Re: Cascading parameter default value problem [message #636997 is a reply to message #636844] |
Wed, 03 November 2010 16:58 |
Can you post the report and version you are using? Your syntax works on
my report. You could also try:
parseInt(BirtDateTime.year(BirtDateTime.now()));
Jason
On 11/3/2010 1:24 AM, Yuri wrote:
> I am trying to create a cascading parameter group and set e default
> value for a parameter type integer from
> BirtDateTime.year(BirtDateTime.now()).
> This function returns integer, but I am getting a data type mismatch.
> Unfortunately I cannot attach a screen shot at this time.
Re: Cascading parameter default value problem [message #637211 is a reply to message #636844] |
Thu, 04 November 2010 15:38 |
Yuri Messages: 5 Registered: October 2010 |
Here is the project code.
Try to change the default value of the parameter Year to
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<cascading-parameter-group name="Start" id="618">
<property name="dataSet">year</property>
<property name="dataSetMode">single</property>
<parameters>
<scalar-parameter name="Year" id="619">
<property name="valueType">dynamic</property>
<property name="isRequired">true</property>
<property name="dataSetName">year</property>
<expression name="valueExpr">row["year"]</expression>
<property name="dataType">integer</property>
<property name="controlType">list-box</property>
<property name="fixedOrder">true</property>
<structure name="format"/>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
</parameters>
<data-sources>
<script-data-source name="Script" id="562">
<method name="beforeOpen"><![CDATA[1;]]></method>
<method name="beforeClose"><![CDATA[1;]]></method>
<method name="afterOpen"><![CDATA[1;]]></method>
<method name="afterClose"><![CDATA[1;
]]></method>
<method name="close"><![CDATA[1;]]></method>
</script-data-source>
</data-sources>
<data-sets>
<script-data-set name="year" id="613">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">year</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">year</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Script</property>
<method name="open"><![CDATA[flag=0;]]></method>
<method name="fetch"><![CDATA[if (!flag) {
row["year"] = 2001;
flag = 1;
return truel
}]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="599"/>
<text-data id="600">
<expression name="valueExpr">"Start = " + params["Year"].value + " " + params["Month"].value</expression>
</text-data>
</body>
<property name="pageVariables">
<variable-element name="CurrentYear">
<expression name="value" type="javascript">parseInt(BirtDateTime.year(BirtDateTime.now())).toFixed(0)</expression>
<property name="type">report</property>
</variable-element>
<variable-element name="mList">
<expression name="value" type="javascript">["Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"];</expression>
</variable-element>
</property>
</report>
Re: Cascading parameter default value problem [message #637241 is a reply to message #637211] |
Thu, 04 November 2010 17:02 |
This appears to be a bug. Can you log it? As a work around use a
getDefaultValueList script on the parameter. And enter the following script:
importPackage( Packages.java.util );
cal = Calendar.getInstance();
tyear = cal.get(Calendar.YEAR);
tyear;
See attached modified example
Jason
id="1">
<parameters>
<parameters>
<expression name="labelExpr">row["year"]</expression>
<method
name="getDefaultValueList"><![CDATA[importPackage( Packages.java.util );
tyear;]]></method>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
</parameters>
<data-sources>
]]></method>
</data-sources>
<data-sets>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<method name="open"><![CDATA[flag=false;]]></method>
row["year"] = 2001;
flag = true;
return true
}else{
return false;
}]]></method>
</script-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<data id="620">
<structure name="numberFormat">
<property name="category">Custom</property>
<property name="pattern">#0</property>
</structure>
<list-property name="boundDataColumns">
<structure>
<property name="name">Year</property>
<expression name="expression"
type="javascript">params["Year"]</expression>
<property name="dataType">string</property>
</structure>
</list-property>
<property name="resultSetColumn">Year</property>
</data>
</body>
type="javascript">parseInt(BirtDateTime.year(BirtDateTime.now())).toFixed(0) </expression>
</variable-element>
</variable-element>
</property>
</report>
> id="1">
> <parameters>
> <parameters>
> </scalar-parameter>
> </parameters>
> </parameters>
> <data-sources>
> ]]></method>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> row["year"] = 2001;
> flag = 1;
> return truel
> }]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <text id="599"/>
> </text-data>
> </body>
> </variable-element>
> </variable-element>
> </property>
> </report>
FUDForum. Page generated in 0.03550 seconds
