Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] getting All classes from Papyrus Model([Acceleo 3] getting All classes from Papyrus Model strarting from a given class property)
[Acceleo 3] getting All classes from Papyrus Model [message #646930] Mon, 03 January 2011 04:08 Go to next message
Hi to everybody!
I'm dealing with an Acceleo 3 template to generate c# code. The problem is that starting from a Papyrus UML model I would like to retrieve all classes that belong to such model.
My template simply write a file for each class but sometimes given a class it has to find for each of other class of the model if a given property is set. I tried to select classes form getModel() method but it didn't work:
"[(c.getModel().eAllContents(Class)->select(
classLoop: Class | general->asSequence()->last().qualifiedName = c.qualifiedName))->collect(qualifiedName)/] "
I tried also with different selection, but it seems that model doesn't contain classes.
Is it possible to do that? please send me a feedback.
thanks in advance
giacomo
Re: [Acceleo 3] getting All classes from Papyrus Model [message #647229 is a reply to message #646930] Wed, 05 January 2011 03:38 Go to previous message
--------------040100080406000008030107
Hi Giacomo,
This isn't a Papyrus problem, rather a general UML question. However, I
don't see what you're trying to do at all. You say you want to retrieve
all classes, but the OCL query you show doesn't select "all" classes :
it only retrieve one single classes which is the one you started with
(the class contained in variable "c").
"all classes" can be done in a number of ways, here are the two easiest :
1 - [Class.AllInstances/]
2 - [c.getModel().eAllContents(Class)/]
You had the "2", however, the "select" you did afterwards was merely
narrowing down the Classes you retrieved to "c" alone.
Laurent Goubet
Obeo
On 03/01/2011 10:08, splogad wrote:
> Hi to everybody!
> didn't work:
> "[(c.getModel().eAllContents(Class)->select( classLoop: Class |
> contain classes.
> thanks in advance
> giacomo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040100080406000008030107--
Previous Topic:[Xpand] setting the value of a global variable from xtend?
Next Topic:Using getValue(Stereotype, String) with Collections
Current Time: Wed Oct 29 18:26:45 EDT 2025
Powered by FUDForum. Page generated in 0.04227 seconds
