Re: Check of OCL constraints embedded in UML2 profile [message #64339 is a reply to message #64274] |
Wed, 05 November 2008 13:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: cdamus.zeligsoft.com
Hi, Matteo,
The org.eclipse.emf.validation.examples.ocl example plug-in (installed
via the "New -> Example..." wizard if you have the EMF Validation
Framework SDK) demonstrates a simple way to contribute constraints from
an OCL text file. It's a pretty bare-bones example of a custom
constraint provider that doesn't put its constraints in the plugin.xml.
You could adapt this example to have the constraint provider get the
stereotypes applied to a UML element and find Constraints attached to
the Stereotypes. For any Constraint that is specified by an OCL
expression (usually as an OpaqueExpression with a language "OCL"), you
could create an AbstractOCLModelConstraint that parses and evaluates it.
HTH,
Christian
Matteo Bordin wrote:
> Hello all,
> this is what I am trying to do:
> 1. Define a UML2 profile
> 2. Embed OCL constraints in the UML2 profile
> 3. Validate a model using the profile - and thus the embedded OCL
> constraints
> The OCL constraints tipically check that model element with a given
> stereotypes have certain properties. A typical OCL constraint is thus
> something like:
> myStereotype.base_BaseClass.<ocl_expression>
> The first two steps were quite easy (I use the Papyrus UML editor which
> embeds an OCL parser/validator); but I have serious problems with the
> validation part (for the papyrus users: the tutorial for OCL constraints
> doesn't seem to work).
> I googled around looking for tutorial/solutions with no results (or
> partial results lacking detailed info).
> So the question is: is there a way to directly use OCL constraints
> embedded in a UML2 profile to validate a model? If not, could you please
> indicate a tutorial explaining how to use OCL constraints embedded in a
> UML2 profile (likely via the validation frameworks)?
> Thanks in advance,
> Matteo
Re: Check of OCL constraints embedded in UML2 profile [message #64362 is a reply to message #64339] |
Wed, 05 November 2008 17:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Matteo Bordin![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bordin%40adacore.com) Messages: 19 Registered: July 2009 |
Hello Christian,
thanks for the hint. Before trying it, I would like to know if I could
use UML2 static profiles for my purpose (generating genmodel model out
or a UML2 profile containig OCL constraints).
Matteo
Christian W. Damus wrote:
> Hi, Matteo,
> HTH,
> Christian
>> Hello all,
>> constraints
>> something like:
>> which embeds an OCL parser/validator); but I have serious problems
>> with the validation part (for the papyrus users: the tutorial for OCL
>> constraints doesn't seem to work).
>> please indicate a tutorial explaining how to use OCL constraints
>> embedded in a UML2 profile (likely via the validation frameworks)?
>> Thanks in advance,
>> Matteo
Re: Check of OCL constraints embedded in UML2 profile [message #64431 is a reply to message #64362] |
Wed, 05 November 2008 19:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi, Matteo,
The UML2 run-time provides traceability between your UML profile and the
generated EPackage, so this should work as well with OCL as a dynamic
profile.
Just be sure to register your package and your profile on the various
EMF and UML2 extension points, and you should be fine.
Christian
> Hello Christian,
> Matteo
>> Hi, Matteo,
>> from an OCL text file. It's a pretty bare-bones example of a custom
>> HTH,
>> Christian
>>> Hello all,
>>> constraints
>>> something like:
>>> Thanks in advance,
>>> Matteo
FUDForum. Page generated in 0.03576 seconds
