Home » Archived » Eclipse Communications Framework (ECF) » ECF + OSGI + TCP Socket
ECF + OSGI + TCP Socket [message #651526] Mon, 31 January 2011 09:09 Go to next message
--------------010807020801050805030007
finally I made the Target Platform running - thx for help
I had to install ECF into TargetPlatform because ECF Server should be
part of my Equinox OSGI RT App
first communication protocol to be implemented is TCPSocket
first Clients to be able to connect are BlackBerry Devices (where BB
knows 2 different kinds to connect:
directly from the device or thru BlackBerry Enterprise Server infrastructure
at first I'm testing direct connect because I don't get all errors back
thru BES infrastructure
....was not easy to setup all in TargetPlatform (will blog later how I
found solution)
now I can start the GenericServer from my OSGI Launch Config
have replaced all system.out with logging commands
and changed the protocol from 'ecftcp' to 'socket'
because the protocols are limitied from BlackBerry devices
GenericServer was started and can be connected thru URL
'socket://xxx.xxx.xxx.xx:3282/server'
got no error from BlackBerry
if I stop the GenericServer bundle then BlaclBerry reports correctly
'...connection refused...'
but now I'm lost in dust...
it's not easy to understand all concepts of ECF from given documentation
and many classes / methods are without JavaDoc
perhaps someone can help me:
* GenericServer is running as one of my OSGI bundles
* configured thru server.xml as 'socket://<myip>:3282/server'
now my questions:
* where and how can I control the connection / disconnection of a client ?
* where and how do I get access to ServerSocket and Client Socket ?
in some classes I notice that you can trace some code -
how do I switch Tracing on ? ProgramArg or Extension ?
thx
ekke
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml | blackberry
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
project lead: http://redview.org and http://red-open.org
eclipse committer: Runtime Project Riena - http://eclipse.org/riena
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=ISO-8859-15">
</head>
finally I made the Target Platform running - thx for help<br>
<br>
be part of my Equinox OSGI RT App<br>
<br>
first communication protocol to be implemented is TCPSocket<br>
knows 2 different kinds to connect:<br>
infrastructure<br>
back thru BES infrastructure<br>
<br>
----<br>
<br>
I found solution)<br>
<br>
now I can start the GenericServer from my OSGI Launch Config<br>
<br>
have replaced all system.out with logging commands<br>
and changed the protocol from 'ecftcp' to 'socket'<br>
because the protocols are limitied from BlackBerry devices<br>
<br>
'socket://xxx.xxx.xxx.xx:3282/server'<br>
got no error from BlackBerry<br>
'...connection refused...'<br>
<br>
-------<br>
but now I'm lost in dust...<br>
<br>
documentation<br>
and many classes / methods are without JavaDoc<br>
<br>
perhaps someone can help me:<br>
<br>
* GenericServer is running as one of my OSGI bundles<br>
* configured thru server.xml as 'socket://&lt;myip&gt;:3282/server'<br>
<br>
now my questions: <br>
client ?<br>
* where and how do I get access to ServerSocket and Client Socket ?<br>
<br>
in some classes I notice that you can trace some code -<br>
Re: ECF + OSGI + TCP Socket [message #651606 is a reply to message #651526] Mon, 31 January 2011 15:47 Go to previous messageGo to next message
--------------080006010800030405050504
hi,
has anyone some hints ?
I noticed that ServerManager#createServersFromConnectorList()
creates the Server Container (TCPServerSOContainer)
but I still don't know where/how to add my business logic
what should happen if connect / disconnect and receiving / sending data
thx for help
ekke
Am 31.01.11 15:09, schrieb ekke:
> infrastructure
> found solution)
> now my questions:
> thx
> ekke
> skype: ekkes-corner
skype: ekkes-corner
<html>
<head>
<meta content="text/html; charset=ISO-8859-15"
http-equiv="Content-Type">
</head>
hi,<br>
<br>
has anyone some hints ?<br>
<br>
I noticed that ServerManager#createServersFromConnectorList()<br>
creates the Server Container (TCPServerSOContainer)<br>
<br>
but I still don't know where/how to add my business logic <br>
data<br>
<br>
thx for help<br>
<br>
ekke<br>
<br>
<blockquote cite="mid:ii6ff4$sdm$1@news.eclipse.org" type="cite">
<br>
<br>
BB knows 2 different kinds to connect:<br>
infrastructure<br>
<br>
----<br>
<br>
how I found solution)<br>
<br>
<br>
<br>
correctly '...connection refused...'<br>
<br>
-------<br>
<br>
documentation<br>
<br>
<br>
<br>
client ?<br>
?<br>
<br>
Re: ECF + OSGI + TCP Socket [message #651656 is a reply to message #651606] Tue, 01 February 2011 01:27 Go to previous messageGo to next message
--------------000409090708060701010305
in the meantime I learned from
https://bugs.eclipse.org/bugs/show_bug.cgi?id=335848
that ServerManager is the 'old' way and only for backward compatibility
hard to find such things out without documentation
Am 31.01.11 21:47, schrieb ekke:
> hi,
> thx for help
> ekke
>> infrastructure
>> found solution)
>> now my questions:
>> client ?
>> thx
>> ekke
>> skype: ekkes-corner
> skype: ekkes-corner
skype: ekkes-corner
<html>
<head>
</head>
in the meantime I learned from<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=335848">https://bugs.eclipse.org/bugs/show_bug.cgi?id=335848</a><br>
compatibility<br>
<br>
hard to find such things out without documentation<br>
<br>
<blockquote cite="mid:ii76qt$ap2$1@news.eclipse.org" type="cite">
hi,<br>
<br>
<br>
<br>
data<br>
<br>
thx for help<br>
<br>
ekke<br>
<br>
<br>
should be part of my Equinox OSGI RT App<br>
<br>
(where BB knows 2 different kinds to connect:<br>
infrastructure<br>
errors back thru BES infrastructure<br>
<br>
----<br>
<br>
<br>
<br>
<br>
<br>
-------<br>
<br>
documentation<br>
<br>
<br>
<br>
a client ?<br>
Socket ?<br>
<br>
Re: ECF + OSGI + TCP Socket [message #651669 is a reply to message #651656] Tue, 01 February 2011 03:09 Go to previous message
Hi Ekke,
you might wanna subscribe to our documentation enhancement bug [0] and
help prioritize what gets documented first.
Markus
[0] https://bugs.eclipse.org/bugs/show_bug.cgi?id=329124
Previous Topic:SSL protocol
Next Topic:Event Admin is null when debugging in eclipse, not in command line
Current Time: Wed Apr 16 01:25:34 EDT 2025
Powered by FUDForum. Page generated in 0.03321 seconds
