[CDO] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common.revision.InternalCDO [message #646589] |
Wed, 29 December 2010 01:37 |
In CDO 3.0 / Teneo 1.1.2 / Hibernate 3.3.2, When saving a CDO Object
using CDOResource.save() I got :
java.lang.ClassCastException:
org.eclipse.emf.cdo.internal.common.id.CDOIDExternalImpl cannot be cast
to org.eclipse.emf.cdo.spi.common.revision.InternalCDORevision
Observing the class hierarchy it seems the exception is correct.
But how could it happen?
from CDOPropertyGetter.java :
public Object get(Object target) throws HibernateException
InternalCDORevision revision = (InternalCDORevision)target;
if (!(HibernateUtil.getInstance().getCDOID(revision) instanceof
CDOIDObject))
so either the code is incorrect or something sent the wrong object.
Any suggestions??
!ENTRY org.eclipse.emf.cdo.server.hibernate 4 0 2010-12-29 07:57:12.967
!MESSAGE org.eclipse.emf.cdo.internal.common.id.CDOIDExternalImpl
cannot be cast to
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOID PropertyGetter.get(CDOIDPropertyGetter.java:41)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.getIdentif ier(AbstractEntityTuplizer.java:199)
at
org.hibernate.persister.entity.AbstractEntityPersister.getId entifier(AbstractEntityPersister.java:3605)
at
org.hibernate.persister.entity.AbstractEntityPersister.isTra nsient(AbstractEntityPersister.java:3321)
at
org.hibernate.engine.ForeignKeys.isTransient(ForeignKeys.jav a:204)
at
org.hibernate.event.def.AbstractSaveEventListener.getEntityS tate(AbstractSaveEventListener.java:535)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:103)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at
org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:535)
at
org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :527)
at
org.hibernate.engine.CascadingAction$5.cascade(CascadingActi on.java:241)
at
org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:292)
at
org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :240)
at
org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:19 3)
at org.hibernate.engine.Cascade.cascade(Cascade.java:154)
at
org.hibernate.event.def.AbstractSaveEventListener.cascadeBef oreSave(AbstractSaveEventListener.java:454)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:288)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:204)
at
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:130)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:210)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:117)
at
at
at
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Accessor.write(HibernateStoreAccessor.java:556)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext .write(TransactionCommitContext.java:328)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:35)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:1)
at
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:316)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:168)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:122)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:315)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Eclipse Driven Rich Application Development -
http://eclipsedriven.blogspot.com/
Re: [CDO] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common.revision.Interna [message #646595 is a reply to message #646589] |
Wed, 29 December 2010 02:52 |
It turned out this was because I tried to import an XMI file into a CDO
Resource, but it contains references to objects in another XMI file.
cast
> @Override
> CDOIDObject))
> Any suggestions??
07:57:12.967
> cannot be cast to
cast
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [CDO] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common.revision.Interna [message #646788 is a reply to message #646589] |
Fri, 31 December 2010 09:05 |
Hi Hendy,
If you see "hibernate" or "teneo" in a stack trace it's usually best to add that to your subject prefix, e.g. [CDO/Teneo], to catch Martin's attention.
CDO generally supports references to objects in any type of non-CDO resource. We call that external references. Either the HibernateStore does not support that or that support is broken somehow. I hope that Martin can clarify it.
Cheers
/Eike
http://www.esc-net.de
It might be the
Am 29.12.2010 02:37, schrieb Hendy Irawan:
> @Override
> CDOIDObject))
> Any suggestions??
> cannot be cast to
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Cheers
/Eike
Re: [CDO/Teneo/Hibernate] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common. [message #646820 is a reply to message #646788] |
Fri, 31 December 2010 14:41 |
Thansk Eike.
It seems this happens when I import (i.e. copyAll() ) objects from an
XMI file that references objects in another XMI file.
If Teneo/Hibernate doesn't support it then it should give a proper error
with information as opposed to a Java cast exception.
