Home » Modeling » EMF » [CDO] bad performances for few objects(retrieving 58000 objects takes 5 minutes)
[CDO] bad performances for few objects [message #629413] |
Tue, 28 September 2010 08:04 |
Guillaume P. Messages: 69 Registered: June 2010 Location: Toulouse, France |
Member |
I'm currently working on creating mock-ups for a project we are just starting. This project has several needs which match with the CDO technology (EMF model, remote access, revisions, offline mode, ...).
So I'm trying to use CDO in a project example since few days, but I have big performance problems: My standard model has only about 58000 objects for 26 classes (so i imagine the structure in the generated database should be approximatively the same), but retrieving the biggest tables takes almost 1 minute !
As the total model is about 10Mo, I tried to retrieve all the objects at the start of the software (making local, and so faster future accesses), but I have to retrieve objects one by one if I want them to be stored in my local model (a query "Select cdo_id FROM alltables" doesn't seems to store objects in the local model.
Well, i'm blocked here. And with such performances, the only solutions i have is to renounce using CDO and to implement my own solution (which will be nearly the same).
Could someone give me some trick to solve this problem ?
Thank you,
Guillaume
Note: I'm using the default h2 database, and i followed the Tweaking CDO Performance
[Updated on: Tue, 28 September 2010 12:24] Report message to a moderator
Re: [CDO] bad performances for few objects [message #629434 is a reply to message #629413] |
Tue, 28 September 2010 09:28 |
--------------060902030903080506010900
Hi Guillaume,
I'm not sure if you experience performance problems when storing objects (i.e. committing transactions) or when loading objects. I suspect you meant the latter.
By default CDO loads objects on demand and that can cause many server round trips. Sometimes it's better to load sub trees of your model with one server roundtrip. Please try CDOObject.cdoPrefetch() and note that this method is also present and functional for CDOResources (because they are CDOObjects as well).
Does that help?
Cheers
/Eike
Contact: http://www.esc-net.de Blogger <http://thegordian.blogspot.com>Twitter <http://twitter.com/eikestepper>Linkedin <http://de.linkedin.com/in/eikestepper>Xing <http://www.xing.com/profile/Eike_Stepper>
Article: What exactly is inside that p2 repository? < http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html>
I'm speaking at Eclipse Summit Europe 2010 <http://www.eclipsesummit.org/>
Am 28.09.2010 10:04, schrieb Guillaume P.:
> Hello,
> Thank you,
> Guillaume
> Note: I'm using the default h2 database, and i followed the http://wiki.eclipse.org/Tweaking_CDO_Performance
Content-Type: multipart/related;
boundary="------------060407050307050600030504"
--------------060407050307050600030504
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi Guillaume,<br>
<br>
suspect you meant the latter.<br>
<br>
CDOResources (because they are CDOObjects as well).<br>
<br>
Does that help?<br>
<br>
<!--WISESTAMP_SIG_38888_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers<br>
/Eike<br>
</div>
<div style="padding: 5px 0pt; font-family: arial,sans-serif;
font-size: 13.3px;"><span style="color: gray;">Contact: <a
href="http://www.esc-net.de">http://www.esc-net.de</a></span>
<a href="http://thegordian.blogspot.com" style="padding: 0pt
2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part1.09090702.03050304@esc-net.de" alt="Blogger"
style="vertical-align: middle; padding-bottom: 5px;"
border="0" height="16" width="16"></a><a
href="http://twitter.com/eikestepper" style="padding: 0pt
src="cid:part2.03050606.09030907@esc-net.de" alt="Twitter"
href="http://de.linkedin.com/in/eikestepper" style="padding:
0pt 2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part3.07060504.00070701@esc-net.de"
alt="Linkedin" style="vertical-align: middle;
padding-bottom: 5px;" border="0" height="16" width="16"></a><a
href="http://www.xing.com/profile/Eike_Stepper"
style="padding: 0pt 2px; color: blue; font-size: 10pt;"
_service=""><img
src="cid:part4.06080402.09030008@esc-net.de" alt="Xing"
border="0" height="16" width="16"></a></div>
<div style="color: gray; font-size: 13.3px; padding-bottom:
5px;">Article: <span style="color: blue; text-decoration:
underline;"><a
href=" http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html"
undefined="">What exactly is inside that p2 repository?</a></span></div>
<div><br>
<a href="http://www.eclipsesummit.org/"><img
src="cid:part5.06060702.01030401@esc-net.de" alt="I'm
speaking at Eclipse Summit Europe 2010" border="0"
height="100" width="100"></a>
<br>
<br>
</div>
</div>
</span><!--WISESTAMP_SIG_38888_END--><br>
<br>
