[ERR]: org.eclipse.birt.chart.exception.PluginException: Unable to locate any en [message #62350] |
Thu, 28 July 2005 18:01 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jyl.us.ibm.com
I am a newcomer of BIRT, trying to learn Chart Programming by running the
"create a line chart programmatically" example in FAQ. I ran into the
any entries for lookup=dv.SWING; (full message attached). Will appreciate
any advice on how to resolve the problem.
Also, is there any doc describing how to start with the chart programming
with examples?
Juhnyoung
any entries for lookup=dv.SWING; element=(name:device) in any plugin.xml
file in all of the available plugins
entries for lookup=dv.SWING; element=(name:device) in any plugin.xml file
at
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObjec t(PluginSettings.java:636)
at
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:324)
at
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer. <init>(SwingLiveChartViewer.java:116)
at
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer.main(SwingLiveChartViewer.java:92)
at
at
at
at
at
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer.main(SwingLiveChartViewer.java:105)
Exception in thread "main"
FUDForum. Page generated in 0.03529 seconds
