Home » Archived » Visual Editor (VE) » Renaming is a waste of time
Renaming is a waste of time [message #62321] |
Tue, 28 September 2004 10:38  |
Originally posted by: lrv.libero.it
Hi everybody,
i'm using eclipse 3.0.1 and VE 1.0 , JRE 1.4.2.05, on a P4 1800 with 1 Gb
of RAM;
when i try to rename a field from Java Beans view in VE it takes about 20
seconds
for a label an about 1 minute for a composite containing some widgets.
The process often ends with an error and the design view result is empty.
I wonder if this is a normal behavior for VE or if i'm doing something in
the wrong way. If i stop roundtripping ,make a lot of changes, and restart
roundtripping the process always ands with an error and i can recover the
previous state only closing and reopening the file.
Any suggestions?
Thanks anyway.
Re: Renaming is a waste of time [message #62638 is a reply to message #62392] |
Wed, 29 September 2004 03:43   |
Gili Mendel wrote:
> Lrv wrote:
> > Hi everybody,
> > of RAM;
> > seconds
> > Any suggestions?
> > Thanks anyway.
> If the instance variable or the method is public, VE will the Eclipse
refactoring process (quite slow and require
> saves). If both are private, it will use the local rename - significantly
faster.
> How big is your file? Can you attache a .log
Hi Gili,
my file is less than 200 lines of code , the variables i rename are
private class variable. In Swing the renaming process is slow but always
successfull; in SWT the renaming process is much more slow than in Swing
and it often fails;
i don't know how to attach a file to this message so i paste the text from
log: (generated by the renaming of only one variable )
!SESSION set 29, 2004 08:58:15.531
eclipse.buildId=unknown
java.version=1.4.1_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
!ENTRY org.eclipse.ve.java.core 4 0 set 29, 2004 08:58:15.531
!MESSAGE Invalid PropertyDecorator
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:17.453
!MESSAGE
+++ Warning +++: Wed Sep 29 08:58:17 CEST 2004 Project
(com.finantix.ide.modeler)-VM for
com.finantix.ide.modeler:err>org.eclipse.swt.SWTException: Failed to
execute runnable (java.lang.NullPointerException)
!MESSAGE
(com.finantix.ide.modeler)-VM for com.finantix.ide.modeler:err>
!MESSAGE
(com.finantix.ide.modeler)-VM for com.finantix.ide.modeler:err> at
org.eclipse.swt.SWT.error(SWT.java:2691)
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:17.468
!MESSAGE
org.eclipse.swt.SWT.error(SWT.java:2616)
!MESSAGE
!MESSAGE
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:109)
!MESSAGE
!MESSAGE
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
!MESSAGE
!MESSAGE
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:17.484
!MESSAGE
!MESSAGE
org.eclipse.ve.internal.swt.targetvm.Environment$1.run(Envir onment.java:37)
!MESSAGE
!MESSAGE
(com.finantix.ide.modeler)-VM for com.finantix.ide.modeler:err>*** Stack
trace of contained exception ***
!MESSAGE
!MESSAGE
com.finantix.ide.modeler:err>java.lang.NullPointerException
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:17.500
!MESSAGE
org.eclipse.ve.internal.swt.targetvm.ControlManager$6.run(Co ntrolManager.java:124)
!MESSAGE
!MESSAGE
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
!MESSAGE
!MESSAGE
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:17.515
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.ui 4 4 set 29, 2004 08:58:18.328
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 set 29, 2004 08:58:18.328
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!MESSAGE *** SWT nested exception
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.ve.internal.swt.ControlGraphicalEditPart.activat e(ControlGraphicalEditPart.java:106)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:199)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:750)
at
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.acces s$0(CompositeGraphicalEditPart.java:1)
at
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart$1.run (CompositeGraphicalEditPart.java:115)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 set 29, 2004 08:58:18.343
!ENTRY org.eclipse.ui 4 0 set 29, 2004 08:58:18.343
!STACK 0
at
at
at
at
at
!STACK 0
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.getIm age(JavaBeanTreeEditPart.java:205)
at
org.eclipse.gef.editparts.AbstractTreeEditPart.refreshVisual s(AbstractTreeEditPart.java:137)
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.refre shVisuals(JavaBeanTreeEditPart.java:230)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:699)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:233)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:196)
at
at
org.eclipse.ve.internal.swt.CompositeTreeEditPart.access$0(C ompositeTreeEditPart.java:1)
at
org.eclipse.ve.internal.swt.CompositeTreeEditPart$1.run(Comp ositeTreeEditPart.java:58)
at
at
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:24.734
!MESSAGE
+++ Warning +++: Wed Sep 29 08:58:24 CEST 2004 Project
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:24.750
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:24.781
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 set 29, 2004 08:58:24.796
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.ui 4 4 set 29, 2004 08:58:28.984
!ENTRY org.eclipse.ui 4 0 set 29, 2004 08:58:28.984
!STACK 0
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 set 29, 2004 08:58:29.00
!ENTRY org.eclipse.ui 4 0 set 29, 2004 08:58:29.00
!STACK 0
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.deact ivate(JavaBeanTreeEditPart.java:138)
at
org.eclipse.gef.editparts.AbstractEditPart.deactivate(Abstra ctEditPart.java:269)
at
org.eclipse.ve.internal.cde.emf.DefaultTreeEditPart.deactiva te(DefaultTreeEditPart.java:79)
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.deact ivate(JavaBeanTreeEditPart.java:148)
at
org.eclipse.ve.internal.swt.CompositeTreeEditPart.deactivate (CompositeTreeEditPart.java:92)
at
at
at
at
at
at
org.eclipse.ve.internal.java.core.CompositionComponentsTreeE ditPart.deactivate(CompositionComponentsTreeEditPart.java:78 )
at
org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsTreeEditPart.deactivate(SubclassCompositionComponentsTreeE ditPart.java:71)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:371)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.loadModel(JavaVisualEditorPart.java:301)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$16.run(JavaVisualEditorPart.java:1672)
at
at
at
at
at
Re: Renaming is a waste of time [message #62733 is a reply to message #62685] |
Wed, 29 September 2004 09:05   |
Hi Joe,
the answer to your first question is yes, renaming the field in the property
sheet is faster and without errors.
