 21:26:26.328] startup-tracker > public static boolean org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.seen(java.lang.Throwable)
[2011-01-31 21:26:26.328] startup-tracker < public static boolean org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.seen(java.lang.Throwable)
[2011-01-31 21:26:26.328] startup-tracker > public static void org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.record(java.lang.Throwable)
[2011-01-31 21:26:26.328] startup-tracker < public static void org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.record(java.lang.Throwable)
[2011-01-31 21:26:26.343] System Bundle Shutdown > public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.343] System Bundle Shutdown < public boolean org.eclipse.virgo.kernel.shim.scope.internal.StandardScopeFactory.GlobalScope.isGlobal()
[2011-01-31 21:26:26.343] startup-tracker <ME0001W> A message with the key 'ME0003I' was not found. The inserts for the message were '[serviceability\dump\2011-01-31-21-26-328]'
[2011-01-31 21:26:26.343] startup-tracker A message with the key 'ME0003I' was not found. The inserts for the message were '[serviceability\dump\2011-01-31-21-26-328]'
[2011-01-31 21:26:26.343] startup-tracker Dump 'serviceability\dump\2011-01-31-21-26-328' generated
[2011-01-31 21:26:26.343] startup-tracker > public static boolean org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.seen(java.lang.Throwable)
[2011-01-31 21:26:26.343] startup-tracker < public static boolean org.eclipse.virgo.kernel.serviceability.dump.FFDCExceptionState.seen(java.lang.Throwable)
[2011-01-31 21:26:26.343] startup-tracker > public void org.eclipse.virgo.kernel.core.internal.ServiceReferenceTracker.ungetAll()
[2011-01-31 21:26:26.343] startup-tracker < public void org.eclipse.virgo.kernel.core.internal.ServiceReferenceTracker.ungetAll()
[2011-01-31 21:26:26.343] startup-tracker < public void org.eclipse.virgo.kernel.core.internal.StartupTracker.StartupTrackingRunnable.run() java.lang.IllegalStateException: The EventAdmin is stopped
at org.apache.felix.eventadmin.impl.EventAdminImpl$1.createHandlerTasks(EventAdminImpl.java:128)
at org.apache.felix.eventadmin.impl.EventAdminImpl.postEvent(EventAdminImpl.java:87)
at org.apache.felix.eventadmin.impl.security.EventAdminSecurityDecorator.postEvent(EventAdminSecurityDecorator.java:85)
at org.eclipse.virgo.kernel.core.internal.StartupTracker$StartupTrackingRunnable.postEvent(StartupTracker.java:249)
at org.eclipse.virgo.kernel.core.internal.StartupTracker$StartupTrackingRunnable.kernelStartFailed(StartupTracker.java:223)
at org.eclipse.virgo.kernel.core.internal.StartupTracker$StartupTrackingRunnable.run(StartupTracker.java:169)
Exception in thread "startup-tracker" java.lang.IllegalStateException: The EventAdmin is stopped
[2011-01-31 21:26:27.250] System Bundle Shutdown > public void org.eclipse.virgo.kernel.core.internal.ShutdownManager.ShutdownLoggingListener.bundleChanged(org.osgi.framework.BundleEvent)
[2011-01-31 21:26:27.250] System Bundle Shutdown < public void org.eclipse.virgo.kernel.core.internal.ShutdownManager.ShutdownLoggingListener.bundleChanged(org.osgi.framework.BundleEvent)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 37.157 sec <<< FAILURE!
Results :
Tests in error:
uk.co.utel.tcds.test.DemoIntegrationTest: An error occurred trying to read the bundle
[INFO] ------------------------------------------------------------------------
[ERROR] BUILD FAILURE
[INFO] There are test failures.
Please refer to D:\eclipseProjects\tcds_workspace\tcds-persistence-service\target\surefire-reports for the individual test results.
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 44 seconds
[INFO] Finished at: Mon Jan 31 21:26:35 NOVT 2011
[INFO] Final Memory: 26M/63M
Sometimes output is different - both versions can be found at attached zip file.
I have no ideas about the source of problem which prevent Virgo to be started. Can anyone advise how to handle this?
Re: Problems using Virgo Test Framework [message #654095 is a reply to message #651546] |
Mon, 14 February 2011 08:14 |
The problem seems to be a bundle that failed to start.
Unfortunately there are far too many logs and I cannot determine the exact bundle. Can you please try to reduce the log level/severity?
The exception "java.lang.RuntimeException: bundle stopped" can also be improved to provide the bundle's name and version. That will be helpful in cases with many logs. Can you please file a bug about the exception?
Re: Problems using Virgo Test Framework [message #656424 is a reply to message #654386] |
Fri, 25 February 2011 15:02 |
I've had some time to look at this and could you explain the difference between output_1 and output_2, are they just different runs of the same problem, while not identical they are pretty close. During startup, a kernel bundle shutdown for some unknown reason. This then prompts the whole kernel to shutdown, this is the correct behaviour, the question is why one of the kernel bundles goes down in the first place. Unfortunately this seems to be an area we could do with some better logging in.
I've had a look over the configuration and all seems to be in order although I haven't been through it in detail. First, could you confirm that when you took a copy from one of the Virgo repos it was at the 2.1.0 tag and not master as there have been a lot of changes to the required configuration. Also, I can't find any sign of the test.config file. In the Virgo projects this is not kept with the rest of the config, it's normally in the META-INF directory. This is the default location, there is an annotation to specify where it is if you want to put it somewhere else. If you did grab that as well, could you please attach that so I can have a look. If not then this may be what your missing.
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Current Time: Thu Dec 26 14:22:30 GMT 2024
Powered by FUDForum. Page generated in 0.03016 seconds
