Home » Language IDEs » PHP Development Tools (PDT) » [Q] Installing PHP for Eclipse
[Q] Installing PHP for Eclipse [message #63287] Tue, 18 December 2007 15:09 Go to next message
Eric  is currently offline Eric Friend
First, I am running Mac OS X 10.5.1 (Leopard)
I would like to be able to use the
Help > Software Updates > Find and Install...
to get things installed...it just seems easier to go this route -
assuming that it works.
So, I select the
Search for new features to install
option and press 'Next >'.
I then select 'New Remote Site...' and enter
URL: http://downloads.zend.com/pdt
I check:
Europa Discovery Site
PDT
The Eclipse Project Updates
and press 'Finish'.
The update manager searches for some stuff and I then get the 'Updates'
dialog.
In the 'Select the features to install' list, I see:
PDT
PDT Updates
I check & select PDT and get an error which states:
Zend Debugger Feature (5.2.12.v20071210) requires feature
"org.eclipse.php_feature (1.0.0)", or later version.
How can I install this using Help > Software Updates > Find and
Install...?
If I check & select PDT Updates, I get an error which states:
PDT Feature (1.0.1.v20071210-79-78E7QYGHEPYPG) requires feature
"org.eclipse.wst (2.0.0)", or compatible.
Install...?
If I check and select either, both or neither 'PDT' and 'PDT Updates'
and press the 'Select Required', nothing extra is selected.
Should I be able to get this stuff installed using Help > Software
Updates > Find and Install...?
Re: [Q] Installing PHP for Eclipse [message #63314 is a reply to message #63287] Tue, 18 December 2007 15:26 Go to previous messageGo to next message
Did you do the "Select required" thing mentioned in the PDT/Install
FAQ/Wiki thing? I just installed PDT with it recently and that button
sorted out the dependencies (I believe).
Re: [Q] Installing PHP for Eclipse [message #63337 is a reply to message #63314] Tue, 18 December 2007 15:48 Go to previous messageGo to next message
Sorry, re-read your message and yoiu do mention "Select required".
I'm sure it did add stuff for me, tho'...
Re: [Q] Installing PHP for Eclipse [message #63359 is a reply to message #63287] Tue, 18 December 2007 17:06 Go to previous messageGo to next message
Alon Peled is currently offline Alon PeledFriend
Hi Eric,
The PDT project is also based on the Webtools project, which you also need
to install.
Add the following site:
http://download.eclipse.org/webtools/updates
Make sure it is checked along with Europa & PDT.
When you press the 'Select Required' the relevant feature should be checked.
Good luck,
Alon
On 12/18/07 5:09 PM, in article 1i9b9vi.1dpxvq4cyd67gN%ericgorr@gmail.com,
> So, I select the
> I check:
> PDT
> and press 'Finish'.
> dialog.
> PDT
> PDT Updates
> Install...?
> Install...?
Re: [Q] Installing PHP for Eclipse [message #63381 is a reply to message #63337] Tue, 18 December 2007 17:22 Go to previous messageGo to next message
Yes, if I check and select PDT & PDT Updates and then press 'Select
Required", nothing extra is selected.
If it matters, I am using Eclipse SDK Version 3.3.1.1 with Build id:
M20071023-1652.
Re: [Q] Installing PHP for Eclipse [message #63403 is a reply to message #63359] Tue, 18 December 2007 17:32 Go to previous messageGo to next message
Thanks. I'm sure that's another piece of the puzzle, however, when I try
to install Webtools, I get the error message:
WST Common UI (2.0.1.v200709110622-7C5EH2E9RvTVnijrspVz0bgOmfz-)
requires plug-in "org.eclipse.draw2d (3.2.0)", or compatible.
Now, if I search for org.eclipse.draw2d, find
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. draw2d.doc.i
sv/reference/api/org/eclipse/draw2d/package-summary.html
or
http://tinyurl.com/ywley8
http://preview.tinyurl.com/ywley8
(if you want to check to see where the tiny url goes first)
which appears to be documentation on the draw2d package on which the
Webtools package seems to depend.
But, based on the documentation here, I cannot determine the location
from which I can download this package.
Perhaps it should be:
http://download.eclipse.org/draw2d/updates
(following the same form as webtools)
I haven't tried this yet, but I am about to. When one gets one of those
cryptic error messages about a required plug-in, what is the
easiest/best way to determine where it can be obtained?
Thank you.
Alon Peled <alon@zend.com> wrote:
> Hi Eric,
> to install.
> Good luck,
> Alon
> > So, I select the
> > I check:
> > PDT
> > and press 'Finish'.