<blockquote cite="mid:i7s7d6$3kn$1@news.eclipse.org" type="cite">Hello,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thank you,
<br>
Guillaume
<br>
<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Tweaking_CDO_Performance">http://wiki.eclipse.org/Tweaking_CDO_Performance</a>
<br>
</blockquote>
</body>
</html>
Content-Type: image/png;
name="blogger.png"
Content-ID: <part1.09090702.03050304@esc-net.de>
Content-Disposition: inline;
filename="blogger.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAMAAAAoLQ9TAAAABGdBTUEAAK/I NwWK6QAAABl0
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAADkUExURf9xEv9m AP////9lAP+Q
SP9kAP9jAP9fAP9nAf9vD//x5/9hAP/iz/9iAP9eAP/s4P9vEP9yEv9qAP9q B/+LRP+we/90
I/+RSP/z6/+jZv/y6P+8kP/59f5yE//awf/Ttv9hAf9nAv/17v+4if9sC/9o BP+bWP/r3v/k
0v+wfP+QRv/o2f9gAP+OQ/93HP/l0/+0gv/Rsv/9/P/j0P+pcP+0hf/dx//D m//+/v+td/9o
AP+NQv/Yvf+zgv/x6P/q2/9xG//p2f9pAP/s3//8+fxxE//ex/+AK/9oCP/j 0f/Uuv///4Xw
StcAAABMdFJOU/////////////////////////////////////////////// ////////////
/////////////////////////////////////////wCejeTMAAAAsklEQVR4 2kSP1w6DMBAE
7cMGQg0hvffee++d//+f2IaIeTlppNXtIo88UAjxEIlhjCUG5lwJQuwoulqh FuUGcWGSiTF7
bt40EEoXBKtyIPQS5PffFqyHlhCS2obTK5kDmJ8lXxgA0zsPXer0L3zSUVmI D9ip3SC+hKwQ
2CxCtXYYL25gu1S8bf4jib5fTM+MNE079jom/+KwJUojwnAVifcQ46jM4M23 BHmkEK53iPcT
YACE/Q4KzoVQVwAAAABJRU5ErkJggg==
name="twitter.png"
Content-ID: <part2.03050606.09030907@esc-net.de>
filename="twitter.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAABxUlE QVQ4y4WTMW4U
QRBFX3X3zoy8FgZphTCYAEg4gAPEYbgBJEgEXIALkHMfAjIwItnAAfLK2JYB r3dmuj7BzI5m
2WBLqqzq//q/fxt9NTmrzo7MCIhgRpWSsaMSgEta5czcjYtWTKPxfALZXTEE 2wmAxLXD11VL
BZy2MAuJB/iuA3oAoJb4lUUCVkAGTM5t06gjATMjBiPFaFsADvx1MTFoBd/q zHkMeLcLgCEe
JqjbrCJ1IAkghGDz20Z/XEzMMMTnZTsSYANMAl7fq7YlZOBaUCCk4WowwyRA mBmL7CxcmwDu
rh+rzKU71YhQ/dnr8VbiaRF4MgmbAAZkxJU7lRk3Wby5W3FcJlbSICAjZjFS jJ42rSXWgoWL
fYPfLvaCMTVxJ0XoJTmQ/stF6GPABDhzcepi7uJ74yQDuXcDErjjGhkwNvHx xCjMOMkCg3eX
S85zyVEMtGt24GWVxvsM5yi3+nBV8/7iBmJv0gaZQMZhNL4cHXBYdDkY7HQL vD0oebVfQuud
a8FGHSAaP1vnpMmbHgDEECwafLq/x8fZlGfJKCVKiapvXLyoEsdl3JYwBMpd uW1YEjlz4aMh
AY+iURiU/Vf/B6EE4kjfs5YLAAAAAElFTkSuQmCC
name="linkedin.png"
Content-ID: <part3.07060504.00070701@esc-net.de>
filename="linkedin.png"
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAACGklE QVQ4y6WTO2sU
URTHf3dmdp0kTnZJzErSrPjKYqNY2GljodhoLRLB1sLCD2DrZxAsfCAE/AaC grY+SBQSFTSC
xizGzZ3MTiYz92UxY5KNYuOBP+eew/3/73lwxfWHT9yjuR8YL0CwyxygAAPo Cqr0ntFcvjBB
cH++x8WzJzm8v/EnWVdks0PEgNWO95/XePD4HZ4ADk6MAhD6Hs26/08yBjwr ODrZBK0JADyv
LP7GsX2Evse9xR5Lsvgr+XfsO7ctoKwj9AWh7wEQIFCF+3sFGjCmgiJwQFwY Yge3X3cZrwXM
r2SDg9tJ1rokaw1alRXI3NAO61w60AAHTkE7qtNu1PjSUywsb3L60AgjNcHz hZgXb39WApoA
C3FqsIGjMxYC8OZbxlQU0GmFTLdCznWireV0pobYSDKevuzilMZDg0wN/cxu XdrMLVqX53TT
cu3OJ87cmmdlrQBgemoYKTMwqhSI+4Z0QMBhjANgcTnj1UdJHGd8Xc0AmBit Ecu0moGGODH0
h7cF8tyidSmgjSWWG6AUWpkypw1xLwXA4z8tQINcN/T3moEWtLZbr0mZQV5s 55RFJuU8RHR1
1iWtIzQ8nxOtIVCw9D2lWbM06w4ZZ8wtrEJRcLw9TDMUyKRg7kOPSHQR0ZVZ lyRjMDkOOVAU
FfLS57viHRaJLsHM+THuPtuDUgLTW2U0X672t47rrw82vOu/z9w8xS+MkDzV Boy6+QAAAABJ
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.06080402.09030008@esc-net.de>
filename="xing.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAACXBIWXMAAAsT AAALEwEAmpwY
AAABsklEQVR42mP8//8/AymAEb+G1x9333hU9fffZy52ZTONrQQ0/P7z7sLd hJfvN7Mw80mL
ROkqTodqAIKvv379+fuXhZmZh50dpv7f49dLLt1LYWD4ryRZCETsrJIIDYdu 3y5fu16AizPE
0CTFzgoo8fPXoxPX/T9/v8DHbWCito6LXRHFDw/evnXpm3D39Ws1Eck9xVmy wqLP3/SevlXC
ysKtLtuoJFmMxdObL17ymzqN8S9LnZddua/VrUcWD149FRNwNFFby8oiiEXD itNnImfN5WTi
nBhu7Gvw5OLdiv+MQnqKU6WEI7AE6+vPnx17+68+fmGrJL0wRe/rl/jbL94r isfqKs1kZuJE
1/Dt16/27TtatmzjYeZcnuZpqnDi3J16FmZxYDhKCAViibiVp8+Ur1v39N0H X12DFRkJ33/u
O3LVk+E/i5xYqq7iNCwaXn769PLTZ0ZGBnFePjE+3j9/3155kPvk9XIudgV9 5XnCfI6Ek8a7
T4dO3vD4+++HlHC4kepywhr+/P0ITEIPXk5jZxXTVpgE1EY48X36euHs7fBv P+8CVespzYGH
FSOpyRsAAuDh4a3m5z0AAAAASUVORK5CYII=
Content-Type: image/gif;
name="100x100_speaking.gif"
Content-ID: <part5.06060702.01030401@esc-net.de>
filename="100x100_speaking.gif"
R0lGODlhZABkAOZ/APb3+VNYfigtUDRDchhWpwM6mkRXjThrsCdirVJ7u0p2 uExflWyGrQU0
asnX6aq31ImZUxRFoaOqOWaIwgRGlubr87bG4C44YMHDzmeGZYqMrtLRFuHi 5zpalGxskRZD
lVt/vdHZ6TRlqzlTiJiy1Wd7qExtrB00XDtfnH2SvyFeq0ZttQlTo9vi7lNt qTRfryVJlkVr
rXmEkYebxLKzvPDqAi9ZrANMniZGgTpMfh4dNSpWk4OjywI6flx0qIV2rDxk pD5psQNBiyw8
jjpksJSkx4OImhtFi2CEv0NjornAMCBRoYqq0uvw9zNor4SBRj5xtcbGHr65 HDRhoxVPoyRR
pypWqg0/nB5aqSE+bUU/kCpQh1NRKildo05ppUBnqh1LpJOt0ZecsaCJwkRH aU5yozRMmGpY
nz5sgk9knmyPw6alwDk+YNPT3uLdCkVop2BggnaOvC1lrre5TBc7fVB7fRFP lRtakkNfmnyc
yypVnyxdrcTQ5O/v8v///////yH5BAEAAH8ALAAAAABkAGQAAAf/gH+Cg4SF hoeIiYqLjI2O
j5CRkpOUlYp+mE2amhUOm5uYfpajpIiZfHl5SKsgra4gCbEJamopFU2YpbqT fk0OeRPBq6yv
ssYJCskKSGoVubvQpn6/wcLErsexysor3d1BzaLR471M1dZI2LLb297u30Hx CRbi46Tl5xPX
6+3v7vEAARIZSOQFPXuVevHIl66VtmTvAhKcSHHii4sXbRxECMkPn3P7IHqL RxGjyZMoTdpY
ScQZR0bTQDZ8CG8gxpU4rejcydMKzp9AdyYA8DKRx2rEtI20+WLlzipQo0qd GrWnVagvKhQ1
