Home » Archived » BIRT » BIRT + javabridge... HELP!!!!!!!
BIRT + javabridge... HELP!!!!!!! [message #644132] |
Thu, 09 December 2010 15:57 |
osuwariboy Mising name Messages: 24 Registered: December 2010 |
Hi all,
I'm currently designing reports using BIRT but all of my frontend interface is in PHP. Since those reports are all accessible via the Web through an HTTPS connection, using the solution presented here is not an option:
http://www.eclipse.org/birt/phoenix/deploy/usingPHP.php
"http:localhost:8080" does not work over the internet and even if it did, I'd end up losing my secured connection anyway since control would then jump to Tomcat which is unsecured.
This is why I ended up using phpjavabridge which calls the reports from PHP and consequently my Apache server which IS secured. There's no other way to put it but that it was a nightmare to setup until I've stumbled upon this thread:
http://www.eclipse.org/forums/index.php?t=msg&goto=49139 4&
That successfully solved my problem... until recently where BIRT decided to upgrade their report engine and all of the new reports decided to stop working with the error:
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:RunAndRenderTask]]->run. Cause: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report. VM: 1.6.0_22@http://java.sun.com/" at: #-29 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:199) #-28 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:75) #-27 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-26 sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) #-25 sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) #-24 java.lang.reflect.Method.invoke(Unknown Source) #-23 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:990) #-22 php.java.bridge.Request.handleRequest(Request.java:415) #-21 php.java.bridge.Request.handleRequests(Request.java:491) #-20 php.java.servlet.PhpJavaServlet.handleHttpConnection(PhpJavaServlet.java:170) #-19 php.java.servlet.PhpJavaServlet.handlePut(PhpJavaServlet.java:186) #-18 php.java.servlet.PhpJavaServlet.doPut(PhpJavaServlet.java:195) #-17 javax.servlet.http.HttpServlet.service(HttpServlet.java:640) #-16 javax.servlet.http.HttpServlet.service(HttpServlet.java:717) #-15 org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) #-14 org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) #-13 php.java.servlet.PhpCGIFilter.doFilter(PhpCGIFilter.java:126) #-12 org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) #-11 org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) #-10 org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) #-9 org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) #-8 org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) #-7 org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) #-6 org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) #-5 org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) #-4 org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857) #-3 org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) #-2 org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) #-1 java.lang.Thread.run(Unknown Source) #0 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(230): java_ThrowExceptionProxyFactory->getProxy(14, '@V', 'T', true) #1 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(356): java_Arg->getResult(true) #2 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(362): java_Client->getWrappedResult(true) #3 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(554): java_Client->getResult() #4 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1711): java_Client->invokeMethod(7, 'run', Array) #5 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1810): java_JavaProxy->__call('run', Array) #6 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1958): java_AbstractJava->__call('run', Array) #7 [internal function]: Java->__call('run', Array) #8 C:\Program Files\EasyPHP-5.3.2i\www\timesheets\rapportsall.php(339): java_InternalJava->run() #9 {main}]
Which essentially means nothing and everything at once. So, I tried upgrading the engine following the same steps I followed initially (replacing all of the jar in the lib directory except a select few)... and nothing. Same problem.
A new version of javabridge conveniently shows up, I decided to try this one... same mistake. Upgrade the BIRT enging... same mistake.
I've tried the three versions of Tomcat available... same result. I just don't know what to do anymore. All I want is for my reports to be accessible via the web through a secure connection with a PHP frontend. Is it really THAT complicated to accomplish?
Anyway, thanks in advance for any suggestion you people might have.
Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644157 is a reply to message #644132] |
Thu, 09 December 2010 17:44 |
What version of the Designer are you using? What version of BIRT
runtime did you update to? Can you list the jars that are in the
WEB-INF/lib
Jason
On 12/9/2010 10:57 AM, osuwariboy wrote:
> Hi all,
> option:
> upon this thread:
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:199)
> #-28
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
> php.java.servlet.PhpJavaServlet.handleHttpConnection(PhpJava Servlet.java:170)
> #-19 php.java.servlet.PhpJavaServlet.handlePut(PhpJavaServlet.jav a:186)
> #-18 php.java.servlet.PhpJavaServlet.doPut(PhpJavaServlet.java:19 5) #-17
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> #-14
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> #-13 php.java.servlet.PhpCGIFilter.doFilter(PhpCGIFilter.java:126 ) #-12
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
> #-11
> #-10
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> #-9
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> #-8
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
> #-7
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> #-6
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> #-5
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
> #-4
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:857)
> #-3
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:588)
> #-2
> org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:489)
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644181 is a reply to message #644173] |
Thu, 09 December 2010 18:54 |
Can you look at this directory
webapps\JavaBridge\WEB-INF\platform\plugins
And post the version of the org.eclipse.birt.core plugin?
