Home » Eclipse Projects » Nebula » Questions on Nebula Grid
Questions on Nebula Grid [message #64956] Mon, 22 June 2009 08:27 Go to next message
Originally posted by: m.kasid.gmail.com
I have some queries on Grid:
1. Is it possible to change the color of cells in Row headers? How ?
2. Is it possible to change the width of Row headers or make the row header
resizable?
Mustufa
Re: Questions on Nebula Grid [message #64980 is a reply to message #64956] Wed, 24 June 2009 08:21 Go to previous messageGo to next message
Mustufa Kasidwala wrote:
> resizable?
1. It is possible to set your own custom header renderer and draw anything
you need in the header cell:
grid.getColumn(0).setHeaderRenderer(customHeaderRenderer);
There may be a possibility to use a label provider for this, but I don't
know for sure, if it exists.
2. Width of row headers is definitely adjustable, but I'm not sure of the
API to do that, sorry.
Stanislav
Re: Questions on Nebula Grid [message #64991 is a reply to message #64980] Fri, 26 June 2009 00:58 Go to previous messageGo to next message
Thanks.
I think grid.getColumn(0).setHeaderRenderer(customHeaderRenderer); will be
useful for having custom column headers, I want to know how can i modify the
Row headers. Also, I just want to have a facility of changing the color of
Row headers, so can i extend some class for this and provide colors that i
need?
Mustufa
"Stanislav Vodetskyi" <blutkind99@gmail.com> wrote in message
news:3f17500f00271a8c32c3f270d53966a7$1@www.eclipse.org...
>> Hi,
>> header resizable?
> Regards,
> Stanislav
Re: Questions on Nebula Grid [message #65000 is a reply to message #64991] Fri, 26 June 2009 03:35 Go to previous messageGo to next message
The method to set the width of the row header is called
Grid#setItemHeaderWidth. We currently miss the implementation to the set
the background/foreground color for the row-header but this should be
easy to implement.
So if you need this feature please file a bug and if possible create a
patch I can integrate into the code base. This way the feature will be
available to whole Grid community.
Tom
Mustufa Kasidwala schrieb:
> Thanks.
> need?
> Mustufa
>>> Hi,
>>> header resizable?
>> Hi,
>> Regards,
>> Stanislav
Re: Questions on Nebula Grid [message #65040 is a reply to message #65000] Fri, 26 June 2009 06:31 Go to previous messageGo to next message
Thanks Tom,
I downloaded the code from CVS and i can see the method 'setItemHeaderWidth'
added in Grid.java. It wasn't visible in the binary that i was using. I may
be using an old one.
For setting background/foreground colors in row headers, i tried it out and
was able to set it by making some changes in GridItem and
DefaultRowHeaderRenderer.
How to raise a bug for this? and how can i contribute? can I send/post the
code and you can update it?
Mustufa
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:h21tnl$2kq$1@build.eclipse.org...
> easy to implement.
> Tom
>> Thanks.
>> be
>> the
>> of
>> i
>> need?
>> Thanks,
>> Mustufa
>>>> Hi,
>>>> header resizable?
>>> Hi,
>>> anything
>>> the
>>> Regards,
>>> Stanislav
Re: Questions on Nebula Grid [message #65050 is a reply to message #65040] Fri, 26 June 2009 06:35 Go to previous messageGo to next message
Please file a bug against Nebula > Grid through
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Nebula and attach a
patch which you can create within eclipse.
Please cc me on the bug and post the bug id here.
Tom
> Thanks Tom,
> Mustufa
>> Hi,
>> easy to implement.
>> Tom
>>> Thanks.
>>> be
>>> the
>>> of
>>> i
>>> need?
>>> Thanks,
>>> Mustufa
>>>>> Hi,
>>>>> header resizable?
>>>> Hi,
>>>> anything
>>>> the
>>>> Regards,
>>>> Stanislav
Re: Questions on Nebula Grid [message #65066 is a reply to message #65050] Fri, 26 June 2009 06:46 Go to previous messageGo to next message
"attach a patch which you can create within eclipse."
can you explain what steps i need to do for this? i made changes in two
files, should i attach these two files?
Sorry if this sounds like a stupid question...
Mustufa
news:h2288o$91a$1@build.eclipse.org...
> Tom
>> Thanks Tom,
>> may
>> and
>> the
>> Thanks,
>> Mustufa
>>> Hi,
>>> easy to implement.
>>> Tom
>>>> Thanks.
>>>> be
>>>> modify
>>>> the
>>>> of
>>>> that
>>>> i
>>>> need?
>>>> Thanks,
>>>> Mustufa
>>>>>> Hi,
>>>>>> header resizable?
