Home » Modeling » OCL » OCL can not match operation and argument types if argument is EClass
Re: OCL can not match operation and argument types if argument is EClass [message #65368 is a reply to message #65346] |
Fri, 12 December 2008 20:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: cdamus.zeligsoft.com
Hi, Kirill,
I'm not so sure about that. The error message that you are getting is
that the Bag(EObject) type does not have an operation
intersection(Bag(EClass)). I would expect this parse error because
Bag(EObject) defines only intersection(Bag(EObject)).
You can, instead, reverse the intersection thus:
self.element.oclAsType(ecore::EClass).eSuperTypes->asBag()- >
intersection(notation::Node.allInstances()->select(
a : notation::Node | not a.element.oclIsUndefined() ).element)
because the Bag(EClass) type can do intersection(Bag(EObject)), as
Bag(EClass) conforms to Bag(EObject).
For example, in an Ecore editor, if I select an EClass and do this in
the OCL Console:
self.eSuperTypes->asBag()->intersection(EReference.allInstances().eType)
I get this error:
Cannot find operation (intersection(Bag(EClassifier))) for the type
(Bag(EClass))
but if I do this, instead:
EReference.allInstances().eType->intersection(self.eSuperTypes- >asBag())
then all is well.
HTH,
Christian
Kirill A. Balod wrote:
> Hello,
> I experimented with OCL over Ecore diagram and found strange behavior (error
> from my point of view).
> As you know notation::Node.element refers to model element and for Ecore
> diagram it could be EClass.
> I would like to know - which super classes of this class there are on
> diagram.
> I wrote query:
> a : notation::Node | not a.element.oclIsUndefined() ).element->
> inttersection(self.element.oclAsType(ecore::EClass).eSuperTy pes- >asBag())
> and found error: Cannot find operation (inttersection(Bag(EClass))) for the
> type (Bag(EObject))
> After investigation I found that if argument is EClass OCL use as type of
> argument _not_ argument.eClass() but argument itself and can not match
> operation and argument types.
> Look like problem in UMLReflection.getOCLType(Object metaElement)
> Best regards
> Kirill A. Balod
Re: OCL can not match operation and argument types if argument is EClass [message #65388 is a reply to message #65368] |
Fri, 12 December 2008 21:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi, again, Kirill,
Sorry, I seem to have got myself turned backwards this Friday afternoon.
Your formulation of the expression should be OK. The inverse would be
invalid.
I do notice that the snippet you pasted has two ts in the word
'inttersection.' Could that be the problem?
When I use 'intersection', the expression parses successfully for me in
the Interactive OCL Console.
Christian
Christian W. Damus wrote:
> Hi, Kirill,
> the OCL Console:
> I get this error:
> (Bag(EClass))
> then all is well.
> HTH,
> Christian
>> Hello,
>> (error from my point of view).
>> Ecore diagram it could be EClass.
>> diagram.
>> I wrote query:
>> for the type (Bag(EObject))
>> of argument _not_ argument.eClass() but argument itself and can not
>> match operation and argument types.
>> Best regards
>> Kirill A. Balod
Re: OCL can not match operation and argument types if argument is EClass [message #65410 is a reply to message #65388] |
Sun, 14 December 2008 21:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Kirill A. Balod![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Kirill.Balod%40borland.com) Messages: 30 Registered: July 2009 |
Member |
I'm so so sorry.
It is my double mistake.
The first - the name 'inttersection.' in my example and the second in my
code
Helper helper =
auxGetOcl().createOCLHelper();helper.setContext(getContextEC lass());
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:ghuk1m$3fd$1@build.eclipse.org...
> Hi, again, Kirill,
> invalid.
> Cheers,
> Christian
>> Hi, Kirill,
>> For example, in an Ecore editor, if I select an EClass and do this in the
>> OCL Console:
>> I get this error:
>> (Bag(EClass))
>> then all is well.
>> HTH,
>> Christian
>>> Hello,
>>> diagram.
>>> I wrote query:
>>> Best regards
>>> Kirill A. Balod
Re: OCL can not match operation and argument types if argument is EClass [message #65433 is a reply to message #65410] |
Sun, 14 December 2008 21:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
Ups..
Previous mail is incomplete...
so problem was in my function getContextEClass()
Thanks a lot for your replies.
Sorry one more..
Kirill
"Kirill A. Balod" <Kirill.Balod@borland.com> wrote in message
news:gi3s64$1tk$1@build.eclipse.org...
> I'm so so sorry.
> code
> Helper helper =
>> Hi, again, Kirill,
>> invalid.
>> Cheers,
>> Christian
>>> Hi, Kirill,
>>> the OCL Console:
>>> I get this error:
>>> (Bag(EClass))
>>> then all is well.
>>> HTH,
>>> Christian
>>>> Hello,
>>>> diagram.
>>>> I wrote query:
>>>> Best regards
>>>> Kirill A. Balod
Current Time: Sat Jul 13 17:28:50 GMT 2024
Powered by FUDForum. Page generated in 0.04263 seconds