5EcNUofIvjG1oVMqmLNo06pNS7Ut1I1F/2Nac6hAbMayVdJG2Mu3r9++a8FQ TauA6Eu5+ujW
DWKTLFS9fq9Inkz5yt+9gTNbMWxPbtK6Kxg3tfL4bN/KqFNTvpwZzN4qnKHF HAYrrOgXZdHy
TV2gt+/fv1VfHg472uyZoEU7zut6L2rg0KP7Tj38NJjYozzTtevYtPPn0sNH Fx558nVdDoal
C7ui4B7SzHerliy+fvD5lQuAqVcJAG1YixXk2BLNRYDaBwgmSJ99DOK3YAFh ZKfGZ918UcaA
BRooWYIfwGDGhzDA8MEVDJZYAG/APZCQBRSuUIYESqDBXHOoDeFhB0nkiIIe H2qhxQAXBHlB
FnSYCB1l0mH3SP96DTEgAQRlBPGFEkpMAcYSGUCwQ2oe4uGFDyWAUMIPP5wR ABlksCGkAAKc
UKSRJUagJEy0JcCAG1GUcREKU+hxpQRujHAgDHqkUUIKRayxhgYewHFmmkJe wGabcJYYYUcs
zpSADDIISJppaKABw6Ao+JDCAyG0QQOjjqKp5pqTClApg3Mm0gQxDAT4wnvx yQcDDpN1mIQP
M7RRQQir/tBqmmoKICmbOlA6q3h6POKHKiAwMIcSMoTmXhUEZnjFDk9u8YGN ZqDgQhEYtIHB
oo0+yoYAHtAwKRlGSPrmtNK14MitDSmxQQmi8UrgX0tEsYGB537owhiKiqHB Dx48mqb/ADJU
MGkAbbARLb/SXQEEf6Zg2woDJURJxHtWhHvZDjtoeAUMaZA5McUVe+ABGRfM KwMH0U6qw9BZ
9HbFEiQGRyB0FCyBdGr+LtKEOgGKsCt84YJBxdZUnJZEqhW00WijcGBQAQcV GMHmz0FzfEG0
bFiQAh99tNBB0kCEoDcfo/a2BB98hGDBqJWNfEke2ICQHGMFpXTSG3uYUEEa A+QQwho5wLFA
G23w7IEMPRvBgbNseAAAGQKwQQYADxiQwxoV4HAEDE2UkEUOJRhwRIchlIAD DuzuTpkQHFwy
gUPaQqAA4xjt4fzz0E9RhwRoFGHBCDq3ewEZpgegw7NBiu7s/wVw9DGvAGT0 sUAWOIwAwAJ0
wOBHCjngQIfsV7zBwQJpdOADACMQ3hWEIIQiGMUC2GBADeawggMQwWrQi2DL QvSEGsDhARzA
AB84JwZnlaAPkmKDCNUkPmeV71npSwMOEFQBH6zQCxXoAwcYILwSAAADGHiA DgOIIAIKoQd9
MMXxamMngjHGalZ7gQiWSJAk2qAMJRgBCWhwghwEIAfOGoDpUEeGHFRuAOIL UvnmtT31rVAP
75PdEXCwAA34oQS78wEHBvC7Ou7uAwTsQQ/4gAgAEDEZUIiHEy4SwUJCzwoR cIEfFqCFM1Cs
Z2SowBqixT01/WxSJ4RbH3xAhw+koP8FslvCFD5AhyNUQAOdRKMGZAeDJIho RHnsAQoO4ZHa
cCMIBxCBHAxpyClYKUQa6EMIWgCANaSOfBzgQBv60EEBlFAA5ROAJpXJgRYs gJUtCMED3FU/
EcGQDw8Ap4gG+EM9HiGIhfDDBPgBhRhk6Q0qwAIB5jlPp3Fta3rIQAYIdC4D lIBR58PkzoaW
OjIQFH1Di1YLSsDQEciOAhSAgQ8Y4ILfwWBrYBhBCShavyOQU496bANX1qkN KEChDFFwQx3i
KU96zvOeVEDBBtywAzDAYAhDuEAjzxBQaSZUaEHzKdEmV8ojHAGiEP2AUUN0 T5vaEY+x1KMB
C9EEdkLhAPr/BAJLXcrVeWIhA3VYwk1xOgQtkAkOz4qVWmOVUB184AELOCpS KXADukYAplQg
wD0RRIGompM/HmHnAZwgBwTsQQVdwEJLu9oFeoo1RCHKQSPH8APUrfWybaUD BT7wULre4LOg
helLuRYBiPq1B+ckhB+Q8BCTDnaXKkDDk6bgVXp2AQLUsykMwjUCCUghCnA4 A2Ute1mgDu0E
c6UABOoAWtCygGsuvadpT7tH1aqhtVclLAJUAIQNRKGxXahDBsALKAM4jQBY cBoEpGAGOMDB
rMNV6/k81tYLfGCzdb1BBtCgXwncgQXPzStXuWaH6ZYTpD0Q6SDUid3Xbje8 dZAn/woUhgbF
hiqxik3vEiCwgRGUVQtSgMAP5iABATwhClLYgG/d8IShSeG3T9qAEuxwAwnU 4Q4z9e/WuqrX
rdW1r6dtgBgIUQFjKMC12lUBSzOcJQxn+MnpJVcNnuCjDVBZCXM4AwRqwIUK djkKOmBDDTKw
hTHfoQb83UAGbgABJdxhxzzm2o99iOAGNIAO9aiqYJO8ZCj7GcpVgEEGpmyG KFBZAhLQAgSi
MIQnSMHEUhjCFtxwBDu4ga5ovkEU1tzm59Izw/T08Zz9auct5JkfR3bwdv+s 2Hj2maV6gAEY
1msGK2shCok+sRYc3WgpfGDSlXbDHSzN302zWQks+DSoX//Kgh8D+cA9sDMO Tv2QVKu6z09W
srZdrVgIQCADbsgADCSg4hpAoNGMPvEH1F3mSqP5Dm5IcwZYAG4INBbKof4s UukMUmlTGxlH
vuq1sY2FbRscC3pAw7fRoIcqjCADjgoADAwg8REE4Ncj+IAd+HuDOtiBBR7v +H/pnQF54rvH
oDVwv/09iCI3+LWF3a6Ss61tBNgcsXqwwratEOvdPhayr9zLxwHcXOcCONle LfhW9dpsfQO5
ztLmDB8ADkiBEzbmMjd4zW3eBT104eba7jrP9aAHp5n9nkc/etHTnnRtK3ae RHc2qe1MB3T+
oQnsMGl2tWvzrGu973rYQ98H34X/Lmz7yVxNu9o/y3b0Kn3mLY37vqFt5wZs gRB434beB3v1
wWtdBX3vguDlQHrSc33wfl86PRXPeq9qPfJNH/XKWS6IzFcdyYRVAAkUgPqt I0D0pQ8+1lEP
dpaCgAmrlwMTENB69L5enpKf7uwbMO1B2D7gSPYDCSagTuITHgHCl4MTrl56 8BNf20zwg0sT
4AcFKL7tSs469GMvfT1Wnvr1qIAy9C7wA2hfDn5get7Xd8I3fgY4fuE3fCoQ Bn7wdnDXfI9X
fPMHWnyQAlF1f9VXe9i3eQfgfyQgBx/oAA5ADxaQB37QAgdgc6THBADgBxXg BCTgBzzgggng
BDzgDBZA/3oOgAl8cAAMqAJ50AIIwH4JwALat4NqgAVysIMOAABhIHNYQAIt GAIHMIMeUU73
1wAjUA+rxX+uNVj/p4MAkAd8oH0xOAHgR3p+kIMKAIPaZ4IWAAUAwARQ0BVy AAJyoAarxYAJ
UAFQgAVEaIT+0QlYwIKxoH03hwUKQAAqIIM3IIOxlIUYUAhI4IUdCIYfqIMO AIIByH0TEHx5
UAEtkAdu2IEiqIehQAJQQA+YMAExCAB8EE8g4AdF6AdMwAIiiAUiCHqIKHMs iAk88Ig8cGCS
WAhqwH+XiIlXJ4KcKAeeGH4xCAIxeFUVYAHsxwQGmH4g4IkxaII8oAKzmAAE YP+LuOgAWGAB
AOAESNCLQyiD4xiMkDh9DTCJRIaMl+gE2reMmxiDzqhOwdcJoggFMcgHFQAA CXAAMSiC23eC
ZWgB/EgPq+AHIDCOyCeCBLCOa8iOTgAA1ciRFBACTfAA9nd/WYAdTdB/9+gE aqAApdcKcqAA
nwgFE3AAwQeTEzB+07iSlzgLajB+CYAE6ogEMEl666SOcgCITkAAULCIcgAF lXgtAugEE+kE
ClBgZbADI1l5OYAdtJiMHXiATrBES5SAwrdEOOkHXpmMB8h5CBh8q9ZVhdGE KCiAhpdedlBg
kXh/NHAIapCSYKlLYikHupSAYikCPtmXHRgPXjl+ann/gOW3ZJ8mB6ylgnRp l3iZlZVHj4XQ
AgdomGEZloUZmtsnAqNZmAZ4iQGhmGn5lZ85mDFHcPGXhoW1B12ABGGwBHZw BFh4fycwJ34A
BaG5RKGgfcFJnMRpmk5wALiknKnplTfoB/5hgGNZfnWZYTUXfLTJgDsAA0ZF B9F2f0ZAMoMw
AcEpAsdZnucZnInJnKmZmrAYBKx1iUs0eqRHm68Wm4I5BYWnBztQBnxQBnSQ hfOYCBWAniRQ
mEzgDAVqnAeqN/QQAvHAihYQBBPQAn4QAiAQEKKoBvGgh2pABNq3ByJIgibY ApIpgwDgHxaa
B1OgnWXoBzMQoFpZK4IQA77k/0vCGQoioIdMIAIJYJ4HSpwhAAA8EIM8oIc8 EAQZGgJ8EAMt
8AABgQQ4qAAeGgTaNwVNSIbax4ARaQF62ALN4ABdoJ0l4Ac+kAVZcAKVt5eK 8AA3eqPaBwRy
GoNyCgRACqR5EwJf8AXa9wUPAItqEAPDGQIxUKjxEAMM6KVdYaUHKoJdEIMi wH0RiQRd4Adh
0AWOyoBbUKZnmqYnoKbFcwlv6ktxKqcz0BV1Gqd9OkxfwH488AUxoAB8AAAx UAFNWqi4GquF
2gJ8oId5MIMkQASZ6gc7qk6SWqmXKoI7oKk+YKZo+qknIAON4KYowCco4IIO oE15c6EVMDIk
4K1fEP8CxwIALfAFapBNAGABMZAH5MqkuXqhxHQ8LUgPJBCuIdCindgVekip lqoHyloEfrAF
C9AHp+SpJxCqiwAA1bqwDNCwDAACcgoCauADQHBd5poA9poAcbCnXzABcTAB uJoAKRAHCWAC
uKoAcRAHuLqNMWCxqwAECTABUwAO3RCoU4AEMaAHZVAGW4AHLoQDOeABAwCt 0uoID7CwSIu0
dVqnXwAEe6o3X/AGUvsGuGoCVnu1WFu1MWC1ucqxXgsEUyACRMCxvsSfO7AF W1BHaGqwB/sI