> > dialog.
> > PDT
> > PDT Updates
> > Install...?
> > Install...?
Re: [Q] Installing PHP for Eclipse [message #63425 is a reply to message #63403] Tue, 18 December 2007 18:00 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
PDT has the following pre-reqs
# Java 5 JRE
# Eclipse SDK v3.3.1.1
# EMF SDO XSD 2.3.1
# GEF 3.3.1
# DTP 1.5.1
# WTP 2.0.1
this info can be found on the download pages, eg
http://download.eclipse.org/tools/pdt/downloads/?release=S20 071213-M1
I would have thought that the update site would define the pre-reqs but I don't know
how that works (ie where the info is stored and how eclipse processes it)
Dave Kelsey
> or
Re: [Q] Installing PHP for Eclipse [message #63447 is a reply to message #63425] Tue, 18 December 2007 19:47 Go to previous messageGo to next message
thanks.
In any case, I tried downloading the '
pdt-all-in-one-S20071213_M1-macosx-carbon.tar.gz' from the site you
mentioned and went to go see if there were any dependencies that weren't
included in this all-in-one and I found a couple...
The Eclipse Project Updates requires:
Eclipse RCP Patch 1 for 3.3.1 (3.3.1.v20071002_331) requires feature
"org.eclipse.rcp (3.3.1.R33x_r20070802-8y8eE8sEV3Fz0z0GlHJrXvTAUS)".
The XML Schema Infoset Model (XSD) Updates requires:
EMF Model Query OCL Integration (1.1.0.v200706071712-10-7w311817182823)
requires plug-in "org.eclipse.emf.ocl (1.1.0)", or compatible.
I'm assuming this is a genuine problem...
> # Java 5 JRE
> # EMF SDO XSD 2.3.1
> # GEF 3.3.1
> # DTP 1.5.1
> # WTP 2.0.1
> don't know how that works (ie where the info is stored and how eclipse
> processes it)
> Dave Kelsey
> > or
Re: [Q] Installing PHP for Eclipse [message #63491 is a reply to message #63287] Wed, 19 December 2007 16:35 Go to previous messageGo to next message
> Install...?
Yes, you should. I'm not sure why it is not working as expected in your
case, but here's one shot-in-the-dark: A few days ago I responded to a
newsgroup question about a possible bug in the Select Required
functionality. The person asking the question seemed to observe that
unless a particular update site was expanded in the list, Select
Required would not search it. So can you try your scenario again, this
time making sure to expand the Europa site before hitting Select Required?
Hope this helps,
Eric
Re: [Q] Installing PHP for Eclipse [message #63537 is a reply to message #63491] Wed, 19 December 2007 17:11 Go to previous messageGo to next message
This appears to be noted in http://wiki.eclipse.org/PDT/Installation
> * Expand the Europa Discovery site to resolve dependencies.
> Collapsed sites will not be searched.
Re: [Q] Installing PHP for Eclipse [message #63581 is a reply to message #63491] Wed, 19 December 2007 20:57 Go to previous messageGo to next message
> > Install...?
> Hope this helps,
> Eric
Thanks. I'll play around with it a bit more and see if I can get it
working. This whole Eclipse thing looks pretty cool.
It seems silly that collapsed sites would not be searched...I assume
this is considered to be a bug...?
Re: [Q] Installing PHP for Eclipse [message #63678 is a reply to message #63581] Thu, 20 December 2007 14:37 Go to previous messageGo to next message
Seems to be a "known" limitation that is just not presented to the user:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203473
Eric
Re: [Q] Installing PHP for Eclipse [message #63700 is a reply to message #63678] Thu, 20 December 2007 15:05 Go to previous messageGo to next message
Interesting.
I am still wondering why such a feature even needs to exist. It seems
the solution used by MCPAN, MacPorts, Fink, etc. for a long time
(decades?) is far better...if you try to install something, that
something knows what it needs and the system can find and install the
dependencies automatically. I believe the success of these systems has
shown this method to be a good solution.
The bug report seems to be trying to fix a feature that, as near as I
can tell, is fundamentally and inherently flawed.
Re: [Q] Installing PHP for Eclipse [message #63767 is a reply to message #63700] Fri, 21 December 2007 14:24 Go to previous message
> Interesting.
Hence the effort underway in Eclipse 3.4 to replace it. The bug talked
about that.
Eric
Previous Topic:xdebug not working
Next Topic:PHP Project Outline is not working with remote project
Current Time: Fri Dec 27 15:11:21 GMT 2024
Powered by FUDForum. Page generated in 0.04094 seconds