>>>>> Hi,
>>>>> anything
>>>>> don't
>>>>> the
>>>>> Regards,
>>>>> Stanislav
Re: Questions on Nebula Grid [message #65091 is a reply to message #65066] Fri, 26 June 2009 06:58 Go to previous messageGo to next message
1. Right Click on the project
2. Team > Create Patch
3. Save to file system
4. Attach to bug
> Mustufa
>> Hi,
>> Tom
>>> Thanks Tom,
>>> may
>>> and
>>> the
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> easy to implement.
>>>> Tom
>>>>> Thanks.
>>>>> be
>>>>> modify
>>>>> the
>>>>> of
>>>>> that
>>>>> i
>>>>> need?
>>>>> Thanks,
>>>>> Mustufa
>>>>>>> Hi,
>>>>>>> header resizable?
>>>>>> Hi,
>>>>>> anything
>>>>>> don't
>>>>>> the
>>>>>> Regards,
>>>>>> Stanislav
Re: Questions on Nebula Grid [message #65113 is a reply to message #65091] Fri, 26 June 2009 07:17 Go to previous messageGo to next message
Bug 281644 submitted for this and a patch is attached.
Mustufa
news:h229l8$3np$1@build.eclipse.org...
> 4. Attach to bug
>> Hi,
>> Thanks,
>> Mustufa
>>> Hi,
>>> Tom
>>>> Thanks Tom,
>>>> may
>>>> and
>>>> the
>>>> Thanks,
>>>> Mustufa
>>>>> Hi,
>>>>> set
>>>>> easy to implement.
>>>>> Tom
>>>>>> Thanks.
>>>>>> will
>>>>>> be
>>>>>> modify
>>>>>> the
>>>>>> color
>>>>>> of
>>>>>> that
>>>>>> i
>>>>>> need?
>>>>>> Thanks,
>>>>>> Mustufa
>>>>>>>> Hi,
>>>>>>>> row
>>>>>>>> header resizable?
>>>>>>> Hi,
>>>>>>> anything
>>>>>>> don't
>>>>>>> of
>>>>>>> the
>>>>>>> Regards,
>>>>>>> Stanislav
Re: Questions on Nebula Grid [message #65260 is a reply to message #65113] Fri, 03 July 2009 06:01 Go to previous messageGo to next message
Any idea when this will be fixed? Actually we are planning to use Nebula
Grid for our project and fixing this bug is important to us.
Mustufa
"Mustufa Kasidwala" <m.kasid@gmail.com> wrote in message
news:h22ank$i9q$1@build.eclipse.org...
> Mustufa
>> 4. Attach to bug
>>> Hi,
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Thanks Tom,
>>>>> I
>>>>> may
>>>>> out
>>>>> and
>>>>> the
>>>>> Thanks,
>>>>> Mustufa
>>>>>> Hi,
>>>>>> set
>>>>>> easy to implement.
>>>>>> a
>>>>>> be
>>>>>> Tom
>>>>>>> Thanks.
>>>>>>> will
>>>>>>> be
>>>>>>> modify
>>>>>>> the
>>>>>>> color
>>>>>>> of
>>>>>>> that
>>>>>>> i
>>>>>>> need?
>>>>>>> Thanks,
>>>>>>> Mustufa
>>>>>>>>> Hi,
>>>>>>>>> row
>>>>>>>>> header resizable?
>>>>>>>> Hi,
>>>>>>>> anything
>>>>>>>> don't
>>>>>>>> of
>>>>>>>> the
>>>>>>>> Regards,
>>>>>>>> Stanislav
Re: Questions on Nebula Grid [message #65281 is a reply to message #65260] Fri, 03 July 2009 06:10 Go to previous messageGo to next message
I'll try (but can't promise) to revist it on the weekend.
Tom
Re: Questions on Nebula Grid [message #65454 is a reply to message #65281] Fri, 10 July 2009 04:42 Go to previous message
Thanks Tom,
I can see this is fixed now.
Mustufa
news:h2klf5$sci$1@build.eclipse.org...
> Tom
>> Hi,
Re: Questions on Nebula Grid [message #595372 is a reply to message #64956] Wed, 24 June 2009 08:21 Go to previous message
> resizable?
Stanislav
Re: Questions on Nebula Grid [message #595381 is a reply to message #64980] Fri, 26 June 2009 00:58 Go to previous message
Thanks.
need?
Mustufa
>> Hi,
>> header resizable?
> Regards,
> Stanislav
Re: Questions on Nebula Grid [message #595392 is a reply to message #64991] Fri, 26 June 2009 03:35 Go to previous message
easy to implement.
Tom
> Thanks.
> need?
> Mustufa
>>> Hi,
>>> header resizable?
>> Hi,
>> Regards,
>> Stanislav
Re: Questions on Nebula Grid [message #595409 is a reply to message #65000] Fri, 26 June 2009 06:31 Go to previous message
Thanks Tom,
Mustufa
> easy to implement.
> Tom
>> Thanks.
>> be
>> the
>> of
>> i
>> need?