AFAGHZC0Sbu0dZoEb7AKU0u1hYq1fHu1e8u3uOq1HGunTrunQIACHXC2afv/ O2sLrSegAZHA
AR0wuZQbt3Mrp0kABHabt1O7tX3bt54LujEgtYLbtEubBIjbAWjLuM8KrasT CX4At5U7uXKr
uTmyuVIbB8OZAnzrAibgu58LunkruJmLuXjQASMwAmnbuI7LppEAAF4wu5Qr t7eLu7obB17g
BVfrAtzbvcAbvFg7tcSbI3hQrcc7AjngRa0LrUZAo4sgudI7vQtbvVN7vdpr Ag/gBy6QAvOj
SAT5ABMQAtD5APjrBwBbASDgBRV6oRRru0lwvJObvF40AFlwAY7LBu7LCA+Q vByMvJWLAuWL
B7f7Bl6gu5gQAi6Qv/vbvyc4AyUwTD4AsKfiBw9w/6oW4AVMmgRPergLS7kS PMFBAq1soGAJ
4QUcfMSziwdKfLsl7AfY6wUprL/8mwKK9ADcS8NWS8Mq7AJ64wWD2sMRLMED MMZCAq3Oawl9
YABHjMSUq8QinARpYL9QnL8+QA9UTMPca6tewAAGTMcuUI3f9MDV6sM/PMZA EsSf2r66kMZr
zMYd4MZ4EMcnqDdFcKoZeccPkL0zQK4AEAJekL8ECQAl4AUp0K58EMboO8Fk XMbOJJ5o7Drp
mwONbAAG8MhKXMIpGwejjDKm4gP7O8rZ6wNxwADZS8cp4ANekAaR3LB4wMHp a8iHDCvhOQ5p
HMuxvMa0bAB4sADczD9p8P/NaZC94gzO5PzN+UvOC4AHtOzMz0zBFYzIbDLN 9lDN1py+R5zN
BtDN3FzO/MzPwvzN3bzOsQzN7wytkyLPCNEHqVzP9py8+KzPEK3PkBzRAa3G 7bzKFvypsYLQ
HNEHmGPIDC3LI4DP+azPJH3SKA3LqvzOGR0rF0ADrowQawDNYxzSI53SJM3B Of3DqhwpGh0r
ZEDEW9FyqgzNIW3NC33UR23IZfzTG53BHFEBYkDTVK3UVn3RhvwqaSVfMD3U isABcEDVYj3W
ZJ3VIgQra6XIXp2wGBAAZf3WY/wqWh0pWx0rMiDUa83WATBCdN3Xfv3XQVJc d53XknBDYgDY
iE1P18XFJmRAA3hN2JHb1okd2IstXzJAA1AN2Y0AABmkATyD1pU9KapDA5it 2fbA2ThkBGiy
2vMyQiLU2KSdoqbt1Sla25xt2y0427q924UQCAA7
--------------060407050307050600030504--
--------------060902030903080506010900--
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #629504 is a reply to message #629464] |
Tue, 28 September 2010 14:07 |
Member |
I think to something: When I make an sql query to retrieve all the objects from the database, it takes only 3 or 5 seconds... but even if I store these objects in a list (to avoid the GC to remove them), when I try to access the content via the CDOResource, objects are re-loaded from the repository, taking, this time, several minutes.
When all objects have been read via the resource (using the EObject methods), they are not reloaded while next accesses.
Is my access to content not correct (forcing to load objects one by one instead of loading everything in one time) ?
public Object[] getChildren(Object parentElement) {
if (parentElement instanceof CDOObject) {
((CDOObject)parentElement).cdoPrefetch(10000);
return ((EObject)parentElement).eContents().toArray();
return null;
what method should I call to retrieve all objects through only one request (or at least one for each concerned table) ?
Why object accessed from a sql Query (like "SELECT cdo_id FROM information_schema.TABLES") are not cached like are objects accessed from EObject methods ?
Guillaume
[Updated on: Wed, 29 September 2010 09:58] Report message to a moderator
Re: [CDO] bad performances for few objects [message #629834 is a reply to message #629504] |
Wed, 29 September 2010 16:42 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Hi Guillaume,
> try to access the content via the resource, objects are re-loaded from
> instead of loading everything in one time) ? Object[] childs =
> parentCDOObject.eContents().toArray();
> Why object accessed from a sql Query are not cached like objects
I'm not entirely sure what you are comparing. The plain approach is
CDOView view = session.openView();
CDOResource res = view.getResource("/whatever");
Object[] obj = res.getContents().toArray();
(this should be equivalent to your code mentioned above).
Can you give an example of how you collect the objects with an SQL
query? I'm currently unsure how you query for objects, because actually,
you only can query for CDOIDs. So I guess what you actually store in
your list in your implementation you described initially, is proxy
objects which are not filled with actual values (which would explain why
they are loaded on access ...).
Cheers
Stefan
Re: [CDO] bad performances for few objects [message #629991 is a reply to message #629834] |
Thu, 30 September 2010 09:08 |
Member |
Hi Stefan,
Sorry if i'm not enough clear.
What i'm comparing is performances loading objects via EObject methods, or via sql query.
To load objects via EObject methods, I use quite the same process as you (calling getContents() on an object containing about 5 000 objects).
To load objects via an SQL query, I use something like this:
List<EObject> res = session.openView().createQuery("sql", "SELECT cdo_id FROM cdo_objects").getResult(EObject.class);
System.out.println("from sql size: "+res.size());
System.out.println("object 35 is proxy: "+((EObject)res.get(35)).eIsProxy());
And the result is:
Quote: | from sql size: 58355
object 35 is proxy: false
So, what I don't understand is why loading 5 000 object by calling getContents() takes about 50s, while loading 58 000 objects via an SQL query takes only 1s (and as seen above, loaded objects are not only proxies).
Moreover objects loaded from SQL queries don't seems to be cached (when accessing them via EObject methods, they are reloaded as if they wouldn't have been loaded before).
