Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript] loading Metamodel
[MOFScript] loading Metamodel [message #383892] |
Tue, 17 June 2008 22:23  |
I'm defining some textual tranformations for models based on the
JavaAbstractSyntax metamodel. It works fine! However, when I try to
integrate my MOFScript transformation in a Java environment, using the
example given in the MOFScript User Guide v0.6, it doesn't work.
The following line
**int errorCount = ParserUtil.getModelChecker().getErrorCount();**
returns 85 erros. They are all concerning the lack of a metamodel
definition.
I see that the exemple in the User Guide doesn't present a means of
setting the metamodel before calling
**execMgr.executeTransformation();**
So, the errors are expected.
Although I've searched a lot, I have not found any way of setting the
metamodel, any kind of MOFScript API and any other kind of ducumentation.
Has anyone had the same problem? May someone help me?
Best regards!
The output I get from my Java program is this:
Parsing result: 85 errors
: Error: MTTParseError: Illegal/unknown context: jast, line: 484, column: 0
: Error: MTTParseError: Can't find feature 'interface' for type
'TypeDeclaration'., line: 28, column: 5
: Error: MTTParseError: Type not found: 'FieldDeclaration' in metamodel
'null', line: 0, column: 0
: Error: MTTParseError: Can't find feature 'bodyDeclarations' for type
'TypeDeclaration'., line: 31, column: 2
: Error: MTTParseError: Type not found: 'MethodDeclaration' in metamodel
jast is a reference to the metamodel.
Re: [MOFScript] loading Metamodel [message #383901 is a reply to message #383896] |
Tue, 24 June 2008 16:45   |
Thanks Gøran,
i did it...
File metamodel = new File("Z:\\<<Filepath>>\\JavaAbstractSyntax.ecore");
ResourceSet rsSource = new
ResourceSetImpl(); rsSource.getResourceFactoryRegistry().getExtensionToFactoryM ap().put( "*",
new XMIResourceFactoryImpl());
Resource resSource = rsSource.getResource(
URI.createFileURI(metamodel.getAbsolutePath()), true);
EPackage package = (EPackage) resSource.getContents().get(0);
EPackage.Registry.INSTANCE.put("JavaAbstractSyntax", package);
But now i have other problem. When i load the model.
i m doing it:
execMgr.lookupAndAddSourceMetaModel("JavaAbstractSyntax","JavaAbstractSyntax "));
execMgr.loadSourceModel(new
File("Z:\\<<Filepath>>\\test.javaabstractsyntax"));
But a exception is thrown. The model test.javaabstractsyntax and the
transfomation works well on the eclipse plugin.
Exception in thread "main" java.lang.NullPointerException
at
org.eclipse.mofscript.runtime.ExecutionManager.getSourceMeta ModelName(ExecutionManager.java:887)
at
org.eclipse.mofscript.runtime.ExecutionManager.loadSourceMod el(ExecutionManager.java:585)
at code.JavaCodeGeneration.test(JavaCodeGeneration.java:123)
at code.JavaCodeGeneration.main(JavaCodeGeneration.java:151)
Any ideia?
Thanks in advance
Gøran K. Olsen wrote:
> Hello again,
> And if this doesn't work have you added
> //Change to your ovn metamodel
> import org.eclipse.uml2.uml.UMLPackage;
> public class TestAPI implements ExecutionMessageListener {
> public TestAPI () {
> //Maks MOFScript aware of your metamodel chenge to your own
> UMLPackage lePackage = UMLPackage.eINSTANCE;
> /Gøran
> "Gøran K. Olsen" <Goran.K.Olsen@Sintef.no> wrote in message
> news:g3ntt1$qo5$1@build.eclipse.org...
>> Hello Netuh,
>> Have you added your model plugin to the classpath?
>> Cheers,
>> Gøran
>> "Netuh" <waldemar.neto@gmail.com> wrote in message
>> news:8fc95745bbb80a8e313ec69317d7e804$1@www.eclipsecon.com...
>>> Hi,
>>> The following line
>>> definition.
>>> setting the metamodel before calling **execMgr.executeTransformation();**
>>> Best regards!
>>> 0
Re: [MOFScript] loading Metamodel [message #383918 is a reply to message #383904] |
Mon, 30 June 2008 14:12  |
Thanks Goran,
i solve my problem making, lookUp my metamodel, registring the
ResourceFactory nad loading my model by archive.
execMgr.lookupAndAddSourceMetaModel("jast", "JavaAbstractSyntax");
execMgr.lookupAndAddSourceMetaModel("JavaAbstractSyntax","JavaAbstractSyntax ");
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "javaabstractsyntax",
public Resource createResource(URI uri)
XMIResource xmiResource = new XMIResourceImpl(uri);
return xmiResource;
execMgr.loadSourceModel(new File(inputPath));
Re: [MOFScript] loading Metamodel [message #618081 is a reply to message #383895] |
Mon, 23 June 2008 06:42  |
Hello again,
public TestAPI () {
/G
Re: [MOFScript] loading Metamodel [message #618091 is a reply to message #383896] |
Thanks Gøran,
i did it...
i m doing it:
at
at
Any ideia?
Thanks in advance
> Hello again,
> public TestAPI () {
> /Gøran
>> Hello Netuh,
>> Cheers,
>> Gøran
>>> Hi,
>>> The following line
>>> definition.
>>> Best regards!
>>> 0
Re: [MOFScript] loading Metamodel [message #618104 is a reply to message #383904] |
Thanks Goran,
return xmiResource;
Current Time: Wed Apr 16 06:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.03887 seconds
