Home » Language IDEs » ServerTools (WTP) » Getting started
Getting started [message #63862] |
Mon, 10 January 2005 12:50 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: davegabol.eircom.net
Hi folks,
Finally back online after a few months and trying to catch up with the
latest version of everything. I have installed Eclipse 3.1M4 and all of the
WTP and associated jars from
http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/in
dex.html
However the web tools don't show up in Eclipse when I start it. I remember
in the original IBM distro you had to unpack a separate jar file from the
download into some directory or another. But I can't find the original
"getting started" guide or any other getting started docs. Do I still need
to unpack a lone jar file to some directory? If not, is unzipping all of the
files at the above link good enough? I've unzipped them all into the same
base dir as Eclipse, so they are all under eclipse/plugins. Any idea what
might I be missing (apart from a brain)? I'm running this on Win ME, and the
original IBM version worked fine.
The only message in the log file is
!ENTRY org.eclipse.core.resources 2 1 2005-01-10 12:37:10.350
!MESSAGE Skipping builder com.ibm.sse.model.structuredbuilder for project
graphtest. Either the builder is missing from the install, or it belongs to
a project nature that is missing or disabled.
which I don't think is relevant.
Many thanks,
Dave.
Re: Getting started [message #63891 is a reply to message #63862] |
Mon, 10 January 2005 13:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I recall that VE and XSD were required as separate downloads for the
original drop. Are they still required (they are not mentioned in the list
of things on the current download page)? Any particular versions if so?
Dave.
Re: Getting started [message #63915 is a reply to message #63862] |
Mon, 10 January 2005 13:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: amnon.netvision.net.il
That's what I am having (see "Newbie installation problem" post).
I haven't got to it yet, but it seems there are manual prerequisites
before this nifty package will start working.
I haven't got to it yet but if you manage to do it before I do, please
post the list of things you put in there so that it will be easier to
follow...
Amnon
Dave Gabol wrote:
> Hi folks,
> dex.html
> Many thanks,
> Dave.
Re: Getting started [message #63936 is a reply to message #63915] |
Mon, 10 January 2005 13:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No problem, I'm hoping that as I work my way through the installation,
setup, and subsequent use of various things, to keep notes and perhaps put
together some docs that might be useful. There are a lot of repetetive
questions on this list. I know nobody wants to keep web pages or FAQs up to
date, it's totally tedious. But I might have a whack at some of it until I
get bored :-)
Dave.
"Amnon I. Govrin" <amnon@netvision.net.il> wrote in message
news:crtv6s$2r2$1@www.eclipse.org...
> follow...
> Amnon
> Dave Gabol wrote:
> > Hi folks,
the
> > dex.html
remember
the
need
the
same
what
the
project
to
> > Many thanks,
> > Dave.
Re: Getting started [message #63979 is a reply to message #63891] |
Mon, 10 January 2005 13:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I notice that XSD is in the emf zip file, so that's one out of the way
anyway.
"Dave Gabol" <davegabol@eircom.net> wrote in message
news:crtusd$269$1@www.eclipse.org...
> Dave.
Re: Getting started [message #64048 is a reply to message #64025] |
Mon, 10 January 2005 14:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Raphael, that's exactly what I did.
The only difference I can see is that I have my old workspaces left in the
Eclipse directory (nothing else except the workspaces). Don't see why that
should stop anything working. But I'll try a clean install of everything and
then import the workspaces afterwards and see if it makes a difference.
Dave.
"Raphael A. Bauer" <raphael.bauer@temis-group.com> wrote in message
news:cru372$g8h$1@www.eclipse.org...
remember
the
> I just veryfied what I did EXACTLY to bring webtools to life - this is
> vital for me beacause my application heavily relies on that.
> First check:
dex.html
> This is the description of how to install webtools M2 and the preqs
> So - you need as download in one directory (as written in the html):
> -- eclipse-SDK-3.1M4-linux-gtk.zip (or the right M4 eclipse for your
> platform - I am using linux, so it's okay)
> -- emf-sdo-xsd-SDK-I200412160800.zip
> -- GEF-SDK-I20041216.zip
> -- JEM-runtime-1.0.2.zip
> -- wtp-1.0M2.zip (The webtools package)
> download them all in one directory (eg /eclipsetest/.) and unzip them.
> You have then a directory with eclipse and all things unzipped
> in the eclipse folder.
> A simple
> - unzip eclipse-SDK-3.1M4-linux-gtk.zip
> - unzip emf-sdo-xsd-SDK-I200412160800.zip
> and so on works fine on my machine...)
> And that's it for me...
> If you start this eclipse it works perfect with all XML/XSD Stuff
> enabled... (I just tested that again... and I am 100% sure - it works)
> Hope this helps - in my case no additional faq or howto is needed,
> because I just have to follow the steps described on the index.html for
> the integration build M2.
> If this doesn't work for you - then there is some bug... Then you can
> should describe in detail what you installed and how you did it - which
> versions/platforms/etc...
> Cheers,
> Raphael
> Btw. If you want extensive xml verification you should follow as well:
> http://www.eclipse.org/webtools/wst/components/xml/xercesInf o.xml
> (mentioned as well in the index.html of the integration build)
> => but that is optional. XML and XSD edition works very fine without
that...
Re: Getting started - NOW WORKING [message #64117 is a reply to message #64048] |
Mon, 10 January 2005 16:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi folks,
Well, I did a clean install after renaming my old eclipse home dir out of
the way...and it all works perfectly. Amnon, I suggest you try the same
thing, it should work.