I don't know if i am more clear ^^
Thanks for your help
Guillaume
Re: [CDO] bad performances for few objects [message #630214 is a reply to message #629991] |
Fri, 01 October 2010 07:41 |
Am 30.09.2010 11:08, schrieb Guillaume P.:
> Hi Stefan,
In CDO a different mechanism for proxying is used, one that really releases memory in proxy state and not increases it as the EMF proxies do.
The correct assertion would be CDOObject.cdoState() == CDOState.PROXY. If you didn't generate CDOObject into your interfaces or if you're using the new legacy mode you can obtain the CDOObject for your object with CDOUtil.getCDOObject(eObject).
> And the result is:
> Quote:
In both cases, and by default, you are encountering the 1+n effect: There's one server round trip for getting the CDOIDs of all the objects. Then you have one more roundtrip per object that is accessed and not yet loaded.
As Stefan said (IIRC.), in both cases only IDs are transfered. No objects are cached during that. But if you access one object and it gets loaded by that, then it will certainly be cached. I suspect your objects from the query are all still in state PROXY.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #630238 is a reply to message #630230] |
Fri, 01 October 2010 09:25 |
Am 01.10.2010 11:17, schrieb Guillaume P.:
> Hi Eike,
> Thanks for your response.
> I changed the method to check if the object loaded is a proxy (my objects are generated CDOObjects):
> java.util.List<EObject> res = session.openView().createQuery("sql", "SELECT cdo_id FROM cdo_objects").getResult(EObject.class);
> System.out.println("object 35 is proxy: "+(((CDOObject)res.get(35)).cdoState() == CDOState.PROXY));
> But the result is the same:
> Quote:
> And even if those loaded objects are proxies, is there some solution to avoid the 1+n effect ? making only one query to get all data (or one by object type instead of one by object) ?
As I mentioned in my first reply, CDOObject.cdoPrefetch() can be used.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #630266 is a reply to message #630265] |
Fri, 01 October 2010 10:57 |
Am 01.10.2010 12:57, schrieb Martin Flügge:
> Hi Guillaume,
> just to make sure that we are not on the wrong track.
> Are you using the legacy mode? Maybe by accident?
Didn't we add the CDOUtil.setLegacyModeDefault(boolean) method particularly to prevent legacy objects from being used accidentally?
Cheers
/Eike
> This could explain that loading the objects takes so long.
> Cheers,
> Martin
> Am 01.10.2010 12:04, schrieb Eike Stepper:
>> Am 01.10.2010 12:02, schrieb Guillaume P.:
>>> As you can see above, I am already using the prefetch method.
>>> But using the PrefetchingPolicy and the CollectionLoadingPolicy
>>> doesn't seem to have any effect.
>> Please send us an executable test that demonstrates that.
>>> Have you any other idea ?
>> No, the CDOObject.cdoPrefetch(int) method or the
>> CDOView.Options.setRevisionPrefetchingPolicy(CDORevisionPref etchingPolicy)
>> should help. If they don't they have to be fixed, see above.
>> Cheers
>> /Eike
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #630284 is a reply to message #630270] |
Fri, 01 October 2010 12:26 |
Member |
This is a plugin for Eclipse. It is composed of
a manager to open an access to the repository and open editors.
an editor to explore the resources in the database.
a CDO server
The goal here is not to have something with a lot of functionalities but to test performances when loading objects.
The repository address is hard coded in the manager, and a tree viewer is user to load dynamically objects.
I cannot provide my own CDO model, but this should be tested on a model containing a lot of object (mine is 58000) in order to see the problem. This example doesn't provide edition features, so the CDO model should be added or imported through another UI (the default CDO UI for example).
package example;
import java.util.ArrayList;
import org.eclipse.emf.cdo.common.revision.CDORevision;
import org.eclipse.emf.cdo.eresource.CDOResource;
import org.eclipse.emf.cdo.net4j.CDONet4jUtil;
import org.eclipse.emf.cdo.net4j.CDOSession;
import org.eclipse.emf.cdo.net4j.CDOSessionConfiguration;
import org.eclipse.emf.cdo.session.CDOCollectionLoadingPolicy;
import org.eclipse.emf.cdo.transaction.CDOTransaction;
import org.eclipse.emf.cdo.util.CDOUtil;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.IToolBarManager;
import org.eclipse.net4j.Net4jUtil;
import org.eclipse.net4j.connector.IConnector;
import org.eclipse.net4j.tcp.TCPUtil;
import org.eclipse.net4j.util.container.ContainerUtil;
import org.eclipse.net4j.util.container.IManagedContainer;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.List;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.ISharedImages;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.ide.IDE;
import org.eclipse.ui.part.ViewPart;
* View for managing the database and its resources.
public class DBManager extends ViewPart {
private List resourcesNameList;
private ArrayList<CDOResource> resources;
private Action openDbAction;
private Action closeDbAction;
private CDOSession session = null;
private CDOTransaction transaction = null;
private final static String host = "localhost:2036";
private final static String repoName = "repo1";
* Create the manager
public DBManager() {
super();
// no resources when starting
resources = new ArrayList<CDOResource>();
public void createPartControl(Composite parent) {
resourcesNameList = new List(parent, 0);
createActions();
createToolbar();
public void setFocus() {
resourcesNameList.setFocus();
* Create actions to open or close the access to the database
public void createActions() {
openDbAction = new Action("Access Database...") {
public void run() {
openDatabase();
openDbAction.setImageDescriptor(PlatformUI.getWorkbench().getSharedImages().getImageDescriptor(ISharedImages.IMG_OBJ_ADD));
openDbAction.setEnabled(true);
closeDbAction = new Action("Close access to Database") {
public void run() {
closeDatabase();
closeDbAction.setImageDescriptor(PlatformUI.getWorkbench().getSharedImages().getImageDescriptor(ISharedImages.IMG_TOOL_DELETE));
closeDbAction.setEnabled(false);
// Add selection listener.
resourcesNameList.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
updateActionEnablement();
public void widgetDefaultSelected(SelectionEvent e) {
// add double click listener to open editors
resourcesNameList.addMouseListener(new MouseListener() {
public void mouseDoubleClick(MouseEvent e) {
if (resourcesNameList.getSelectionCount() > 0) {
// get the selected CDOResource
CDOResource resToOpen = resources.get(resourcesNameList.getSelectionIndex());
try {
// open an editor for this resource
IEditorInput editorInput = new DBEditorInput(resToOpen, resToOpen.getPath());
IDE.openEditor(
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage(),
editorInput,
"db.ui.dbEditor");
} catch (PartInitException e1) {
e1.printStackTrace();
public void mouseDown(MouseEvent e) { }
public void mouseUp(MouseEvent e) { }
* Access to the Database and read the different resources available
private void openDatabase() {
//open session and transaction
session = openSession(host, repoName);
CDOCollectionLoadingPolicy policy = CDOUtil.createCollectionLoadingPolicy(0, 10000);
session.options().setCollectionLoadingPolicy(policy);
session.options().getProtocol().setTimeout(IConnector.NO_CHANNEL_TIMEOUT);
transaction = session.openTransaction();
// search all stored resources
transaction.getRootResource().cdoView().options().setRevisionPrefetchingPolicy(CDOUtil.createRevisionPrefetchingPolicy(CDORevision.DEPTH_INFINITE));
for (EObject eobj : transaction.getRootResource().getContents()) {
if (eobj instanceof CDOResource) {
CDOResource resource = (CDOResource)eobj;
// add resource to lists
resourcesNameList.add(resource.getName().toString());
resources.add(resource);
* Close the access to the current Database.
private void closeDatabase() {
if (transaction != null) {
transaction.close();
transaction = null;
if (session != null) {
session.close();
session = null;
resourcesNameList.removeAll();
resources.clear();
* Update the close and open actions state.