Here's an illustration of my models:
XMI Resource 1: A (root) --containment children--> B --reference--> C
XMI Resource 2: D (root) --containment children--> C
What I do is do a copyAll(A) from XMI Resource 1 to CDO.
I think what happens is CDO is confused because it needs to store A, B,
and C.. but problematic because C is contained in D, which is not
stored.
What's the "official" CDO resolution for the scenario above?
I'm also curious what happens with unresolved (cannot validate?)
Eike Stepper wrote:
> Hi Hendy,
to
> attention.
does
can
> clarify it.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> It might be the
cast
>> @Override
>> CDOIDObject))
>> Any suggestions??
07:57:12.967
>> cannot be cast to
cast
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO/Teneo/Hibernate] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common. [message #646845 is a reply to message #646820] |
Sat, 01 January 2011 09:52 |
Am 31.12.2010 15:41, schrieb Hendy Irawan:
> Thansk Eike.
This topic has been discussed, e.g., in "[CDO] Import a fragmented model ?". One solution is:
Collection<Resource> resourcesToImport = null;
CDOTransaction transaction = null;
EcoreUtil.Copier copier = new EcoreUtil.Copier(); // A Copier for all roots
for (Resource resourceToImport : resourcesToImport)
Collection<EObject> copiedObjects = copier.copyAll(resourceToImport.getContents());
String targetPath = resourceToImport.getURI().path();
CDOResource cdoResource = transaction.createResource(targetPath);
cdoResource.getContents().addAll(copiedObjects);
copier.copyReferences();
transaction.commit();
Please file a bugzilla.
> stored.
As I said, I don't think CDO is confused. It correctly encapsulated this reference to an object outside of the current repository in a CDOIDExternal. But the HibernateStore does not seem to handle it correctly.
CDO does only use the (proxy) URI of the target object, whether it's resolved or not.
Cheers
/Eike
> Eike Stepper wrote:
>> Hi Hendy,
> to
>> attention.
> does
> can
>> clarify it.
>> Cheers
>> /Eike
>> It might be the
> cast
>>> @Override
>>> CDOIDObject))
>>> Any suggestions??
> 07:57:12.967
>>> cannot be cast to
> cast
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Cheers
/Eike
Re: [CDO/Teneo/Hibernate] Error: CDOIDExternalImpl cannot be cast to org.eclipse.emf.cdo.spi.common. [message #646912 is a reply to message #646845] |
Mon, 03 January 2011 05:09 |
Hi Hendy,
A later reply because I was away for new year. The CDO HibernateStore can map external references but you have to tell
the store which associations are to be stored externally. Below a xml document which contains an example on how to map
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Asso ciation_Mapping#Storing_external_references_.28to_non-persis ted_objects.29.2C_customizing_persisting_references
See here on how to add annotations in xml:
http://wiki.eclipse.org/CDO/Hibernate_Store/Model_Relational _Mapping#JPA_Annotations_in_XML
<?xml version="1.0" encoding="utf-8"?>
<persistence-mapping xmlns="http://www.eclipse.org/emft/teneo"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<epackage namespace-uri="http://www.eclipse.org/emf/CDO/tests/model4/1.0.0">
<eclass name="GenRefSingleNonContained">
<property name="element">
<external> org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOID ExternalUserType </external>
</property>
</eclass>
</epackage>
<epackage namespace-uri="http://www.eclipse.org/emf/CDO/tests/model1/1.0.0">
<eclass name="PurchaseOrder">
<property name="supplier">
</property>
</eclass>
<eclass name="Supplier">
<property name="purchaseOrders">
</property>
</eclass>
</epackage>
</persistence-mapping>
>> Thansk Eike.
>> stored.
> Cheers
> /Eike
>> Eike Stepper wrote:
>>> Hi Hendy,
>> to
>>> attention.
>> does
>> can
>>> clarify it.
>>> Cheers
>>> /Eike
>>> It might be the
>> cast
>>>> @Override
>>>> CDOIDObject))
>>>> Any suggestions??
>> 07:57:12.967
>>>> cannot be cast to
>> cast
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.05245 seconds