"Joe Winchester" <winchest@uk.ibm.com> wrote in message
news:cjdvjh$1f5$1@eclipse.org...
> Hi Lrv,
20
> > seconds
> If you rename the field using the "fieldName" property in the property
> sheet is this faster ? The property sheet rename should go through the
> same codepath as the quick fix "local rename". A full rename going
> requires doing a full Java editor refactor which a) saves the file if it
> is dirty and b) will check for any external references in other files to
> see if they also need refactoring. As Gili said, there should be
> optimization that the "rename" option intelligently decides which path
> to take, and uses the faster "local rename" one whereever it can, and
> only does a full refactor is the field and/or getter is public (and
> therefore could be being used by another Java class.
> I just did a quick test and the rename option is working as designed and
> using the local rename if the field is private enough, however there is
> also a reload occuring afterwards. This is deactivating the edit parts
> and is what is causing you a problem and shouldn't happen.
> I've opened a bugzilla 75257 for us to look at this. Can you please add
> yourself as a cc member to this, and also post the .java file that is
> your test case that throws the .log file you have.
> Best regards and many thanks for pointing this out to us,
> Joe Winchester
Re: Renaming is a waste of time [message #65452 is a reply to message #65389] |
Thu, 07 October 2004 12:30  |
I don't know anything about "Similiar Variable exist". Never seen that.
But the hang is a known bug which we have fixed and will be in the
1.0.1.1 fixpack when available. There is a maintenance (development)
build with the fix available on the download site, but it is not the
final release version of it yet.
Rich Kulp
Re: Renaming is a waste of time [message #599916 is a reply to message #62321] |
Tue, 28 September 2004 12:41  |
Lrv wrote:
> Hi everybody,
> of RAM;
> seconds
> Any suggestions?
> Thanks anyway.
If the instance variable or the method is public, VE will the Eclipse refactoring process (quite slow and require
saves). If both are private, it will use the local rename - significantly faster.
Re: Renaming is a waste of time [message #599995 is a reply to message #62392] |
Gili Mendel wrote:
> Lrv wrote:
> > Hi everybody,
> > of RAM;
> > seconds
> > Any suggestions?
> > Thanks anyway.
faster.
Hi Gili,
and it often fails;
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Renaming is a waste of time [message #600017 is a reply to message #62321] |
Wed, 29 September 2004 05:39  |
Hi Lrv,
> seconds
Joe Winchester
Re: Renaming is a waste of time [message #600035 is a reply to message #62685] |
Hi Joe,
> Hi Lrv,
20
> > seconds
> Joe Winchester
Re: Renaming is a waste of time [message #600087 is a reply to message #63069] |
Wed, 29 September 2004 11:24  |
I meant attach your .log file to bug 74792.
Rich Kulp wrote:
> There is already an open bug on rename from popup menu ALWAYS uses the
> full refactor instead of the local rename. BUT we need track down why
> the full refactor causes errors too.
> This is the bug for rename from popup not going through local:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=74790
> Please attach your .log file to this defect and add yourself as cc. It
> is a similiar type error to what you are getting and we can try to fix
> both at the same time.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=74792
> To attach, use the "Create a new attachment" link near the middle top of
> the bugzilla page.
Rich Kulp
Re: Renaming is a waste of time [message #600993 is a reply to message #62733] |
Thu, 07 October 2004 11:13  |
Lrv wrote:
> Hi Joe,
> property sheet is faster and without errors.
Sometimes renaming in the property-sheet leads to an error in the
status-line "Similar Varable exist" or so, which is not the case and then
followed by "The editor is busy at this time and cannot be changed" and
finally the Eclipse hangs (sometimes).
By the way the VE did the reneaming at all.
spunti
Using Eclipse3.0.1 and VEP1.0.1 at Gtk/Linux
Re: Renaming is a waste of time [message #601013 is a reply to message #65389] |
Rich Kulp
Current Time: Tue Oct 21 01:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.08693 seconds
