Re: Download failure using Project Set File [message #528891 is a reply to message #528696] |
Thu, 22 April 2010 09:56 |
Originally posted by: news.eclipse.org.08.lemmster.de
On 04/21/2010 04:04 PM, Jonathan Gossage wrote:
> I am trying to download the source code for ECF using the Project Set
> File referenced from
> http://www.eclipse.org/projects/project_summary.php?projecti d=rt.ecf
> I get several errors while trying to import this file and wind up with
> an incomplete set of projects.
> Specifically, the following errors occur:
> 1. The server reported an error while performing the "cvs-expand-module
> command.
> cvs version cannot find module
> "org.eclipse.ecf/compendium/bundles/org.ecf.osgi.services" - ignored
> 2. Pat way through, Eclipse warns that project org.eclipse.ecf.releng
> exists in the workspace. If I choose to overwrite it, Eclipse complains
> that only partial repository information is supplied and suggests
> sources for complete information.
> 3. Further along I get Eclipse complaining about being unable to delete
> files from org.eclipse.ecf.presence.ui\bin.
> The final result of all this is that I wind up with an incomplete set of
> ECF projects.
> I am using a brand new installation of Eclipse-RCP M6 and a brand new
> workspace, running on Windows 7 Professional with Sun JDK 1.6.0_20.
> Any suggestions as to how I can resolve this issue?
Hi Jonathan,
that project set file is pretty much outdated. Please use the one which
can be found at CVS
pserver:anonymous@dev.eclipse.org :/cvsroot/rt,org.eclipse.ecf/releng/org.eclipse.ecf.releng/p rojectSet-anonymous.psf.
Guess we should remove the old version from the projects page and rather
link to viewcvs instead.
Markus
Re: Download failure using Project Set File [message #625207 is a reply to message #528696] |
> command.
> ECF projects.
Hi Jonathan,
can be found at CVS
Markus
FUDForum. Page generated in 0.06621 seconds
