Home » Archived » Test and Performance Tools Platform (TPTP) » Position independent item-select in AGR
Position independent item-select in AGR [message #61050] |
Tue, 28 March 2006 09:28  |
Originally posted by: eclipse.shedid.de
Hello everybody,
we're trying test our eclipse plugins with the AGR. Some of our views
contain tree widgets which are controlled by the plugin via JFace
TreeViewer.
I can record the selection of items in the tree with the recorder, but
the command stored is based on the relative position of items in the
tree structure as shown below.
<command type="item-select" contextId="view/com.packgae.SomeTreeView"
widgetId="org.eclipse.swt.widgets.Tree#1">
<item path="com.package.SomeClassl0|0||9|"/>
</command>
Unforunately I have really no influence on the position at which the
item may appear when replaying the test and so the tests will fail in
most cases because items are on different positions in the tree.
So my questions is if there is any other method to select the items
without knowing thier position, e.g. by the label or by any properties
of the object?
I really need to select the items, verification of existence (could be
done by hooks) is not enough, because I want to call the context menu.
Thanks in advance for your help,
best regards,
Dirk
Re: Position independent item-select in AGR [message #61830 is a reply to message #61050] |
Wed, 29 March 2006 05:55   |
Originally posted by: mvjaibharatreddy.yahoo.com
Hi dirk,
I am bit surprised about your comment :
> I can record the selection of items in the tree with the recorder, but the
> command stored is based on the relative position of items in the tree
How your macro is based on relative position ? . Can you explain what you
mean by relative position? .
cheers
Jai
"Dirk Bernsau" <eclipse@shedid.de> wrote in message
news:e0bh6p$3aj$1@utils.eclipse.org...
> Hello everybody,
> TreeViewer.
> </command>
> Unforunately I have really no influence on the position at which the item
> may appear when replaying the test and so the tests will fail in most
> without knowing thier position, e.g. by the label or by any properties of
> the object?
> best regards,
> Dirk
Re: Position independent item-select in AGR [message #61876 is a reply to message #61830] |
Wed, 29 March 2006 06:44   |
I give you some examples:
When I select the third child of the first top level element in the
tree, which is an object of class ClassificationScheme, it records as
<item path="com.xxx.ClassificationScheme0|2|"/>
because indexing starts with 0.
When I select the first child of the fourth child of the first top level
element in the tree, which is an object of class Concept, it records as
<item path="com.xxx.Concept0|3||0|"/>
I dont't know why there are to pipe characters between 3 and 0 in the
second command.
My problem is that I don't know at which position the item will be at
replay time.
When recording selection of elements in the JDT PackageExplorer, the
recording looks different:
<item path="org.eclipse.swt.widgets.TreeItem#{{/GUITest/src}}-{{1.0}} "/>
Here the 'src' folder in the project GUITest will be selected.
The difference is, that here the TreeItem of SWT is adressed, and not
the object representing the entry in the tree. I've tried to convert
this to my needs but had no success within our TreeView. I then get a
NullPointerException in the AutoGUIRunner$1$MacroPlayWrapper.run().
Maybe someone can explain in detail what the syntax of
....TreeItem#{{/GUITest/src}}-{{1.0}}... is about.
Dirk
> cheers
> Jai
>>Hello everybody,
>>TreeViewer.
>></command>
>>the object?
>>best regards,
>>Dirk
Re: Position independent item-select in AGR [message #62247 is a reply to message #61876] |
Wed, 29 March 2006 11:41  |
Actually the tree item that you referenced below is resolved using its
underlying data item. The reason why it's resolved is because of the
following registration entry under widgetReg.xml:
<class name = "org.eclipse.jdt.core.IJavaElement" matchThreshold = "1.0">
<method name = "getPath" weight = "1.0"/>
</class>
If you provide a similar registration, you'll be able to resolve the tree
item using better means than the tree item's indices.
news:e0drv2$ul1$1@utils.eclipse.org...
you
> second command.
> replay time.
> Regards,
> Dirk
> > cheers
> > Jai
> >>Hello everybody,
> >>TreeViewer.
the
> >></command>
item
of
> >>the object?
> >>best regards,
> >>Dirk
Current Time: Mon Apr 28 08:59:30 EDT 2025
Powered by FUDForum. Page generated in 0.04308 seconds