Also can you run the url
http://localhost:8080/JavaBridge/BirtIndex.jsp?
If so try running one of the reports.
Jason
On 12/9/2010 1:28 PM, osuwariboy wrote:
> The designer is:
> Version: Helios Service Release 1
> Build id: 20100917-0705
> BIRT runtime from 2.6.0 to 2.6.1
> Tomcat 6.0 (though every version gives me the same answer)
> javabridge from 5.?.? (sorry lost version number) to 6.2.1
> Jar files:
> birtEngine.jar
> chartengineapi.jar
> chartexamplescoreapi.jar
> chartitemapi.jar
> com.ibm.icu_4.2.1.v20100412.jar
> commons-cli-1.0.jar
> coreapi.jar
> crosstabcoreapi.jar
> dataadapterapi.jar
> dataaggregationapi.jar
> dataextraction.jar
> documentBeanClient.jar
> dteapi.jar
> emitterconfig.jar
> engineapi.jar
> flute.jar
> itext.jar
> JavaBridge.jar
> js.jar
> lucene.jar
> modelapi.jar
> modelodaapi.jar
> numberGuess.jar
> odadesignapi.jar
> org.apache.commons.codec_1.3.0.v20100518-1140.jar
> org.eclipse.emf.common_2.6.0.v20100607-0756.jar
> org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
> org.eclipse.emf.ecore_2.6.0.v20100607-0756.jar
> org.w3c.css.sac_1.3.0.v200805290154.jar
> php-script.jar
> php-servlet.jar
> poi.jar
> scriptapi.jar
> script-api.jar
> Those are all the default files given with JavaBridge. I noticed that
> jaxrpc.jar is missing, but adding it from my old installation doesn't do
> anything.
> As I said, any sort of help would be greatly appreciated since I've been
> at this for almost a week now and I'm getting understandably irritated.
> Anyway, thanks in advance :).
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644189 is a reply to message #644183] |
Thu, 09 December 2010 19:32 |
Sounds like you did not update the plugins folder. Remove all the
plugins from the plugins folder and replace them with the runtime
download reportengine/plugins. Also delete everything in the
configuration directory but the config.ini.
Jason
On 12/9/2010 2:21 PM, osuwariboy wrote:
> I've tried running all of the reports available at:
> All of them open successfully, though I checked the files themselves and
> the engine version listed in the .rptdesign file is 3.2.21 while the
> latest engine I'm trying to use is 3.2.22
> Also, here's the version of the core:
> org.eclipse.birt.core_2.6.0.v20100526.jar
> If I check the corresponding folder inside the BIRT runtime package, I
> notice most of the jar files are more recent than those listed in the
> javabridge folder. Example:
> org.eclipse.birt.core_2.6.1.v20100819.jar
> Should I try and upgrade this folder too? And if so, what files should I
> modify?
> Thanks again
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644190 is a reply to message #644189] |
Thu, 09 December 2010 19:49 |
I've done as instructed, but I get this error this time around:
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:ReportEngine]]->openReportDesign((o:String)[o:String]). Cause: java.lang.NullPointerException VM: 1.6.0_22@http://java.sun.com/" at: #-16 org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:108) #-15 org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:143) #-14 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255) #-13 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274) #-12 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196) #-11 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130) #-10 org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:295) #-9 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-8 sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) #-7 sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) #-6 java.lang.reflect.Method.invoke(Unknown Source) #-5 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:1044) #-4 php.java.bridge.Request.handleRequest(Request.java:417) #-3 php.java.bridge.Request.handleRequests(Request.java:500) #-2 php.java.bridge.http.ContextRunner.run(ContextRunner.java:145) #-1 php.java.bridge.ThreadPool$Delegate.run(ThreadPool.java:60) #0 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(232): java_ThrowExceptionProxyFactory->getProxy(6, '@V', 'T', true) #1 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(360): java_Arg->getResult(true) #2 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(366): java_Client->getWrappedResult(true) #3 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(560): java_Client->getResult() #4 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1752): java_Client->invokeMethod(4, 'openReportDesig...', Array) #5 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1851): java_JavaProxy->__call('openReportDesig...', Array) #6 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1999): java_AbstractJava->__call('openReportDesig...', Array) #7 [internal function]: Java->__call('openReportDesig...', Array) #8 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\PhpRunAndRenderHTML.php(24): java_InternalJava->openReportDesign('C:\Program File...') #9 {main}]
It's almost like Javabridge cannot cope with the filenames having changed from one version to the other.
