Re: [ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64672 is a reply to message #64581] |
Wed, 24 October 2007 07:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: quentin.glineur.obeo.fr
--------------050401030707070401070006
Hi Guillaume,
Can you send a trace of the raised exception and give more details about
the way you launch the transformation ?
Quentin GLINEUR
Guillaume Gauffre a
Re: [ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64832 is a reply to message #64740] |
Fri, 26 October 2007 08:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
--------------090609060405010307030203
the XML injection process deals with injection (TCS) and not with
transformation (ATL). Thus, you cannot use a launch config (ATL
configuration) to perform an injection.
You can inject an XML file with an ant task (am3.loadmodel specifying an
injector) or with Java code (then look at
org.eclipse.am3.ui.ActionXMLInjector class)
Quentin GLINEUR
Guillaume Gauffre a
FUDForum. Page generated in 0.03680 seconds
