Re: [QVTo] How to correctly reference other qvto files in an import [message #627841 is a reply to message #627086] |
Thu, 23 September 2010 06:14 |
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hello Simon,
does the transformation run from within Eclipse without errors?
Not sure it would help, but you could try:
import toBPEL.bpel.BPELLib;
and
import bpel.BPELLib;
Dennis
Simon harrer wrote:
> I have the following file with path: /qvto/toBPEL/PM_to_BPEL.qvto
> import qvto.toBPEL.bpel.BPELLib;
> The imported file exists at /qvto/toBPEL/bpel/BPELLib.qvto
> However, the system throws an exception that the imported file cannot be
> found.
> I run this standalone using java and it worked before as every file was
> inside the same directory.
> Also, the qvto editor states NO error.
> So, how to reference the other qvto library correctly?
FUDForum. Page generated in 0.04412 seconds
