How Increment Variable in loop [message #643852] |
Wed, 08 December 2010 13:41 |
Manuel Selva Messages: 189 Registered: July 2009 Location: Grenoble, France |
Hi all, in my .mtl file (working on EMF model) I have the following loop
[for (param : Param | subCat.params)]
record.readPayload32("What to put here ??");
[/for]
What I want is to replace the "What to put here" by a value starting at 0 and incremented on each loop's iterration by
The Param EClass has an integer length attribute.
How can I acheive this ? I was not able to find any solution until now ...
Thanks in advance for your help,
Manu
http://manuelselva.wordpress.com/
Re: How Increment Variable in loop [message #643865 is a reply to message #643852] |
Wed, 08 December 2010 14:08 |
--------------080702080304030006030107
Hi Manuel,
Acceleo defines an implicit "i" variable for iterations in order to
handle such needs :
record.readPayload32([i/]);
[/for]
Laurent Goubet
Obeo
> [/for]
> [param.length/] The Param EClass has an integer length attribute.
> Manu
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080702080304030006030107--
Re: How Increment Variable in loop [message #643879 is a reply to message #643873] |
Wed, 08 December 2010 14:59 |
--------------070507050705010905060406
Manuel,
This can still be done... but you'll need to iterate twice on your list :
record.readPayload32([subCat.params->subSequence(0,
i).length->sum()/]);
[/for]
Laurent Goubet
Obeo
On 08/12/2010 15:49, Manuel Selva wrote:
> Hi Laurent,
> Thanks for the answer but this is not exactly what I need. I nee to
> increment this variable with a field of my model:
> [param.length/]
> the output will look like for example (with 3 parameters of length 2,4,2
> respectively)
> record.readPayload32(0);
> record.readPayload32(2); // 0 + 2
> record.readPayload32(6); // 0 + 2 + 4
--------------070507050705010905060406--
Re: How Increment Variable in loop [message #643904 is a reply to message #643883] |
Wed, 08 December 2010 16:09 |
--------------070908010903090408080404
Manuel,
subSequence is for Sequences... you have to use "subOrderedSet" on
OrderedSets :p.
Laurent Goubet
Obeo
On 08/12/2010 16:37, Manuel Selva wrote:
> Thanks again but I don't have the subSequence function:
> Cannot find operation (subSequence(Integer, Integer)) for the type
> (OrderedSet(Param))
> Any ideas about that ?
--------------070908010903090408080404--
FUDForum. Page generated in 0.05255 seconds
