Home » Language IDEs » Java Development Tools (JDT) » Passing environment variables to ANT
Passing environment variables to ANT [message #64075] Sat, 21 June 2003 16:36 Go to next message
Originally posted by: s.millies.ids-scheer.REMOVE-THIS.de
In my external build script, I call ANT like this:
java org.apache.tools.ant.Main -Dcatalina.home=%CATALINA_HOME%
(The system property catalina.home is accessed inside build.xml for the
compilation of JSPs.)
When configuring an external task to call ANT from Eclipse,
how should I pass this property to ANT?
The only thing I seem to be able to do is set the property directly,
using the current value of %CATALINA_HOME% , which is
of course not what I want.
Instead of accessing the OS's environment variable, I'd also
be happy to use one of the classpath variables from my Java
preference settings, but even that seems impossible.
-- Sebastian
PS: Incidentally, it would also be nice if there were a filter in the
ANT view for all non-descript targets (the hollow arrows).
Re: Passing environment variables to ANT [message #69466 is a reply to message #64075] Sat, 28 June 2003 10:39 Go to previous message
Hi!
Why not access the environment variable inside the ant-script instead of
passing the value as a parameter?
First define the prefix for environment variables ("env" in this case):
<property environment="env"/>
Then access the environment variable:
${env.CATALINA_HOME}
*hth*
Philip
Sebastian Millies wrote in news:bd2fk0$lst$1@rogue.oti.com:
> -- Sebastian
Previous Topic:Runtime Workbench Problem
Next Topic:How does one implement relationships with Lomboz
Current Time: Mon Oct 27 07:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.27673 seconds