private void updateActionEnablement() {
if (session == null) {
} else {
closeDbAction.setEnabled(true);
openDbAction.setEnabled(false);
* Create toolbar.
private void createToolbar() {
IToolBarManager mgr = getViewSite().getActionBars().getToolBarManager();
mgr.add(openDbAction);
mgr.add(closeDbAction);
* Open a new session on the given repository
* @param host host where the repository is stored
* @param repository name of the repository to open
* @return opened session
private CDOSession openSession(String host, String repository) {
IManagedContainer container = ContainerUtil.createContainer();
container.activate();
Net4jUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
IConnector connector = TCPUtil.getConnector(container, host);
// configure session
CDOSessionConfiguration configuration = CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName(repository);
// Open CDO session
return configuration.openSession();
package example;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.PlatformObject;
import org.eclipse.emf.cdo.ui.CDOItemProvider;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.net4j.util.ObjectUtil;
import org.eclipse.ui.IPersistableElement;
* This editor input is used by the DbEditor to know which is the linked CDOResource.
public class DBEditorInput extends PlatformObject implements IEditorInput {
private CDOResource resource;
private String resourcePath;
public DBEditorInput(CDOResource resource, String resourcePath) {
this.resource = resource;
this.resourcePath = resourcePath;
public String getResourcePath() {
return resourcePath;
public boolean exists() {
return true;
public CDOResource getResource() {
return resource;
public ImageDescriptor getImageDescriptor() {
return CDOItemProvider.getViewImageDescriptor(resource.cdoView());
public String getName() {
if (resourcePath != null) {
return new Path(resourcePath).lastSegment();
return resource.cdoView().getSession().getRepositoryInfo().getName();
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return "myFile";
public int hashCode() {
return ObjectUtil.hashCode(resource.cdoView()) ^ ObjectUtil.hashCode(resourcePath);
public boolean equals(Object obj) {
if (obj == this)
return true;
if (obj instanceof DBEditorInput)
DBEditorInput that = (DBEditorInput)obj;
return ObjectUtil.equals(resource, that.getResource());
return false;
package example;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.ui.IEditorSite;
import org.eclipse.ui.part.EditorPart;
* This editor is a simple example to load and display in a tree the content of a CDOResource.
public class DBEditor extends EditorPart {
TreeViewer tree;
public DBEditor() {}
public void doSave(IProgressMonitor monitor) {}
public void doSaveAs() {}
public void init(IEditorSite site, IEditorInput input) throws PartInitException {
if (input instanceof DBEditorInput) {
setSite(site);
setInputWithNotify(input);
setPartName(input.getName());
} else {
public boolean isDirty() {
return false;
public boolean isSaveAsAllowed() {
return false;
tree = new TreeViewer(parent);
// The tree will display the content of the CDOResource linked to the editor
tree.setContentProvider(new DBTreeContentProvider());
tree.setLabelProvider(new DBLabelProvider());
tree.setInput(((DBEditorInput)getEditorInput()).getResource());
public void setFocus() {}
package example;
import org.eclipse.emf.cdo.CDOObject;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.Viewer;
* This treeContentProvider load dynamically objects from the CDOResource for the DBEditor tree.
public class DBTreeContentProvider implements ITreeContentProvider {
TreeViewer viewer = null;
EObject rootObject = null;
public void dispose() {}
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
this.viewer = (TreeViewer)viewer;
rootObject = (EObject)newInput;
public Object[] getElements(Object inputElement) {
return getChildren(inputElement);
// start timing
System.out.print("getChildren("+parentElement+") = ");
long t1 = System.currentTimeMillis();
// load objects (or get from cache)
Object[] res = ((EObject)parentElement).eContents().toArray();
// stop timing and display
System.out.println(System.currentTimeMillis() - t1);
return res;
return null;
public Object getParent(Object element) {
if (element instanceof EObject) {
return ((EObject)element).eContainer();
return null;
public boolean hasChildren(Object element) {
if (element instanceof CDOObject) {
return !((EObject)element).eContents().isEmpty();
return false;
package example;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.swt.graphics.Image;
* Label provider to provide labels in the tree displaying the CDOResource.
* Labels just display the type of the object and its version.
public class DBLabelProvider implements ILabelProvider {
public void addListener(ILabelProviderListener listener) {}
public boolean isLabelProperty(Object element, String property) {
return false;
public void removeListener(ILabelProviderListener listener) {}
public Image getImage(Object element) {
return null;
public String getText(Object element) {
return ((EObject)element).eClass().getName()
+" (v"+((CDOObject)element).cdoRevision().getVersion()+")";
And the CDO server configuration:
<cdoServer>
<!--acceptor type="http"/ -->
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<!-- negotiator type="challenge" description="/temp/users.db"/ -->
</acceptor>
<repository name="repo1">
<property name="overrideUUID" value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="true"/>
<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<dbAdapter name="h2"/>
<dataSource class="org.h2.jdbcx.JdbcDataSource"
uRL="jdbc:h2:_database/cdodb1"/>
</store>
</repository>
</cdoServer>
... That's it ! ^^
Thank you in advance for your help,
Guillaume
Re: [CDO] bad performances for few objects [message #630313 is a reply to message #630284] |
Fri, 01 October 2010 14:16 |
Hi Guillaume,
Is it possible that you assemble this in a zip so that i can just extract an eclipse project and use a contained launch config to run your code? My time is really somewhat limited and all this support is free. Please try to make it as quick as possible and bear with me.
Cheers
/Eike
Am 01.10.2010 14:27, schrieb Guillaume P.:
> a CDO server
> package example;
> super();
> @Override
> createActions();
> createToolbar();
> @Override
> public void run() { openDatabase();
> openDbAction.setImageDescriptor(PlatformUI.getWorkbench().ge tSharedImages().getImageDescriptor(ISharedImages.IMG_OBJ_ADD ));
> public void run() {
> closeDatabase();
> closeDbAction.setImageDescriptor(PlatformUI.getWorkbench().g etSharedImages().getImageDescriptor(ISharedImages.IMG_TOOL_D ELETE));
> @Override
> @Override
> @Override
> try {
> IDE.openEditor(
> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage(),
> editorInput,
> "db.ui.dbEditor");
> @Override
> @Override
> session.options().getProtocol().setTimeout(IConnector.NO_CHA NNEL_TIMEOUT);
> transaction.getRootResource().cdoView().options().setRevisio nPrefetchingPolicy(CDOUtil.createRevisionPrefetchingPolicy(C DORevision.DEPTH_INFINITE));
> transaction = null;
> session.close();
> session = null;
> resources.clear();
> } else {
> * Create toolbar.