Is there a place where one can upgrade these references?
Re: BIRT + javabridge... HELP!!!!!!! [message #644204 is a reply to message #644190] |
Thu, 09 December 2010 21:50 |
Does the jsp page work?
Jason
> #-16
> org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:108)
> #-15
> org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:143)
> #-14
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.g etReportDesignHandle(ReportEngineHelper.java:255)
> #-13
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:274)
> #-12
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:196)
> #-11
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:130)
> #-10
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:295)
> php.java.bridge.http.ContextRunner.run(ContextRunner.java:14 5) #-1
Re: BIRT + javabridge... HELP!!!!!!! [message #644205 is a reply to message #644204] |
Thu, 09 December 2010 21:58 |
Also verify that you did not leave the javabridge.war in the webapps
directory of tomcat.
Jason
> Jason
>> #-16
>> #-15
>> #-14
>> #-13
>> #-12
>> #-11
>> #-10
Re: BIRT + javabridge... HELP!!!!!!! [message #644333 is a reply to message #644205] |
Fri, 10 December 2010 15:17 |
Jason Weathersby... you are my savior!!!!!!! For people who will read this in the future, here is exactly what I did (assuming you already have the necessary BIRT runtime downloaded, that is):
1) Stop Tomcat
2) Flush any JavaBridge already in place (actually moving the JavaBridge folder into another dummy directory is recommended here)
3) Put the new JavaBridge.war file in the webapps directory of Tomcat
4) Restart Tomcat and let it decompress the .war file, it should create a new directory
5) Stop Tomcat
6) Move the JavaBridge.war file away from the webapps directory to prevent any future interference
7) Locate the JavaBridge/WEB-INF/lib directory of your JavaBridge (normally, the first file inside should be BirtEngine.jar) and rename it however you please (in my case, I merely renamed it lib_old)
8 ) Next, decompress your BIRT runtime into a folder and locate the ReportEngine/lib directory inside. Then, copy it at the location found in step 7 (normally, you should have lib and lib_old along with a few other folders if you follow my naming convention)
9)Next, from your lib_old folder, copy the following files in the new lib folder:
birtEngine.jar
JavaBridge.jar
jaxrpc.jar (this one was actually removed from the JavaBridge 6.2.1, but I haven't encountered any problems even if it isn't there... bottom line, if you have it, take it, if you don't then just ignore it)
lucene.jar
php-script.jar
php-servlet.jar
script-api.jar
10) Next go to the JavaBridge/WEB-INF/platform and you should see a "plugins" directory. Rename that "plugins_old"
11) From your BIRT runtime decompressed folder, grab the ReportEngine/plugins folder and copy it in the location found at step 10
12) Now, enter your new plugins folder and locate a folder that should be named something like:
org.eclipse.birt.report.data.oda.jdbc_version (where "version" is something that will change, for me it was 2.6.1.v20100909)
13) Inside, you should find a "driver" folder that should only contain a readme.txt file. What you need to do here is download a jdbc connector jar file and put it there. I myself used the same one that I used with my version of Eclipse.
What I did personally was go to my folder:
eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_2.6.1. v20100909\drivers
and copy the "mysql-connector-java-5.1.12-bin.jar" I found there into the folder mentioned at step 12
Once I did that and subsequently restarted Tomcat... everything was fine and dandy. Keep in mind of course that the version of your connector might change, but I don't think it really matters.
I really have to thank Jason again for his invaluable help in setting everything up. I never would have done it without his help.
Good luck with JavaBridge everyone and thanks Jason
Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644352 is a reply to message #644333] |
Fri, 10 December 2010 16:26 |
Thanks For posting your howto description.
Jason
> 1) Stop Tomcat
> a new directory
> 5) Stop Tomcat
> lib folder:
> birtEngine.jar
> JavaBridge.jar
> lucene.jar
> php-script.jar
> php-servlet.jar
> script-api.jar
> v20100909\drivers
> Osu
Current Time: Sat Oct 19 15:59:12 GMT 2024
Powered by FUDForum. Page generated in 0.04348 seconds
