Re: 'atexit' error when upgrading to xdctools 3.16 [message #754690 is a reply to message #630420] |
Thu, 03 November 2011 20:52 |
alan Messages: 2 Registered: November 2011 |
hello
i'm having the same problem as you, you mentioned that the workaround did the trick, but i don't have clear how you modify the file linkcmd.xdt i'm positng the way mi file looks, hopefully you can tell where to modify it, since i know this it's an old post, thanks in advance
* Copyright (c) 2008 Texas Instruments and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* eclipse.org/legal/epl-v10.html
* Contributors:
* Texas Instruments - initial implementation
/* Linker templates are passed the following arguments:
* $out - an open file stream for the generated linker
* command file
* $args[] - array of zero or more libraries that should be linked
* with (in the order they appear in the argument list)
* We can't add "'s around names; otherwise the GNU linker looks for names
* with "'s.
* The GNU linker accepts any text file as "command files", so there is no
* need to use a special option to identify them. In fact, if you use the
* -T option you must also include the default linker command file (which
* defines the memory map, sections, etc). By not using -T, this command
* file "accumulates" with the default.
/* get the GNU compiler version from the version number returned by ITarget */
var VERSION = this.build.target.version.split(',')[2] - 0;
/* guess(!) the default leading prefix convention for this compiler */
var PREFIX = this.build.target.os == "Windows" ? "_" : "";
/* this file was generated by linkcmd.xdt from the gnu.targets package */
/* function aliases */
%if (prog.build.profile.match(/blas/) == null) {
% for (var keys = this.$$aliases.keys(); keys.hasMoreElements(); ) {
% var key = keys.nextElement();
`PREFIX + key` = `PREFIX + this.$$aliases.get(key)`;
%if ($args.length > 0) {
/* input libraries */
INPUT(
%for (var i = 0; i < $args.length; i++) {
"`$args[i]`"
%var _utils = xdc.loadCapsule("gnu/targets/linkUtils.xs");
%/* Mingw compilers do not work with the SECTIONS directive.
%if (prog.build.target.$name != "gnu.targets.Mingw") {
SECTIONS {
`_utils.genSections(prog)`
%if (xdc.om['xdc.runtime.Text'].isLoaded != true) {
ASSERT(ADDR(xdc.noload) + SIZEOF(xdc.noload) < ADDR(.rodata)
|| ADDR(.rodata) + SIZEOF(.rodata) < ADDR(xdc.noload),
"Sections .rodata and xdc.noload overlap. See xdc.runtime.Text.isLoaded for more.")
%} // end of the workaround for Mingw
* @(#) gnu.targets; 1, 0, 1,370; 11-25-2009 10:23:05; /db/atree/library/trees/xdctargets/xdctargets-b28x/src/
FUDForum. Page generated in 0.05532 seconds