>> Thanks,
>> Mustufa
>>>> Hi,
>>>> header resizable?
>>> Hi,
>>> anything
>>> the
>>> Regards,
>>> Stanislav
Re: Questions on Nebula Grid [message #595416 is a reply to message #65040] Fri, 26 June 2009 06:35 Go to previous message
Tom
> Thanks Tom,
> Mustufa
>> Hi,
>> easy to implement.
>> Tom
>>> Thanks.
>>> be
>>> the
>>> of
>>> i
>>> need?
>>> Thanks,
>>> Mustufa
>>>>> Hi,
>>>>> header resizable?
>>>> Hi,
>>>> anything
>>>> the
>>>> Regards,
>>>> Stanislav
Re: Questions on Nebula Grid [message #595430 is a reply to message #65050] Fri, 26 June 2009 06:46 Go to previous message
Mustufa
> Tom
>> Thanks Tom,
>> may
>> and
>> the
>> Thanks,
>> Mustufa
>>> Hi,
>>> easy to implement.
>>> Tom
>>>> Thanks.
>>>> be
>>>> modify
>>>> the
>>>> of
>>>> that
>>>> i
>>>> need?
>>>> Thanks,
>>>> Mustufa
>>>>>> Hi,
>>>>>> header resizable?
>>>>> Hi,
>>>>> anything
>>>>> don't
>>>>> the
>>>>> Regards,
>>>>> Stanislav
Re: Questions on Nebula Grid [message #595441 is a reply to message #65066] Fri, 26 June 2009 06:58 Go to previous message
4. Attach to bug
> Mustufa
>> Hi,
>> Tom
>>> Thanks Tom,
>>> may
>>> and
>>> the
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> easy to implement.
>>>> Tom
>>>>> Thanks.
>>>>> be
>>>>> modify
>>>>> the
>>>>> of
>>>>> that
>>>>> i
>>>>> need?
>>>>> Thanks,
>>>>> Mustufa
>>>>>>> Hi,
>>>>>>> header resizable?
>>>>>> Hi,
>>>>>> anything
>>>>>> don't
>>>>>> the
>>>>>> Regards,
>>>>>> Stanislav
Re: Questions on Nebula Grid [message #595445 is a reply to message #65091] Fri, 26 June 2009 07:17 Go to previous message
Mustufa
> 4. Attach to bug
>> Hi,
>> Thanks,
>> Mustufa
>>> Hi,
>>> Tom
>>>> Thanks Tom,
>>>> may
>>>> and
>>>> the
>>>> Thanks,
>>>> Mustufa
>>>>> Hi,
>>>>> set
>>>>> easy to implement.
>>>>> Tom
>>>>>> Thanks.
>>>>>> will
>>>>>> be
>>>>>> modify
>>>>>> the
>>>>>> color
>>>>>> of
>>>>>> that
>>>>>> i
>>>>>> need?
>>>>>> Thanks,
>>>>>> Mustufa
>>>>>>>> Hi,
>>>>>>>> row
>>>>>>>> header resizable?
>>>>>>> Hi,
>>>>>>> anything
>>>>>>> don't
>>>>>>> of
>>>>>>> the
>>>>>>> Regards,
>>>>>>> Stanislav
Re: Questions on Nebula Grid [message #595508 is a reply to message #65113] Fri, 03 July 2009 06:01 Go to previous message
Mustufa
> Mustufa
>> 4. Attach to bug
>>> Hi,
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Thanks Tom,
>>>>> I
>>>>> may
>>>>> out
>>>>> and
>>>>> the
>>>>> Thanks,
>>>>> Mustufa
>>>>>> Hi,
>>>>>> set
>>>>>> easy to implement.
>>>>>> a
>>>>>> be
>>>>>> Tom
>>>>>>> Thanks.
>>>>>>> will
>>>>>>> be
>>>>>>> modify
>>>>>>> the
>>>>>>> color
>>>>>>> of
>>>>>>> that
>>>>>>> i
>>>>>>> need?
>>>>>>> Thanks,
>>>>>>> Mustufa
>>>>>>>>> Hi,
>>>>>>>>> row
>>>>>>>>> header resizable?
>>>>>>>> Hi,
>>>>>>>> anything
>>>>>>>> don't
>>>>>>>> of
>>>>>>>> the
>>>>>>>> Regards,
>>>>>>>> Stanislav
Re: Questions on Nebula Grid [message #595512 is a reply to message #65260] Fri, 03 July 2009 06:10 Go to previous message
Tom
Re: Questions on Nebula Grid [message #595584 is a reply to message #65281] Fri, 10 July 2009 04:42 Go to previous message
Thanks Tom,
Mustufa
> Tom
>> Hi,
Previous Topic:Row header width resizable
Next Topic:load image to Gallery very slow
Current Time: Mon Mar 31 20:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.04929 seconds