Thanks for everyone's help,
Dave.
news:cru4vm$r90$1@www.eclipse.org...
and
> Cheers,
> Dave.
> remember
> the
> > First check:
> dex.html
> > A simple
> > Cheers,
> > Raphael
> that...
Re: Getting started - NOW WORKING [message #64140 is a reply to message #64048] |
Mon, 10 January 2005 16:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi All,
Well, I moved my eclipse base dir out of the way and did a clean install. It
all works perfectly now. Amnon, I sugest you try the same, it should work.
Thanks for the help everyone,
Dave.
and
> Cheers,
> Dave.
> remember
> the
> > First check:
> dex.html
> > A simple
> > Cheers,
> > Raphael
> that...
Re: Getting started - NOW WORKING [message #64384 is a reply to message #64227] |
Tue, 11 January 2005 09:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Alexander. Bit late for me but it might save others some time!
Dave.
"Alexander Rupsch" <Alexander.Rupsch@gmx.de> wrote in message
news:crun24$5ro$1@www.eclipse.org...
> Dave Gabol wrote:
> > Hi folks,
of
> A "eclipse -clean" after installing the plugins should prevent you from
> installing everything from the scratch.
> regards.
> Alexander Rupsch
> http://www.dreinhalb.de
Re: Getting started [message #64408 is a reply to message #64025] |
Tue, 11 January 2005 09:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yup, that did the trick.
It is working!
Amnon
Raphael A. Bauer wrote:
>> remember
> First check:
> http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/index.html
> A simple
> Cheers,
> Raphael
> that...
Re: Getting started [message #70155 is a reply to message #63862] |
Sun, 30 January 2005 17:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jdthomp434.aol.com
Dave Gabol wrote:
> Hi folks,
> dex.html
> Many thanks,
> Dave.
I followed the directions for unzipping, in order, the eclipse SDK, emf,
gef, jem, and wtp files. However, when attempting to follow the
guidelines laid out at
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/DataToolsEval.html
I do not have the Data option under other.
Specifically, the directions indicated that I should:
select Window->Show view->Other->Data->Database Explorer
however with my installation, I do not have a Database Explorer.
Can anyone indicate to me what file I missed?
Full File names referenced above:
eclipse SDK: eclipse-SDK-3.0.1-win32.zip
emf: emf-sdo-xsd-SDK-I200412160800.zip
gef: GEF-SDK-I20041216.zip
jem: JEM-runtime-1.0.2.zip
wtp: wtp-1.0M2.zip
Thanks!
JD
Re: Getting started [message #70213 is a reply to message #70155] |
Sun, 30 January 2005 21:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The INITIAL contribution and milestone M1 required Eclipse 3.0.1.
Milestones M2 and higher require the specific versions of the .zips
mentioned on the WTP download page for that build. In M2's case, it
requires Eclipse 3.1M4. WTP 1.0M3 should require Eclipse 3.1M5.
The rdb component milestone plan at
http://www.eclipse.org/webtools/wst/components/rdb/milestone _plan.xml
only mentions functionality for WTP 1.0M3 and beyond, so it may not
be part of 1.0M2 at all.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Getting started [message #70474 is a reply to message #70213] |
Mon, 31 January 2005 16:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Nitin!
I will go back and download the 3.1M4. Since I am not too far into this I
am going to assume (always dangerous when I am involved!) that I should
just kill the 3.0.1 install and start fresh, i.e.
Unzip and Install in order:
Eclipse 3.1M4
emf zip
gef zip
jem zip
wtp 1.0M2 zip
Thanks again for your time and guidance!
JD
Re: Getting started [message #71232 is a reply to message #70474] |
Thu, 03 February 2005 09:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fuglis.gmail.com
JD Thompson wrote:
> Thanks Nitin!
> Eclipse 3.1M4
> emf zip
> gef zip
> jem zip
> wtp 1.0M2 zip
> JD
Well, I'm having the same problem. I installed eclipse 3.1m4, and unzipped
emf-sdo-xsd-SDK-I200412160800.zip, GEF-SDK-I20041216.zip,
JEM-runtime-1.0.2.zip and wtp-sdk-1.0M2.zip into the eclipse directory.
Still I get no Web Services, or at least I can't find them. Any idea what
I'm missing?
Trond
Re: Getting started [message #71272 is a reply to message #71232] |
Thu, 03 February 2005 12:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jmordax.terra.es
> unzipped emf-sdo-xsd-SDK-I200412160800.zip, GEF-SDK-I20041216.zip,
> directory. Still I get no Web Services, or at least I can't find them.
> Any idea what I'm missing?
> Trond
Well, AFAIK WTP M2 hasn't Web Services support yet. I think it is
planified for M3.
Chemi.
Re: Getting started [message #71313 is a reply to message #71232] |
Thu, 03 February 2005 12:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> JD Thompson wrote:
>> Thanks Nitin!
>> Eclipse 3.1M4
>> emf zip
>> gef zip
>> jem zip
>> wtp 1.0M2 zip
>> JD
> I'm missing?
> Trond
Ok, I guess this should answer our questions:
http://www.eclipse.org/newsportal/article.php?id=2193&gr oup=eclipse.webtools
Trond
Current Time: Tue Jul 16 11:31:59 GMT 2024
Powered by FUDForum. Page generated in 0.06065 seconds