> // Open CDO session
> package example;
> return true;
> return resource;
> return resource.cdoView().getSession().getRepositoryInfo().getName( );
> return null;
> return "myFile";
> @Override
> @Override
> if (obj == this)
> return true;
> return false;
> package example;
> TreeViewer tree;
> @Override
> @Override
> @Override
> setSite(site);
> } else {
> @Override
> return false;
> @Override
> return false;
> @Override
> tree.setInput(((DBEditorInput)getEditorInput()).getResource( ));
> @Override
> package example;
> @Override
> @Override
> @Override
> @Override
> // start timing
> return res;
> return null;
> @Override
> return null;
> @Override
> return false;
> package example;
> @Override
> @Override
> @Override
> return false;
> @Override
> @Override
> return null;
> @Override
> <cdoServer>
> </acceptor>
> <store type="db">
> </mappingStrategy>
> </store>
> </repository>
> </cdoServer>
> ... That's it ! ^^
> Guillaume
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #630436 is a reply to message #630331] |
Sat, 02 October 2010 13:13 |
Hi Guillaume,
thanks for your code. I did the following to create a repository with
50000 objects:
CDOSession session = openSession(host, repoName);
CDOTransaction tx = session.openTransaction();
EPackage pkg = EMFUtil.createEPackage("foobar", "fb", "http://foobar");
EClass[] cls = new EClass[10];
for(int i=0; i<10; i++) {
cls[i] = EMFUtil.createEClass(pkg, "Class"+i, false, false);
EMFUtil.createEAttribute(cls[i], "att",
EcorePackage.eINSTANCE.getEString());
CDOUtil.prepareDynamicEPackage(pkg);
Random rand = new Random();
for(int r = 0; r<10; r++) {
CDOResource res = tx.createResource("/res"+r);
for(int o=0; o<5000; o++) {
EObject obj = EcoreUtil.create(cls[rand.nextInt(10)]);
obj.eSet(obj.eClass().getEStructuralFeature("att"), "obj"+r * 10000
+ o);
res.getContents().add(obj);
System.out.println("Committing ...");
tx.commit();
tx.close();
session.close();
System.out.println("Done ...");
Next, I altered your code slightly, so it measures initialization time
as well (more or less openDatabase() in your code). Then I ran the
experiment as follows:
- Start the server
- Start the client
- Connect to Repository
- Open res1
- Close res1
- Open res1 again
- Close res1
- Open res3
- Close res3
- Open res3 again
- Close res3
- Terminate client
- Terminate server
Your code as provided leads to these results on my machine:
initializing = 3377
getChildren(CDOResource@OID26358) = 21523 (<- open res1)
getChildren(CDOResource@OID26358) = 45 (<- open res1 again)
getChildren(CDOResource@OID19749) = 18070 (<- open res3)
getChildren(CDOResource@OID19749) = 9 (<- open res3 again)
as a first step: you are configuring the collection loading policy
wrong. The first parameter is what should be fetched at once, so 0 is
not a good idea if you want to preload your whole model.
Therefore I used
CDOUtil.createCollectionLoadingPolicy(10000, 10000);
instead of your
which lead to
initializing = 875
getChildren(CDOResource@OID26358) = 12730
getChildren(CDOResource@OID26358) = 52
getChildren(CDOResource@OID19749) = 10366
getChildren(CDOResource@OID19749) = 5
This is already a 50% speed-up.
Next, you are configuring your revision prefetching policy with
CDORevision.INFINITE_DEPTH (which is -1). Because of an if-statement in
createRevisionPrefetchingPolicy, revision prefetching for negative
values is deactivated. Therefore, you actually never used the revision
prefetching policy. I have to clarify with Eike if
CDORevision.INFINITE_DEPTH is actually not allowed here, maybe we should
state this more explicitly in the documentation.
Anyway, using
transaction.options().setRevisionPrefetchingPolicy(CDOUtil.c reateRevisionPrefetchingPolicy(10));
instead of your
transaction.options().setRevisionPrefetchingPolicy(CDOUtil.c reateRevisionPrefetchingPolicy(CDORevision.INFINITE_DEPTH));
in addition to the modified collection loading policy above leads to
initializing = 5473
getChildren(CDOResource@OID26358) = 6655
getChildren(CDOResource@OID26358) = 73
getChildren(CDOResource@OID19749) = 6522
which makes the initialization slower, but again boosts performance by
40-50%.
I hear you asking the next question, why the first access is still
slower than the second one. I cannot state why at this time. I have to
do further analysis. Maybe its a bug either in the prefetching policy or
in our understanding of how it should work :-)
But finally, you wanted to preload your whole model in the client. You
can do this quite simply by replacing the whole prefetching policy with
one explicit call:
transaction.getRootResource().cdoPrefetch(CDORevision.DEPTH_ INFINITE);
(yes, CDORevision.DEPTH_INFINITE is actually allowed here ...)
this makes the initialization really slow, but leads to instant
subsequent access as you wanted it:
initializing = 157339
getChildren(CDOResource@OID26358) = 190
getChildren(CDOResource@OID19749) = 121
I hope this analysis helps you a bit and you are invited to share your
further experience with us by, for example, complementing
http://wiki.eclipse.org/Tweaking_CDO_Performance with your insights.
Obviously, there are some things not entirely clear in there.
Have a nice weekend,
Stefan
On 01.10.2010 17:46, Guillaume P. wrote:
> Sorry for all my questions, but I'm on those problems since several
> weeks now and I don't know where else I could find help. I understand
> you cannot use all your time for making support, and I thank you for all
> your help.
> So, here is http://dl.free.fr/vBvkgsg0L the zip file containing the full
> plugin project. As told before, I cannot provide my big CDO model
> (because of confidentiality rules), but I think you have one for your
> tests. You just have to change the "host" and "repoName" constants in
> the DBManager class to make the plugin reading your own repository.
> Hopping that nothing is missing, thanks you again for your help.
> Guillaume
Re: [CDO] bad performances for few objects [message #630562 is a reply to message #630436] |
Mon, 04 October 2010 07:16 |
Am 02.10.2010 15:13, schrieb Stefan Winkler:
> Hi Guillaume,
> thanks for your code. I did the following to create a repository with 50000 objects:
> EMFUtil.createEAttribute(cls[i], "att", EcorePackage.eINSTANCE.getEString());
> obj.eSet(obj.eClass().getEStructuralFeature("att"), "obj"+r * 10000 + o);
> tx.commit();
> tx.close();
> session.close();
> Next, I altered your code slightly, so it measures initialization time as well (more or less openDatabase() in your code). Then I ran the experiment as follows:
> - Start the server
> - Start the client
> - Open res1
> - Close res1
> - Open res1 again
> - Close res1
> - Open res3
> - Close res3
> - Open res3 again
> - Close res3
> - Terminate client
> - Terminate server
> initializing = 3377
> as a first step: you are configuring the collection loading policy wrong. The first parameter is what should be fetched at once, so 0 is not a good idea if you want to preload your whole model.
> Therefore I used
> CDOCollectionLoadingPolicy policy = CDOUtil.createCollectionLoadingPolicy(10000, 10000);
Using partial collection loading at all looks like a bad idea if the purpose is to reduce the number of server round trips. It's really best not to call CDOSession.Options.setCollectionLoadingPolicy() in this case.
> instead of your
> which lead to
> initializing = 875
> Next, you are configuring your revision prefetching policy with CDORevision.INFINITE_DEPTH (which is -1). Because of an if-statement in
> createRevisionPrefetchingPolicy, revision prefetching for negative values is deactivated. Therefore, you actually never used the revision prefetching policy. I have to clarify with Eike if CDORevision.INFINITE_DEPTH is actually not allowed here, maybe we should state this more explicitly in the documentation.
> Anyway, using
> instead of your
CDOUtil.createRevisionPrefetchingPolicy(int) could really need more documentation but the name of the parameter indicates a *size* and not a *depth*.
> initializing = 5473
> which makes the initialization slower, but again boosts performance by 40-50%.
> I hear you asking the next question, why the first access is still slower than the second one. I cannot state why at this time. I have to do further analysis. Maybe its a bug either in the prefetching policy or in our understanding of how it should work :-)
> But finally, you wanted to preload your whole model in the client. You can do this quite simply by replacing the whole prefetching policy with one explicit call:
Yeah, that's exactly what I tried to explain repeatedly.
This time the parameter name suggests a *depth* and not a *size* ;-)
Cheers
/Eike
> this makes the initialization really slow, but leads to instant subsequent access as you wanted it:
> I hope this analysis helps you a bit and you are invited to share your further experience with us by, for example, complementing http://wiki.eclipse.org/Tweaking_CDO_Performance with your insights.
> Cheers,
> Stefan
>> your help.
>> Guillaume
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #630706 is a reply to message #630562] |
Mon, 04 October 2010 16:07 |
Member |
Hi !
Thank you both for your help.
Firstly I would like to tell to Eike that I had understood what you were telling me to do. As you can see in my third message, in the code example, I was already using the method cdoPrefetch(10000). But as it didn't seem to have any effect, I tried with the PrefetchingPolicy... without success.
Regarding the stefan's work (and thank you very much for the time you probably passed on it), I reproduced exactly the same process to correct progressively my own project code. But result aren't the same:
with my initial code (and resources generated with your code), results are:
initialization = 703
getChildren(CDOResource@OID78051) = 6781
getChildren(CDOResource@OID78051) = 0
getChildren(CDOResource@OID84779) = 7406
getChildren(CDOResource@OID84779) = 0
Setting 10000 as first parameter of CollectionPolicy does nothing on my side:
initialization = 718
getChildren(CDOResource@OID78051) = 6907
getChildren(CDOResource@OID84779) = 7172
getChildren(CDOResource@OID84779) = 16
So I tried to remove this line, as recommended Eike, but without change.
Changing the PrefetchPolicy to 10 gives about 50% speed-up:
initialization = 687
getChildren(CDOResource@OID78051) = 2844
getChildren(CDOResource@OID78051) = 16
getChildren(CDOResource@OID84779) = 4079
And at last, replacing the setPrefetchPolicy(...) line by the line " transaction.getRootResource().cdoPrefetch(CDORevision.DEPTH_ INFINITE);" provide those results:
initialization = 672
getChildren(CDOResource@OID78051) = 6703
getChildren(CDOResource@OID84779) = 6985
So, here I don't really understand... perhaps it's my server which is not correctly configured ?
The configuration file is in the project, at the path "server/configuration/cdo-server.xml".
My server run configuration contains those parameters:
Program arguments:
Quote: | -os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -consoleLog -console -debug
VM arguments:
Quote: | - -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx1024m -Dnet4j.config=${resource_loc:/CDOExample/server/configurati on} -Dorg.osgi.service.http.port=8080 -Ddebug=true
My client run configuration (if needed) contains those parameters:
Program arguments:
VM arguments:
Quote: | -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx512m -XX:MaxPermSize=128m
Well, I'm blocked here, so I think I will try to explore other directions. But if you have any idea of the problem source, i am ready to try your solution.
Thank you very much for your time and your help,
Guillaume
Re: [CDO] bad performances for few objects [message #631121 is a reply to message #630706] |
Wed, 06 October 2010 09:07 |
Am 04.10.2010 18:07, schrieb Guillaume P.:
> Hi !
Apologies, sometimes I try to spare some time by not reading through old posts for each new one in a thread ;-(
I may not have asked what version of CDO you're using. There was an enhancement to cdoPrefecth(), but only in 4.0. Please compare:
318919: Removing precondition for the prefetching to work effectively
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318919
Cheers
/Eike
> getChildren(mailto:CDOResource@OID78051) = 6781
> getChildren(mailto:CDOResource@OID78051) = 0
> getChildren(mailto:CDOResource@OID84779) = 7406
> getChildren(mailto:CDOResource@OID84779) = 0
> getChildren(mailto:CDOResource@OID78051) = 6907
> getChildren(mailto:CDOResource@OID84779) = 7172
> getChildren(mailto:CDOResource@OID84779) = 16
> getChildren(mailto:CDOResource@OID78051) = 2844
> getChildren(mailto:CDOResource@OID78051) = 16
> getChildren(mailto:CDOResource@OID84779) = 4079
> getChildren(mailto:CDOResource@OID78051) = 6703
> getChildren(mailto:CDOResource@OID84779) = 6985
> Program arguments:
> Quote:
> VM arguments:
> Quote:
> Program arguments:
> Quote:
> VM arguments:
> Quote:
> Regards,
> Guillaume
Cheers
/Eike
Re: [CDO] bad performances for few objects [message #632370 is a reply to message #632367] |
Tue, 12 October 2010 17:06 |
Member |
Yes but the project on which I am working needs and offline mode (That's one of the reason for what I am interested by CDO).
Currently I make my tests on a single machine, and I use a TCPConnector with a localhost connection, but the goal is to have the repository on a remote server, with several clients, offline mode, concurrent accesses, advances search features (I'm trying EMF Query), ...
Are you speaking about JVMConnector ? Is there any example for the use of this connector (especially for the server configuration and the server description) ?
Guillaume
[Updated on: Tue, 12 October 2010 17:12] Report message to a moderator
Re: [CDO] bad performances for few objects [message #633137 is a reply to message #632376] |
Fri, 15 October 2010 13:39 |
Member |
> Maybe you should monitor my current work in progress:
> 327405: Provide an offline CDOWorkspace with Checkout/Update/Commit workflows
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=327405
It's interesting, but I prefer the local repository system, which still giving us immediate feed back about remote modifications (when connected).
> OCL is advanced
> See 256931: Provide common query language (OCL)
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=256931
Hum... OCL is a little complicated for a final user (It would be interesting for me to allow user typing himself "complex" queries)... what about the SQL language like ?
> I guess so
>> Is there any example for the use of this connector ?
> One is org.gastro.server.internal.web.GastroServlet.init().
Hum, I have a problem when opening a session with this configuration. I get this error:
Quote: | org.eclipse.net4j.channel.ChannelException: org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.net4j.serverProtocols[cdo]
at org.eclipse.net4j.internal.jvm.JVMConnector.registerChannelW ithPeer(JVMConnector.java:115)
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:156)
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:1)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol. java:130)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.initP rotocol(CDONet4jSessionImpl.java:166)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.activ ateSession(CDONet4jSessionImpl.java:92)
at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:1174)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:72)
at org.eclipse.emf.internal.cdo.session.CDOSessionConfiguration Impl.openSession(CDOSessionConfigurationImpl.java:214)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurat ionImpl.openSession(CDONet4jSessionConfigurationImpl.java:91 )
Searching on the forum gave me this thread (http://www.eclipse.org/forums/index.php?t=msg&th=136803 &start=0&S=4790720698f5e69bda0b9624bb06c28f), but no dependency seems to be missing for me. Here is what I have:
Quote: | org.eclipse.ui;bundle-version="3.6.0",
org.eclipse.core.runtime;bundle-version="3.6.0",
org.eclipse.ui.ide;bundle-version="3.6.0",
org.h2;bundle-version="1.1.117",
org.eclipse.emf.query;bundle-version="1.2.100",
org.eclipse.jgit;bundle-version="0.8.4",
org.eclipse.net4j.tcp;bundle-version="4.0.0",
org.eclipse.net4j.jvm;bundle-version="4.0.0",
org.eclipse.net4j.db.h2;bundle-version="4.0.0",
org.eclipse.emf.cdo.server.db;bundle-version="4.0.0",
org.eclipse.emf.cdo.ui.ide;bundle-version="4.0.0",
org.eclipse.emf.cdo.net4j;bundle-version="4.0.0",
org.eclipse.emf.cdo.server.net4j;bundle-version="4.0.0"
Maybe I should put this problem in the other thread to be more clear ^^
Guillaume
Re: [CDO] bad performances for few objects [message #633295 is a reply to message #633137] |
Sat, 16 October 2010 05:41 |
Am 15.10.2010 15:39, schrieb Guillaume P.:
>> OCL is advanced :p
From a CDO perpective it's almost trivial to hook your own IQueryHandlers into a repository. Please look at the existing implementations of this interface for examples. You may want to checkout the complete sources: http://wiki.eclipse.org/CDO_Source_Installation
>> I guess so ;)
> Quote:
> Searching on the forum gave me http://www.eclipse.org/forums/index.php?t=msg&th=136803& amp;start=0&S=4790720698f5e69bda0b9624bb06c28f, but no dependency seems to be missing for me.
Are you running standalone? Then you may need to call CDONet4jServerUtil.prepareContainer(IPluginContainer.INSTANC E) to mimic what the extension registry does when running in OSGi. Does that help?
Cheers
/Eike
> Quote:
> Best regards,
> Guillaume
Cheers
/Eike
Current Time: Fri Sep 27 00:34:05 GMT 2024
Powered by FUDForum. Page generated in 0.34981 seconds
